Jerry's Evolving Thoughts on "new-to-me" Prime Premium
Discussion in 'Prime Main Forum (2017-2022)' started by jerrymildred, Mar 12, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
  2. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    I've signed up for Time of Use with our power company here in Northern Nevada. Only paying 5 cents/kwh charging between 10PM-7AM. Works out to about 1 cent/mile vs 5 cents/mile with gas.
  3. jerrymildred
    11,517
    14,171
    Tampa, FL
    Cool. We still don't have TOU here. Did they raise the rates during other hours? I charge mostly before 6AM, but often have to charge in the daytime or early evening.
    Marine Ray likes this.
  4. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    jerrymildred likes this.
  5. jerrymildred
    11,517
    14,171
    Tampa, FL
    I'm not trying to talk you into anything, but some people do fly one way here and drive back.
  6. Marine Ray
    1,139
    949
    Sparks, NV
    Yes, here's the rates. Obviously, one has to be careful from 1-6PM on Summer weekdays but I think overall it's a great option to consider.
    Yes, here's the rates. Obviously, one has to be careful from 1-6PM on Summer weekdays but I think overall it's a great option to consider. 03201901.JPG
  7. jerrymildred
    11,517
    14,171
    Tampa, FL
    Rear visibility:
    Normally, I have the rear headrests down, but my mother-in-law is visiting, so I just leave them both up for convenience. It's a bit of a shame how much of the rear view they block.
    I've heard lots of complaints about the rear window divider. I've decided that with the dip in the middle, it's not as bad as in the regular hatchbacks. Still annoying, but not as annoying. And it still tends to block out the headlights back there except for the pickup trucks that are sporting a pair of 747 landing lights. Fold the headrests and it's actually pretty good viewing back there.
    Oh! And I do like this interior!
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    I thought Prime only came with the gunk.
  9. jerrymildred
    11,517
    14,171
    Tampa, FL
    You thought right. Same with the PiP. I rejected Toyota's reality and substituted my own. I have the same full sized spare now that I had strapped down in the PiP. I just need to finally spring for a donut to gain some much more needed space back there. Having the spare strapped down back there face down provides a perfect place to carry the coiled up EVSE cable.
    Edit to add: Right now, the best fitting place for my for-real 12V compressor is in the storage space inside the rear arm rest. Perfect fit, but I'd like to find a better place and free that back up for passengers ... or for us.
  10. Marine Ray
    1,139
    949
    Sparks, NV
    Agree, that huge dip is a big improvement on rear visibility from the Gen III Prius's.
    Merkey and jerrymildred like this.
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    I drove a while in HV tonight since I was going to be about 2 miles short of making it home on battery. I stayed in HV for about 10 miles. I am impressed that when I made the switch at 55 mph, I heard and felt no change. Also, once it was warmed up, it shut off the engine on level ground with the cruise control set at 60 mph and it stayed that way for at least a minute.
  12. jerrymildred
    11,517
    14,171
    Tampa, FL
    This morning I got a hint of what this car could do if traffic engineers could time lights properly and if it was always spring break. Very little traffic at 6:00 this morning and no stops on the 8 mile 50+mph portion of my 9.5 mile commute. Also none of the typical stop and creep on the part with the 50 mph speed limit.
    Average Miles/kWh were the best ever or nearly so. I think I got a 6.1 one day. That 6.2 showing now will almost certainly go down this evening.
    Miles driven and remaining EV miles add up to 36.8. The guess-o-meter predicted 35.1 when I started.
    #52 jerrymildred, Mar 21, 2019
  13. TinyTim
    TinyTim Active Member
    418
    243
    Seattle
    Well done Jerry, keep up the good work.
  14. jerrymildred
    11,517
    14,171
    Tampa, FL
    Another pleasant improvement from the PiP is the air conditioner efficiency. The PiP A/C would knock almost 10% off the range. This is maybe a couple percent. I need to look more closely once it starts to heat up here. We haven't had hot weather yet, but I still have to run the A/C almost every day. My wife seems to be OK with me leaving it in Eco mode and driver preference. She likes things a little warmer than I do. Anyway, there's much much less impact on EV range!!! It makes me almost eager for our typical "Armpit of North America" weather to return so I can compare them better. But I'll try to be patient. :whistle:
  15. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Today, we'll hit 50°F for the first time since last fall. So, my efficiency isn't anywhere near your level, despite your use of A/C. That's quite impressive.
    #55 john1701a, Mar 21, 2019
  16. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Actually 36.8 and that is even better. ;)
  17. jerrymildred
    11,517
    14,171
    Tampa, FL
    Thanks for catching my brain fart. :D I fixed it.
    Prius from Dad likes this.
  18. jerrymildred
    11,517
    14,171
    Tampa, FL
    IMG_0173 copy.jpg This car is still getting compliments! Several people last night said it looked good. Then this morning, I had it in the front parking area for a while. One of our volunteers came in and said, "You know, that car really looks good." Yup. He stressed the word "really." And I can't find it in myself to disagree with him. Especially when it's in the sun. :D
  19. Prodigyplace
    12,720
    11,852
    Central Virginia
    The Prime has a heat pump for HVAC.
  20. john1701a
    12,840
    5,312
    58
    It's the most efficient in the industry too... a point those touting more expensive plug-ins aren't thrilled about. Prius offering that kind of advantage isn't supposed to happen.
