JDM Headlights
Discussion in 'Gen 3 Prius Main Forum' started by Eggman, Feb 2, 2021.
  1. Eggman
    Eggman Junior Member
    So Cal
    2013 Prius Plug-in
    I just got some JDM headlights (halogen, non-LED) and I noticed the blue housing isn’t as blue as the USDM ones. Is this normal or did I get a faded set?
    Also I didn’t realize these JDM ones had auto leveling with the halogen versions.
  2. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Depending on your state of residency, you will be ticketed for not having orange side markers with those headlights on a turd gen stock prius
  3. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Is your car a plug in? If so that model comes with a slight blue hue in the headlight assembly from Toyota
    Vman455 likes this.
  4. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Was going to say this too; you're comparing plug-in headlights with the "blue chrome" housing to regular chrome JDM lights.
    I kind of like the darker look, actually, orange reflectors or not.
    RightOnTime likes this.
  5. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    I love the clear side markers and I have european headlights on my Golf GTI with the clear side markers and I have never had a problem. They've been on for 2 years.
    #5 David9962000, Feb 5, 2021
  6. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    The bulb in the clear marker is amber, which makes it compliant.
  7. Vman455
    539
    556
    The Middle
    State regulations probably vary*, but federal regulations require an amber reflector--doesn't have to be a light, but a light doesn't satisfy the requirement. You can read the relevant material here, in Tables III and IV at the bottom of the page.
    That said, I've had clear reflectors on three cars and never had a problem.
    *I looked up California's vehicle code, and they allow "white or amber reflectors that are mounted on the front of the vehicle at a height of 15 inches or more, but not more than 60 inches from the ground." Again, no requirement to light it, but the OP should be fine with a clear reflector.
    #7 Vman455, Feb 6, 2021
    Grit likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Correct. The state in particular is more concern about the car parked without its parking lights on. Will it reflect an amber color when your driving towards the car so you’ll know that is a car’s frontal end. Just like the back reflector of a bicycle, it doesn’t light with a bulb up but when shine a light to it, it’s red so you’ll know it’s probably a bike.
  9. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    The 2010 and 2011 Prius headlight lenses have a blue tint to them whereas 2012-2015 models have no blue tints.
