JDM Prius Steering Wheel
Discussion in 'Gen 3 Prius Accessories and Modifications' started by w202mae, May 18, 2011.
  1. VicD
    VicD Junior Member
    52
    Ohio
    where did you get those CF trim on your steering wheel? thanks
  2. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
  3. VicD
    VicD Junior Member
    52
    Ohio
    How much for u guys to ship the steering wheel when you get it from Rakuten global from Japan? I ordered a few items along with the steering wheel, a shift knob, a few chrome piece for the car, they are very light. And I was quoted $100 for the shipping to US. I think it's alil expensive.
    iPhone ?
    Accordlayingkit likes this.
  4. Xterra72
    Xterra72 Senior Member
    1,436
    1,681
    I use to order from Raluten Japan and from what I remember I paid about $50ish for shipping.
    I'm sure it all depends on size and weight.
  5. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Looks good brother! I need those covers in piano black since my steering wheel is piano black. Where did you get those? Cheers!
  6. Accordlayingkit
    1,618
    1,748
    377
  7. VicD
    VicD Junior Member
    52
    Ohio
    Those of you have experienced with Rakuten global, i need your help. I placed an order, seller reply with a shipping fee, I wrote back asking about shipping rate being too expensive. And additional shipping info, didn't hear back from them for 3 days. What should I do?
    iPhone ?
    No one knows?
    iPhone ?
  8. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    if you told them the shipping is too expensive for you, I think they just assumed you wanted to cancel the order /
    BION
    StarCaller
  9. Xterra72
    1,436
    1,681
    I say cancel the order and go somewhere else. If they really wanted your business they would have replied right away.
  10. VicD
    VicD Junior Member
    52
    Ohio
    Thanks
    iPhone ?
  11. VicD
    VicD Junior Member
    52
    Ohio
    any technique to remove the air bag harness? Just use flat head screw driver, push down and pull out?
  12. Accordlayingkit
    1,618
    1,748
    377
    flat head under each yellow tab and pry up
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Then once up, use the small flat head between the connector & the metal frame of the airbag......give a slight twist. That's it
  14. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    I just did the MIT piano black steering wheel change over, I follow the instruction on this post, THANKS. I have no trouble removing the stock leather steering wheel, the nut is tight once loosen the wheel pops right out, I don't even need the steering wheel puller.
    Start to finished about an hour plus, the MIT is heavier than the stock (2.2 lbs vs 2.1 lbs stock), I have a hard time put back the bottom plastic cover, but it's tight fit. The steering wheel NOT center at all, I have to get alignment done again now it's perfectly straight.
    It's a little scary and shaky removing the air bag, I never ever remove an air bag before, but at last I did it and I am happy with the finished fit and look. I end up drove to my brother (Honda dealership master tech) to get the alignment done. Now it's perfectly center.
    Before,
    After,
    Alignment print out, front toe now centered at 0.10, the rear toe is still within spec not adjustable...it needs shims to correct the toe.
    Here is the photo of the latest alignment sensor mount, it mounts into the inner groove of the tire, no more scratch rims by the sensor hooks. Awesome technology.
    #394 nedear88, Jan 31, 2016
    eunique, orenji, Dylan Doxey and 3 others like this.
  15. Mike101
    Mike101 Junior Member
    31
    60
    Richmond, VA
    Did someone leather wrap the jdm or buy it like this? I like it 100% leather wrapped. Looks super clean.
    I like this steering wheel 100% leather wrapped. Any idea where to get it?
  16. Mike101
    31
    60
    Richmond, VA
    Just wanted to give a shout out that I just installed a new steering wheel using your instructions. They were spot on. Years later they are still changing lives. Thank you!
  17. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Success! I now have a leather-wrapped wheel from an Advanced model.
    The directions in this thread made this very easy. I didn't need a puller to remove the steering wheel, but it took some force. Once I cracked loose the nut which holds the wheel on, I loosened it a few turns, but kept it on so that I could pull hard without the wheel flying loose. This also kept the wheel aligned on the splines.
    As another poster pointed out, alignment of the new wheel isn't ultra-critical, becaus the splines are spaced pretty far apart.
    Disconnecting the 12V battery is definitely a must.
    #397 Rebound, Mar 6, 2016
  18. Rebound
    3,996
    2,645
    Portland, OR
  19. AK18
    AK18 Member
    45
    83
    SoCal
    For those who have been using the wheel for several years, any complaints on the durability of the wooden part, especially in SoCal summer weather and cold winter? Are they cracking? Thanks
  20. priusrick
    priusrick Member
    257
    40
    I love my Toyota Leather Wheel. Skipped on the JDM and am happy with my decision. No-one even knows it isn't the right wheel for my car. No one ever says anything about my seats either.
