JBL Audio System Quality Question
Discussion in 'Gen 3 Prius Audio and Electronics' started by Geoffe, Jun 26, 2012.
  1. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    Well no problem for me. I took the old speakers completely out, made new base plates with 3/4 plywood, (good for now) and cut the holes for the speakers, mounted the bases on the door first, then mounted the speakers to the base plates. Use t-taps on the speaker wire just behind the plug. These take more power and the HU has a lack of power for these speakers, thus my comment to take it to 40 as that when I can hear it pretty well. It is by no means blasting. 16 watts in a 80 watt speaker doesnt go far.
  2. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Ahh I understand the 40 comment now.
  3. Geoffe
    Geoffe New Member
    Michigan
    I am going to try that today.
  4. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Since I got no response from the retired broadcast engineer, I went ahead and adjusted the settings by dropping the midrange setting and decreasing the treble setting to one notch below max and the bass setting to 2 notches below max setting. I didn't drop the midrange all the way, maybe to about 2 or three from the lowest setting.
    It does sound "fuller", and I still have plenty of volume adjustment.
  5. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    Sorry, was out in the new car. LOL. What did ya expect with a new toy? hehe
    Yes, any variation of the V setting by adjusting the bass up and treble up while keeping midrange the same or lower will provide you that fullness response I was talking about. Hope you like it.
    Cheers
  6. Prius Guy
    Prius Guy New Member
    I made the adjustment of midrange that you recommended and it made a huge improvement in the bass. It sounds great! Thank you!
  7. Three60guy
    918
    16
    Racine, Wisconsin
    Prius Guy, excellent. Glad it improved your listening pleasure.
  8. Howard12
    Howard12 Junior Member
    Can you tell me the model of those Polk speakers you bought? I'm desperately trying to improve the crappy sound of my Prius III. Is it totally compatable with the stock non-JBL receiver?
    Thanks
  9. swich2mac
    swich2mac Go Hard or Go Home!
    319
    38
    Franklin, TN
    Adjusted the settings according to Three60guy's advice except moved the midrange half way down from center and this made a HUGE difference. I was contemplating getting a powered Bazooka sub but at the moment, I don't believe I will have a need!
    I also moved the fader from center to 2 notches to the rear and I now have a more balanced sound throughout the cabin! Thanks again for the "sound" advice! :)
