JDM Prius Steering Wheel
Discussion in 'Gen 3 Prius Accessories and Modifications' started by w202mae, May 18, 2011.
  1. SoCal 2012 Prius Plus
    Thanks to everyone who posted on this thread, I am a new 2012 Prius Plus owner and just installed the piano black steering wheel. Because of this thread, install only took about 45 minutes tops from start to finish! Thanks again!!!
    KLD_Prius_PI_Synergy likes this.
  2. SoCal 2012 Prius Plus
    Dawit, ucsmfu, JMD and 1 other person like this.
  3. priusrick
    priusrick Member
    257
    40
    Nice
    HTC One V ? 2
  4. GCPExit12
    GCPExit12 Member
    105
    33
    i'm about to swap my steering wheel. browsed through this thread and saw some mentions of alignment issues in the beginning but no more towards the end. Were those isolated incidents? Did someone find a fix? Or is everyone else just less OCD about their steering?
  5. priusrick
    priusrick Member
    257
    40
    Wish I could get one
    HTC One V ? 2
  6. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Simply a matter of the the splines not lining up exactly as the OEM... car goes straight, wheel is cocked off to the side...
    Doesn't bother you... the little knobbies are at 9 and 1, instead of 10 and 2.... motor on, there's no alignment problem.
    Took mine in for summer to winter changeover, informed Federal Law now requires also having TPMS on my winter rims. Dealer special: $99, 4 TPMS transmitters, balance, and realign, which, of course, included adjusting the tie rods...
    Bad case of obsessive... I keep checking, but I think it's straight... unfortunately, I'm not so sure about the shark fin and the RAV-4 side moulding :)
    GCPExit12 likes this.
  7. w202mae
    w202mae Junior Member
    59
    40
    SoCal
    I started this thread long ago surprised to see it helped so many, good job keeping this thread alive guys. =)
  8. The Critic
    The Critic Resident Critic
    3,193
    2,328
    CA
    Same issue here. Wheel is off a bit to the left, maybe not 9 & 1 bad, but it's definitely not at 10 & 2.
    Now the debate is whether to pull it back off and readjust a click to the right, or tweak the tie rods.
  9. The Critic
    3,193
    2,328
    CA
    I pulled it back apart and moved the steering wheel to the next available "position" towards the right - now the wheel is just a bit off to the right.
    So, there's no way to get the steering wheel centered with this JDM wheel. What a POS...
    If you're brave enough, you can adjust each tie rod by equal amounts in the opposite direction to center the steering wheel. However, by doing so, the steering rack will be off-center. Since it is a small amount, it may or may not matter...but buyer beware. (n)
  10. ProphetsOfDoom
    95
    93
    64
    Virginia
  11. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    You now know that adjusting the tie rods fixes the problem, and you can do this at your next alignment.
    Nice find. There are (at least) two sport versions. This one has the more aggressive thumb rests but no "cancer grips" in the top wood. If you're in the LA area, you can pick up the more common sport version from nigel-jdmparts.com for $190 paid in cash.
  12. The Critic
    3,193
    2,328
    CA
    Sort of. It does throw your steering rack off-center a bit, which is a buyer beware.
  13. our1vue
    our1vue Member
    313
    58
    NY
    I thought these weren't for sale in the US because of air bag issues ?
  14. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    What issues and where did you hear this? You salvage and re-use the OEM airbag and all connectors, nothing has changed. JDM products are normally not for sale in the US unless an US retailer imports them.
  15. our1vue
    our1vue Member
    313
    58
    NY
    Where else do you find everything you ever wanted to know about a Prius - Priuschat. There is a thread in this forum called wheelskins. In there someone appended ...
    Again, SIGMA isn't selling the wheel to US Consumers anymore per their website as well as an email response from them. Apparently there were airbag compatibility issues.
    I don't know if anyone ever said what the issue was with the airbag. It is a shame, because their leather steering wheels look really nice.
  16. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Thanks for that link. It appears from the posts they're referring to the factory all leather steering wheel found on JDM Prius upper trims, not the JDM aftermarket wood/leather wheel mentioned in the OP.
  17. our1vue
    our1vue Member
    313
    58
    NY
    Hmm. Wonder what the difference is. You wouldn't think that putting a wood top on it would make it ok vs all leather.
  18. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    The specific steering wheel that Sigma pulled from the website appears to be a JDM OEM product. Most of us have the aftermarket version and there are many manufacturers of aftermarket steering wheels for the Prius. I'm not sure of the reason for the airbag incompatibility of JDM factory wheel on the US Prius; however, I do know that fellow member ucsmfu had trouble fitting the JDM piano black wood steering wheel on the Canadian Prius as the back cover on Canadian Prius is wider than the US Prius and he had to make some modification to make it fit. Perhaps JDM OEM steering wheel is designed to be airbag-compatible only on Japanese Prius.
    If you get the aftermarket wheel in the OP, you shouldn't have any fitment or airbag issues.
  19. priusrick
    priusrick Member
    257
    40
    Still thinking about this....hmmm
    LG-MS870 ? 2
  20. ockevin
    ockevin Active Member
    493
    148
    Orange County
    Do it...Great feel to the steering wheel and hated the stock small diameter wheel.
    Accordlayingkit and TopRamen like this.
