Jerking after taking off the gas and more..
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sharter0N, Dec 12, 2023.
  1. Sharter0N
    Sharter0N Junior Member
    Poland
    Hello everyone,
    I am a second generation Prius user in Europe, Poland. The mileage is 220,000 kilometers(135~k miles) I have a problem that I can't deal with. I decided to start a topic here on the forum and ask you users for advice.
    The car started jerking when I let off the gas. I feel 1-2 quick jerks in first 1 second. Also when starting off, the moment of ICE activation is much more noticeable(pretty rough). There were no such symptoms before..
    Below I will list the service history of what I have already done, and I will also add that there are no errors in the engine computer.
    Replacing spark plugs and coils (12k miles ago)
    Cleaning the throttle and MAF sensor
    Replacing the PCV valve
    Checked engine mounts looking fine
    The engine is in good condition, serviced regularly with fresh oil. It doesn't make any suspicious sounds.
    It bothers me a lot because the drive is not as smooth as it used to be and I don't enjoy driving mu prius anymore.
    Could some sensor be causing this?
    I would like to ask for your advice on what else I should do. Thanks
  2. PriusCamper
    PriusCamper Senior Member
    13,347
    5,396
    Pacific Northwest, USA
    Any warning lights?
    Is your problem consistent, or intermittent?
    The nature of these Atkinson engines causes them to occasionally run a little rough on start up and shut down, especially when cold. So if it's relatively rare you have nothing to worry about.
  3. Sharter0N
    Poland
    Yes, you're right, the problem got worse in winter. But I use the car as a taxi and when the car drives 6-8 hours a day it has time to warm up and the feeling of 1-2 quick jerks when turning off the engine is there all the time. Very rarely, but there are days when this does not happen, usually when the car is not used for a few days.
    No erros, no warning lights at all, never happened.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Hopefully, this is going to be a very interesting thread. Here's something I've noticed, but haven't really brought up for discussion.
    I've had around (10) Gen 2s in my driveway at various times. I've built a handful of HV batteries for them and several for other forum members. On some, I've used modules from brand new OEM Gen 3 batteries and also made some using modules from very low mile Gen 3 and Gen 4 wrecks.
    I've noticed, at least on my cars because I have plenty of before and after time behind the wheel, that a Gen 2 with an aged HV battery can act just like the OPs symptoms when the engine shuts down or starts while driving. Install a 'new' battery and it goes away. I've always noticed how much different the transitions are after a refurb. Why? I don't have a good answer. Unfortunately, it could be a bit expensive to try battery replacement as an experiment to see if the symptoms get cured.
    PriusCamper likes this.
  5. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    Yes I have a Gen 2 well got four of them here but two of them have had batteries and when batteries were failing or falling into the pitfall of failing a lot more snatching and jerking a clunk when the engine cuts off a noticeable one soon as the battery went in Bam back to like brand new so when I go to buy one of these cars now and get it running in the parking lot where it's been sitting for God knows how long because the people whatever I'll get it started in the parking lot drive it around a little bit and will notice that very quickly of course I'm buying the car for a couple hundred dollars mainly because the hybrid battery probably is dead the reason the cars parked.
  6. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    Adding another data point to confirm this observation. Before reconditioning the HV battery for the first time, it had a rough transition to and from the ICE. After reconditioning, back to very smooth and unnoticeable. Subsequent reconditions were done when fuel economy started to tank, but ICE to EV and EV to ICE transitions were still smooth so have not had the phenomenon again.
  7. PriusCamper
    13,347
    5,396
    Interesting line of thinking... I guess the next step in your process would be to look at the health of the hybrid battery via an inexpensive Veepeak or Panlong OBD2 reader so you can run phone apps like Dr. Prius App and others to get a sense of hybrid battery health.
    Or perhaps more directly, how does the state of charge screen look while driving? Does it move rapidly from full charge down to one or two bars very quickly, or does it stay pretty stable? The more stable the charge level, the healthier the battery pack.
  8. PriusCamper
    13,347
    5,396
    This makes me realize that every time I hear the engine start up in a Prius that's stationary or moving slowly it consistently sounds faster and more efficient with a www.projectlithium.com/?ref=9qLPw battery pack than it sounds with an old OEM pack. Perhaps the availability of more amps more often makes the motor starting the engine sound more robust than an old OEM pack depleted down to one bar?
  9. Sharter0N
    Poland
    Very interesting about batteries. But my battery never gave me a sign that something was wrong with it. I would not like to replace the battery due to the high costs, below is a screenshot from Dr. Prius application. The battery fan was also cleaned and I'm sure it doesn't overheat and I've never had a problem with it.
    The question is the application is a good and reliable test for battery? How else could I check it?
  10. Tombukt2
    13,765
    2,491
    Durham NC
    It's funny how that would work too because when the Prius is moving the reciprocating mass is always turning so starting of the engine is not like a starter motor turning the reciprocating mass and adding fire and fuel to start it I reciprocating mass is already turning with the electric motors etc all the Prius is doing is flipping a fire switch that turns on the coils and the fuel pump I would have to guess. That's why it should be very smooth and all this and that because everything is already turning The Prius is just flipping a computer switch for the fire and the fuel pump and then it turns that off when the computer dictates right? But I do notice in a car with a low battery like you noticed when it's in the magenta red area everything is real sluggish duh. So I guess it would make sense as your battery gets more and more depleted things may get a little clunkier I imagine the relationship of the 70 horsepower electric motor to the I don't know what 90 horsepower of the gas engine becomes less of a match with lower state of charge possibly.? Something along those lines so having more battery power probably a good thing I'd like to have a battery that would be as 2x thick as the battery we have now. The room is not the problem at all I don't need that space I'm going to take up back there at all so I could literally have two battery packs stacked on top of each other not sure how it would get them wired or whatever I would just like to buy some kind of battery that's based on the 211 volt nonsense but with double the AH or whatever that would be called I don't care if it's twice as tall that's okay The bus bar arrangement would be quite wild or the module assemblies would be quite different would matter to me.
