Jerry's Evolving Thoughts on "new-to-me" Prime Premium
Discussion in 'Prime Main Forum (2017-2022)' started by jerrymildred, Mar 12, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    I did. But I'm due again.
    Prodigyplace likes this.
  2. Prodigyplace
    12,556
    11,774
    Central Virginia
    Perhaps that is what the drop in EV is telling you ;)
  3. jerrymildred
    11,517
    14,151
    Tampa, FL
    They were down about 3 psi from where I had them, but I think it's mostly the 100+ degree temperatures. Air conditioner was doing quadruple duty at least. I just pumped them up to 42/40 which is actually a couple psi higher than I had them before the trip, but the same as I had the PiP set to. We'll see what tomorrow brings, but I won't be driving in the hottest part of the day like I did today.
    Data Daedalus and Prodigyplace like this.
  4. jerrymildred
    11,517
    14,151
    Tampa, FL
    OK, pumped up the tires Tuesday night to 42/40. They were about 36 psi. Not much difference, but then again, I haven't had any matching days to compare. But they have all been hot with more or less similar speeds. Tuesday was May 28, the day before the inflation. 29th was yesterday which was after inflation. 30th, of course, is today and so far only has the commute to work, which is very easy on the efficiency since the traffic moves about 40 mph under the limit when it moves at all -- and it's not yet screaming hot.
    So there's really no way for me to know whether the small reduction since the new tires is due to the change in tire brand or the increase in heat. I think that at least 90% of it is heat. In fact, given the same weather and driving conditions as I had in April, I might even get more miles/kWh with these tires. No way to know. IMG_1017.jpg
    Tideland Prius likes this.
  5. Mendel Leisk
    41,425
    If not much difference, I would drop them back down. Higher pressures have got to be harder on bearings and suspension.
    Even with a slight mpg improvement, don't see that it's worth.
    That said: 15" tires are more resilient, my 17's are likely colouring my attitude.
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,151
    Tampa, FL
    I agree. (y)
  7. Prodigyplace
    12,556
    11,774
    Central Virginia
    Your butt probably agrees too, ;)
    Mendel Leisk and jerrymildred like this.
  8. jerrymildred
    11,517
    14,151
    Tampa, FL
    Honestly? I can't feel any difference between 36 & 42 psi in this car. Then again, I think that behind my back my friends call me Captain Oblivious. :LOL:
  9. Prodigyplace
    12,556
    11,774
    Central Virginia
    Obliviously! :ROFLMAO:
  10. Mendel Leisk
    41,425
    Yeah 15" going from 35 to 40 not much diff, 17's are much less forgiving.
  11. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    At the lower pressures, (36/35) my car feels slightly less squirrely in cross-winds.
  12. jerrymildred
    11,517
    14,151
    Tampa, FL
    That makes sense, but I haven't experimented with it myself. (y)
  13. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    You might also consider that when you set them to 42/40 in the (relatively) cooler part of the day, the pressure will be higher when the ambient goes up to 100°F and that is before you start driving and the tires heat up from rolling resistance. It would be interesting to see what they read immediately after you stop driving at 100°F.
  14. jerrymildred
    11,517
    14,151
    Tampa, FL
    Yes, it would, but I never seem to stop and take the time. :)
    Right now, it's time for my first oil change. Just waiting for some more daylight.
  15. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    For my winter tire set-up without internal TPMS, I have been using external TPMS. I now have them on my All Season tire. They are set 38 psi cold at ~50F. When it is ~70F (warmest temp so far), it is at 40psi. After driving ~300 miles on highway at ~70 mph, they are about 42 psi. However, when I did the same thing with winter tires earlier this spring before changing tires, 38 psi cold at ~50F went up to 42 psi at ~70F and 46psi at ~70F after 300 miles on highway at ~70 mph. Looks like winter tires (Micheline Xice3) are more sensitive to temp changes than the all season OEM tires (Dunlop Enasave). Oh, I have never driven a car in 100F temp all my life. In fact I don't remember if I have ever experienced 100F temp ever.
    #435 Salamander_King, Jun 7, 2019
    Data Daedalus and jerrymildred like this.
  16. jerrymildred
    11,517
    14,151
    Tampa, FL
    You're blessed!!! You can always add clothes, but you can only take off so many. :D
  17. DavidA
    2,345
    1,821
    Chicago western burbs
    Salamander_King and jerrymildred like this.
  18. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    A balmy day in the California desert, and not yet to the hottest part of the day.
  19. DavidA
    2,345
    1,821
    Remember, as speed increases, the temperature on the outside skin of the car also increases due to friction with the air, which is far denser at lower altitudes like on the ground. That is why the SR-71 needed to be built from titanium.
    benagi and Data Daedalus like this.
  20. jerrymildred
    11,517
    14,151
    Tampa, FL
    LOL!! :ROFLMAO::ROFLMAO::ROFLMAO: It's scary how many opinions and decisions are based on that kind of "logic."
    But something to remember in really hot weather is that air movement increases heat transfer. So, if the temperature of the air is higher than your body, and there is nothing on your body that evaporates, the wind is adding heat rather than taking it away. I don't know how to adjust that balance point to factor in sweat and a person's ability to produce it, but I have experienced it and it's kinda scary.
    Salamander_King likes this.
