Japanese 2010 Prius information
Discussion in 'Gen 3 Prius Main Forum' started by ken1784, Mar 11, 2009.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I also visited the parking lot on April 19th, Sunday. :)
    The label said the vehicle is for Miyagi Pref in Japan.
    Another one with wider license plate frame is going to France.
    Anyway, I saw following tire brands for EU countries.
    (impossible to see tire brands for JP or NA model)
    15inch Bridgestone ECOpia B250 (the B250 OE brand is new to market)
    17inch TOYO PROXES R30
    17inch Bridgestone TURANZA ER33
    Ken@Japan
    4 people like this.
  2. patsparks
    10,664
    569
    Adelaide South Australia
    Steering wheel is on the right, the aim of the headlights give it away.
    Kidding, it's the wiper but since I posted I see a few others already picked it.
  3. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Interesting. So you can choose one of those options right upon ordering time? The dealer fits them for you?
    I checked the 15" and 17" dimensions, and came to the curious result that the 15" wheel is in fact larger. It has a bigger perimeter, although not so wide with only 195mm instead of 210mm.
    So my ideal car would have 17" or 18" rims with 195mm wide tyres, and more direct steering and suspension, to make for the best of both worlds. The 195/50R17 would be perfect. It has the same perimeter as the 195/65R15 (1.25% dif.) but has better looks and better handling.
    I would get the 15" car to get the PV roof and then put these 195/50R17 rims with proper tyres, if only I could have the 15" car with sport suspension setting and direct steering with the brushless motor like the 17" version.
    I don't quite buy the weight problem on the rims. There are rims out there that are quite light. The most beautiful one and perfect for the Prius (my opinion ok), is the ultraleggera:
    It weights less than 7.5 kg on the 17" version, I doubt the OEM ones weight less than that. Check this out:
    OZ - Inside the excellence since 1971 - Ultraleggera
    On top of that, a low profile tyre weights less than a tall sidewall tyre, so the total weight should be quite less than the standard 15" wheel.
    What do you all think?
  4. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Finally we get an LRR tyre!
    The Turanza ER is a summer tyre, not all-season. The ER30 (OE on UK 2G Prius) has been pretty poor all winter and spring. I'd have replaced it, once I found this out, if I didn't want to avoid discarding perfectly good tyres.
  5. Patrick Wong
    18,210
    6,517
    Hi Ken,
    In which city is this parking lot located?
    How did you get past the barbed wire on top of the fence??
    How did you get close enough to take photos of the labels and determine the tire brands/models??? :confused:
    Did you work for the Japanese equivalent of the US Central Intelligence Agency at some point earlier in your life???? :D
    If you see any NA or JDM vehicles in the future, I'd be very interested to know what the tire brands and models will be.
    Thanks very much for continuing to supply this on-site intelligence that would otherwise be unavailable to those of us outside Japan...
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Thanks Ken for your work. I love it. You are our paparazzi. :D
  7. Wooski
    Wooski New Member
    241
    63
    London, UK
    The Prius wheels are designed for good aerodynamic performance whereas these wheels are designed purely for lightness. Whilst they may weigh less (and so provide slightly better acceleration) one wonders what the effect the additional drag will be at highway speeds. I would assume that Toyota has taken this into account, particularly with the 17" wheels. Mind you somebody will always bling them up, my neighbour with a Black G2 has a set of black 16" alloys on it that do give it a very "stealth" look.
  8. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Absolutely! These OZ are not aerodynamic at all, the question is "will the reduced weight compensate for that?"
    I was just arguing about the fact that some say the solar PV roof can't be fitted with 17" wheels because of the added weight.
    I would say it is not impossible to have 17" wheels weighting less than the OEM 15" wheels of the new 2010.
    Just out of curiosity, has someone measured the weight of our current 16" wheels on the 2G? I mean without the tyre, just the rim, has anyone take its weight? The ultraleggera in their 16" version only weight 6.46kg... I doubt our current rims are lighter...
  9. Flying White Dutchman
    4,376
    313
    damm that a lot of white new nice prius gen 3's there:cool:
    i think where going to need a special forum just for the white prius owners:p
  10. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Prius Team confirmed in the other thread that those are for the Government agency only. They are the first batch to measure the quality control. I guess they did so well because they are starting the official production tomorrow.
  11. Flying White Dutchman
    4,376
    313
    ok in that case these are the plugin versions
    going to france where there is going to be a plugin trail like in many places
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    No, those are the non-plugin version. I would guess our Prius Priority orders will be built the first thing tomorrow. :D
    Ken,
    Can you go back to the factory again tomorrow and take pictures for us? I want to see if you can find my order (Blue Ribbon Metallic with Solar/Sun Roof package). :D
  13. Flying White Dutchman
    4,376
    313
    yes you can find it by looking at the same like in the picture
    al rapped up:D
  14. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    On a second thought, you may be right. Those white 2010 Priuses may be the plug-in version.
  15. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    The one that's going to France has different model number: ZVW30L-AHXEBW
    Does that mean it is a plug-in version?
  16. Patrick Wong
    18,210
    6,517
    L is left hand drive. Don't know about W.
  17. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi Patrick,
    It is Toyota Auto Body Fujimatsu plant in Kariya city, 300km away from my home.
    It's interesting to see "5" in the VIN. They used to use "7" for Fujimatsu model on the current Prius.
    Two sides of the parking lot are faced to public road, therefore anyone can take pictures from public road. I could take pictures through the wired fence.
    I used my 28-300mm zoom lens attached to Nikon D100. :)
    Anyway, I also visited Toyota Tsutsumi plant in Toyota city.
    Their parking lot was covered by tall solid fence, so it's hard to see vehicles, only possible to see through the gate.
    I saw a few current Prius on the parking, no 2010 Prius.
    I think they are starting to make 2010 Prius at Tsutsumi plant on April 20th as announced.
    no ;)
    Sure!
    Next time, I'll have binoculars with me to see more detail. :)
    Ken@Japan
  18. Tideland Prius
    16,678
    Thanks for the pics Ken!
  19. Mike Dimmick
    963
    249
    Reading, UK
    See Toyota ID code decoder: L = left-hand drive, W = destined for Europe.
    I think the plug-in is likely to get a different 'grade' character, perhaps AHXQBn.
    2 people like this.
  20. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Thank you for the Toyota ID decoder link.
    Following two pictures were taken at PCD event.
    So, they are left-hand drive for US.
    I can't see "5" in the VIN, therefore I think they are from Toyota Tsutsumi plant, shown by "0".
    Ken@Japan
