JDM salvage engines from Japan
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SteveLee, Jul 30, 2023.
  1. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Decided to swap out my head blown engine for a used one. Is JDM the best option for the salvage engine for the mid east coast? Is there a difference between the USA engines and the Japan engines. They have a bunch of salvage engines imported from Japan. Anyone have any links for the differences if there are any.
    #1 SteveLee, Jul 30, 2023
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,903
    6,844
    Texas Hill Country
    No vin on a JDM engine so no way to check history or mileage. Salvage yards here routinely remove vin plates on US engines so origin stories can be murky.
    With that said, my local independent hybrid shop likes them from a source that requires purchase of ten at a time.
    The only way they could be better is if they did not use low tension rings. And if they really have 50k-60k miles as advertised.
  3. SteveLee
    645
    180
    North Carolina
    I
    Are the engines from Japan exact replacement bolt ins for the ones sold in the US? Is there a more reliable source for mileage at similar pricing? JDM does have a 100% positive feedback on Ebay. Seems they have a good track record. Or can things seem better than they are?
  4. Mendel Leisk
    42,207
    What's the miles? Was the EGR system ever cleaned? Water pump original? What's your oil consumption like?
  5. SteveLee
    645
    180
    North Carolina
    I
    It has 224k miles. EGR and water pump have not been serviced or replaced. Oil consumption has increased considerably. I can see little bubbles in the oil on the stick. It has started the death shake when heated up. My son's 3rd Gen went through the same thing a few years back. He ended up replacing the engine with no previous mechanical experience, learning from YouTube.
    Edit: It's worth noting there was no indication of it running hot or the water pump stopped working. My son says it, the water pump, sounds over-revved like his did when it had gone out.
  6. Mendel Leisk
    42,207
    Consensus here seems to be to replace the water pump around 150K, at the latest. They have been failing around that amount of miles. Plastic impellor starts seizing.
    Is the coolant level stable? That said, with your miles and maintenance, it's pretty much certainty the head gasket is letting go.
  7. SteveLee
    645
    180
    North Carolina
    I
    At this point the cooling level has gone down a little but the condition is getting worse with time. My son's car slowly got worse over a year before he finally had to do something. Unfortunately, I failed to heed the warning from my son to change the water pump earlier. That would have been a much simpler preventative measure. Another lesson from this is when the sounds change, it means something likely has or is going bad. And the water pump had started making a different sound.
  8. rjparker
    10,903
    6,844
    Texas Hill Country
    Most gen3 head gaskets go out slowly with the first severe rattle in the morning which may not repeat for weeks. 15,000 miles later the rattles may cause slight coolant loss or rattling after a minute wait at a traffic light. Rarely is there an overheat ever.
    Carbon buildup from the rings, marginal pcv and egr design combined with large thermal swings (cylinders cooling off 30-50f because of the engine on off cycles) over 125,000 miles or more are culprits. All of which were redesigned in the far more reliable gen4s.
    Keeping the rings free with 5k (max from day 1) oil changes and avoiding traffic jams or long idles helps.
    Blatant overheating will kill any engine. However Toyota cooling systems are very good and overheat warnings are there if heeded.
    Gen4 Cylinder Insulators and Revised Coolant Passages: Prius Gen4 Cylinder Insulator.jpeg
    #8 rjparker, Jul 31, 2023
  9. SteveLee
    645
    180
    North Carolina
    I
    Thanks for the interesting explanation. This was the same conclusion my son came to, the constant starting and stopping of the ICE causing expansion and contraction, much more so than the conventional engine. That seems like a design flaw that Toyota should be willing to mediate when someone has a major failure. I don't think that was a problem on the gen2 either, was it?
  10. Mendel Leisk
    42,207
    Periodic EGR cleanout is paramount to head gasket longevity, my 2 cents.
  11. ASRDogman
    ASRDogman Senior Member
    7,993
    4,056
    The stopping and starting of the egnine is NOT a flaw. It's the way it was designed.
    Any car that is "city" driven will have more wear than one that is drive "highway" miles.
    Look how long police car engines last...because they run all day/night. Very constant.
  12. SteveLee
    645
    180
    North Carolina
    I
    Sorry I wasn't more clear. Yes, the starting and stopping is a design benefit to be more efficient. The expansion and contraction to the point of contributing to the failure is the flaw it seems. Those police car engines as well as some others last because of running more constantly that prevents the wide temperature changes, I believe.
  13. ASRDogman
    7,993
    4,056
    Yes, any engine, not just he Prius, if it runs constantly, should last longer.
    It's why every manufacturer tries to get it to operating temperature quickly and keep it there.
    If you call it a "flaw" for everyone engine, okay, but not JUST for the Prius. (y)
  14. Mendel Leisk
    42,207
    No problems in 2nd or 4th gen, only 3rd with its carbon-clogging EGR.
    SteveLee likes this.
  15. SteveLee
    645
    180
    North Carolina
    I
    There are not EGRs on the 2nd and 4th gens? It does seem likely there was some design difference to gen3 to have such a big issue.
  16. rjparker
    10,903
    6,844
    Texas Hill Country
    No egr on gen2 plus a completely different 1.5L engine. It used an elaborate coolant system in an attempt to have consistent temps and warm up faster. Gen2s are often oil burners. Conventional oil used at 5k intervals. Brake booster failures but no serious hg issues.
    Gen3 was a new hybrid design as a 1.8L engine. Low tension rings and other design flaws to reach a stretch goal of improved mpg. Many Toyotas had low tension rings and became oil burners. Gen3s often burned oil early in their life cycle. Toyota changed pistons and rings free if burning exceeded 1 qt in 1200 miles. With synthetic oil and a doubled 10k interval, along with two free changes to reinforce that interval, people could run out of oil between changes and not qualify for the engine work. Egr intake before the cat. Inverter and brake booster failures. Egr clogging occurs especially on oil burners but it is egr sticking open that caused mild rattling. A software fix was offered.
    Toyota fixed the serious issues partially by the 2015 gen3 and significantly by 2016 gen4. Including major work to solve gen3s thermal cycling cylinder wall temperature issues.
  17. Mendel Leisk
    42,207
    2nd gen didn’t, 4th gen learned from 3rd gen Guinea Pigs, made major improvements to it’s EGR system.
  18. SteveLee
    645
    180
    North Carolina
    I
    Thank you for the in depth review. Very helpful.
