JDM / Japanese VIP Styling: My Prius III Build
Discussion in 'Gen 3 Prius Accessories and Modifications' started by HAWAIIANBUILT, Sep 30, 2010.
  1. HAWAIIANBUILT
    HAWAIIANBUILT Senior Member
    824
    791
    69
    SO CAL
    Hello Allan !!!
    I won't be able to join you all this Saturday March 13, 2015 as I will be at the Spec D Tuning Show in the City of Industry.
    Here's the Flyer for the event should you all decide to stop by :
    Have a Great Weekend !!!
    Rodney
    orenji likes this.
  2. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    Awesome! Thanks for the info! Have a good one!
  3. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Rodney,
    What next on the list? How about strobe light in the front or rear of your ride? For show of course.
    HAWAIIANBUILT likes this.
  4. ncases
    ncases Senior Member
    609
    672
    Chicago
    Hi rodney. Do you have the link on your puddle light leds
  5. HAWAIIANBUILT
    824
    791
    69
    SO CAL
    HEY THERE PRIUS CHAT FOLKS !!!
    I've completed the Latest Modification product to HBII :
    Toyota OEM Side Marker Lamps !!!
    Side Marker Lamps are standard equipment not only here in the US, but elsewhere around the world. I wanted to install this added safety feature to the HBII Prius !!!
    Here are my pix !!!
    These particular Toyota OEM Side Marker Lamps were manufactured in France !!!
    The Lamps overview ...
    Desired Location
    Driver & Passenger Front Fenders
    Alignment
    I headed over to the great folks at Imperial Body Shop in La Habra, California for their expertise ...
    Using the rubber seal, they used it as a template for the hole to be drilled ...
    Almost done with the Driver Side and Passenger Side !!!
    After the tight test fittting ...
    The holes were completed !!!
    After the great install, it was time to head home and touch up the bare metal exposed from the process ...
    Cleaned the location and paint touched up ...
    Then it was time for the wiring connection process ...
    Removed the wheels and lifted the Prius
    Removed the headlamps
    **For My Particular Installation I wanted the Turn Signal Lamps to serve a Dual Purpose : To function Both as a Parking Lamp as well as a Turn Signal Lamp**
    Located the OEM wiring for the Turn Signal Lamps)
    Driver Side : Yellow Wire = +
    Passenger Side : Green = +
    Both Sides : White / Black = Ground
    (Not Shown : Wiring for the Parking Lamps)
    Wiring from the side fender holes, through the inside of the fender, and to the front of the vehicle. This was easily accessed through the plastic fender wheel well shroud.
    For the Side Marker Lamp Two Prong Connections :
    I used an insulated connector :
    I then tested the lamps :
    Replaced the OEM Orange Bulb to a High Intesity LED. I purchased the 6000k color to match the existing LEDs on the Prius.
    Because I wanted these lamps to serve a dual function of Parking and Flashing, I utilized this product :
    The exLED USA control unit.
    With two power sources connected (Parking and Flashing), it will interrupt the power connection when both sources are feeding power. This will create the flash. Please see the videos at the end of the post !!!
    I then made the connections :
    IN : (To 2 Power Sources and Ground)
    Yellow = Flashing
    Blue = Ground
    White = Parking
    OUT : (To Side Marker Lamp)
    Red = Power
    Blue = Ground
    I then reinstalled everything
    And then VOILA !!!
    Here are the VIDEOS taken at night, displaying the 2 features that I intended.
    *** Please Click on Each Individual Video !!! ***
    01. On with the Parking Lamps
    02. Flashing with the Signal Lamps
    (DAY Time)
    (NIGHT Time w/Parking Lamps on)
    And because the lamps are connected with the Flashing Lamps, it also served as a lamp with the Vehicle Arm/Disarm feature.
    Overall I'm very satisfied with the Modification !!!
    With the added safety for the side of the vehicle, the added lamp has complemented the JDM Side Mirror Lamps !!!
    Stay Tuned for More Folks !!!
    Rodney
    Johnsk93, saulbassfan, ncases and 5 others like this.
  6. nufan2222
    nufan2222 Junior Member
    96
    2014 Prius Plug-in
    get the folding mirror dude
    sfv41901 likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm just as surprised as u
    VS980 4G ?
    ncases likes this.
  8. nufan2222
    96
    2014 Prius Plug-in
    he have the jdm mirror but no folding mirror, it isn't h ard to wire and they are cheap!
  9. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    cheap where? Is was like $573 when I priced just the folding portion
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'd like to know where 2
    VS980 4G ?
  11. ncases
    609
    672
    Chicago
    I'd like to know as well because I paid mine $780. Maybe i can ask for a price match from topsage international and get some money back.
    iPhone ?
  12. Accordlayingkit
    1,616
    1,747
    377
    @nufan2222 cheap to you must be expensive to us! :rolleyes:
  13. ncases
    609
    672
    Chicago
    I should have bought mine when it was at that price about a yr ago.
  14. Accordlayingkit
    1,616
    1,747
    377
  15. apt5020
    881
    1,294
    Prius City, CA
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  17. ncases
    609
    672
    Chicago
    At onetime some idiot almost hit my mirrors. All i did was pray man. I'm glad it didn't. Next time i will push the fold button.
    I guess you just have to buy the OEM mirrors and swap the motor and 3 in one led if you can save it. Otherwise you have to buy the pair again.
    iPhone ?
  18. Accordlayingkit
    1,616
    1,747
    377
    Yea I know that. Mirrors were only $130 and MIT quoted me a long time ago over $500 dollars for jus the controllers for the power portion
  19. orenji
    orenji Senior Member
    5,887
    3,488
    I have folding mirrors, but they are the manual ones! (y)
    ncases and Accordlayingkit like this.
  20. nufan2222
    96
    2014 Prius Plug-in
    I bought my set for 350 SHIPPED pre painted. They are the OEM aftermarket one. Pretty much looks like it. I order fro mthis guy
    signal door mirrors & GoSafe devices
    Both mirror, including the side marker and also including the auto folding module. You guys just need to look harder LMAO!
