JBL amp wiring in Prius 2005, 86280-0W240
Discussion in 'Gen 2 Prius Audio and Electronics' started by radarama, Oct 16, 2013.
  1. radarama
    radarama New Member
    Hi everyone!
    I've been looking all over for a wiring diagram for the JBL amp sitting in my 2005 Prius, the plugs going in to the amp has a billion wires and I've got no clue what they are. The model no. on the amp is 86280-0W240. Can anyone point me in the right direction? Any help appreciated.. Thanks! :)
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Welcome to PC.
    I believe I have A wiring diagram for the JBL system. Unfortunately I will not be able to post it till Friday. Hope this will be of help.
    John (Britprius)
    radarama likes this.
  3. Britprius
    5,194
    1,921
    JBL wiring diagram with separate amp:- Radio w_Separate Amp 1of2.jpg
    Hope this helps. If you cannot read the diagram because it is to small let me know, and I may be able to send you this via a PM (private message).
    John (Britprius)
    Paullllc, HeadOfJarg and SFO like this.
  4. radarama
    radarama New Member
    Fantastic, thank you! If you could PM me I would be grateful, a bit difficult to read some of it. :)
  5. Britprius
    5,194
    1,921
    I have sent you a PM.
    John (Britprius)
  6. Jeff Tremble
    Jeff Tremble Junior Member
    Bergen County NJ
    John, If you still have those files could you please message them to me as well. Thank you in advanced.
  7. sounds_great
    sounds_great Junior Member
    34
    +1 Thank you!
  8. Big Tex
    Big Tex New Member
    Hello I am working on upgrading my 2005 with JBL and I would love a higher res version of this diagram. Thanks!
  9. Big Tex
    Big Tex New Member
    Thanks John! Let's see if I can attach them to this thread for others to see as well...
    [​IMG] [​IMG]
  10. JJsCarAudio101
    JJsCarAudio101 New Member
    17
    Los Angeles CA
    Very helpfull shcematic. thanks for posting
  11. quatvnn
    quatvnn New Member
    Hanoi
    Can anyone help me pls. I am installing the after market HU to the OEM JBL amplifier 86280-0W640 but ít does not work.
  12. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
  13. Marclais
    Marclais Junior Member
    Sacramento
    Question: looking at this diagram... If I removed thw head unit completely, then just spliced a headphone jack wire into the R and L + and -, would this effectively give me a line in?
    My MFD is broken and all the audio I listen to is through my phone. I'd like to just hard wire in a Bluetooth adapter and eliminate the head unit altogether. Would this work?
  14. 69shovlhed
    2,170
    751
    Delaware
    I doubt it. best solution is an aftermarket 2din headunit
  15. Baoht1986
    Baoht1986 New Member
    Hd
    Rất cảm ơn bạn
  16. Michael Szatmary
    Michael Szatmary Junior Member
    Denver, Colorado USA
    I have a 2005 Prius w/separate JBL amp and purchased the 2006 factory xm radio receiver and a cable harness for the interface. I believe the cable I received is the wrong cable for this installation but was able to connect and successfully interface the xm receiver with the multi function display which indicated and displayed I was receiving XM radio stations. However the cable I have does not appear to be the correct cable to interface with the amp and as a result I do not get any sound out of the system. Any information on wiring details between the multi function display, JBL amp and XM receiver would be greatly appreciated. With those details I think I can modify the cable harness that I have to work . If you have the part number for the proper cable I can also look for that but these are so old now I'm not sure I can find one. Thanks for your time and help.
  17. Classic Car Guy
    Classic Car Guy Active Member
    429
    119
    Northwest, USA
    Hi John,
    Just a follow up on the JBL 2007 factory amp for I want to add a Rockford Fosgate amp for an additional subwoofer. Provided I have the High line inverter to RCA so I can plug to the additional subwoofer amp. I saw your schematic and I was planning to connect it to the amplifier input if that's correct as I have an additional drawing on the schematic. attached. its the Green line with the Red dot. Is this correct? or should I go with the jbl amp out rear speaker going to the inverter?
    Thanks Joe
    #17 Classic Car Guy, Feb 24, 2019
  18. Britprius
    5,194
    1,921
    I used the rear speaker JBL output to drive my amp, but there is no reason why you cannot use your method shown.
    I only look in on PC occasionally as I have sold my Prius, and bought a Lexus GS450H hybrid.
    John.
  19. Classic Car Guy
    429
    119
    Northwest, USA
    Hi John,
    Oh okay. Congratulations on the new car!
    Thanks for that diagram and I was able to get the back system running. The bass frequency is right on the money. Good thing I had the chance to install it last Sunday. Great!
  20. Teajelly
    Teajelly New Member
    CA
    Could you send me this diagram as well? I’m installing a subwoofer in my Prius. Can I tap into this amp instead of going into the dash? If I can, which wires do I splice into? Thanks
