JBL Speaker repair
Discussion in 'Gen 2 Prius Audio and Electronics' started by Athos, Jun 12, 2019.
  1. Athos
    Athos Junior Member
    Ontario, Canada
    On the front door speakers the outer rims tore away so I glued them using Urathane. The second picture shows how I pressed it together until it set. I did two a few months ago and they held nicely. I don't crank the volume but the urathane is pretty strong. It should hold.
  2. ChapmanF
    15,647
    It might last, but I think what has usually happened is deterioration of that foam itself, making up the speaker surround. Your layer of urethane will stick it back together where it came apart the first time, and then the foam will just disintegrate again someplace else nearby.
    I've had very satisfying results using refoam kits from Parts Express.
    VFerdman and Athos like this.
  3. VFerdman
    VFerdman Senior Member
    1,152
    1,177
    Western Massachusetts
    Absolutely agree. Once the surround starts to go, it's a death spiral. Need to either replace the speakers or re-surround them. I've done the re-surround on home speakers and it's not that difficult, but sometimes replacing the drivers is more cost effective as it takes a bit of time to do the re-surround well plus the cost of the kits. If those drivers are easily and inexpensively replaced, I would go that way. After all, JBL is not some kind of super-duper awesome and rare speaker that must be preserved for posterity for future generations.
    Athos likes this.
  4. ChapmanF
    15,647
  5. VFerdman
    1,152
    1,177
    You don't need to go to Toyota for a speaker, I am sure. Just find a pair that's similar in size at Walmart or Crutchfield and go on with life. On the other hand, $22 refoam kit will take all day to install, if the installer is not experienced in such things, there is a 87% chance it will not come out well and they'll be back at square 1 minus $22 and a day wasted. I am all for DIY, but after having refoamed a few drivers I would not advise it to others unless the driver in question is something really special that can not be replaced for $35/pair. That's just my opinion, obviously, no judgement on what others want to do with their time and money.
    Athos likes this.
  6. ChapmanF
    15,647
    No strong opinion either way on my part, just reporting. There is an older PriusChat thread reporting favorably on refoaming. (One point raised there is the possibility of doing the work in place, no drilling out rivets.)
  7. JC91006
    16,482
    8,400
    I checked with crutchfield before on the jbl speaker replacement, they didn't have anything that was in the same range as the oem speaker. Not sure what the correct terminology was used, but they didn't have it. Best to go online and buy a newer non foam (rubber) jbl speaker from later model Toyota cars
    Athos likes this.
