Jerry's Evolving Thoughts on "new-to-me" Prime Premium
Discussion in 'Prime Main Forum (2017-2022)' started by jerrymildred, Mar 12, 2019.
  1. Trollbait
    12,528
    This what I read about GM's system.
    Amoung the additives in motor oil are antiwear molecules that protect components when metal on metal contact happens. The antiwear molecule gets consumed when that happens. GM studied how quickly a commonly used antiwear compound gets used under various engine conditions; start up, temperatures, engine speed, engine load, etc.
    With that data, they made consumption rate tables that the oil monitor system uses to calculate remaining oil life based on how the car's engine has been running.
    From used oil analysis, the system seems to be pretty accurate.
    Bill Norton and Mendel Leisk like this.
  2. Prodigyplace
    12,552
    11,772
    Central Virginia
    Tractors too.
    jerrymildred and pghyndman like this.
  3. Bill Norton
    Bill Norton Senior Member
    2,152
    734
    MONW, Ks.
    And thus the ability to legally go with 2 year oil change intervals (sometimes) on their defunct PHEV.
    I wonder how other PHEV manufacturers handle the 'Oil Change Interval' issue?
    Toyota is not handling it at all: Prius legacy and Prius Prime -:- Same Same.
  4. Mendel Leisk
    41,411
    Honda says to change oil at least yearly, regardless off what the maintenance minder says. On our previous 06 Civic Hybrid, obviously not a plug-in though.
  5. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    You should at least wait until 1 year or 10,000 miles on the Prime. Toyota care lasts 2 years and you get up to two free oil changes in that time. They are just very aggressive about mailing flyers to remind you.
  6. Trollbait
    12,528
    Toyota has you change oil at 5000 miles instead 10k. Climate is a factor in oil life.
    Then do this once a year is something easy to remember than every other year.
  7. route246
    route246 Member
    97
    49
    SF Bay Area
    2020 Prius Prime
    My weekend driver is a 400HP tuned Focus RS. It has 3000 miles in 3.5 years. I don't drive it that much and it sits in the garage most of the time on a battery tender. The "change oil" light comes on all the time after 1 year without a change. In the past 1.5 years I've driven 700 miles. Oil alone costs US$12.50/quart so oil changes are not cheap. It is out of warranty once I tuned it so I do my own oil changes. I turn off the light myself through the OBD II port using a pro diag console.
    My new Prius Prime is an interesting case. 2 years of "free" maintenance and the ICE is going to get used very little. I'm going to have to force it by using regen mode or something. It just handles local driving and plugging in at $0.11/kwh is so cheap it seems tragic to waste money on California petrol which is so expensive.
  8. Prodigyplace
    12,552
    11,772
    Central Virginia
    That changed for the Gen 3 Prius, I believe. The recommendation is 10K for full synthetic oil. I think they say change at 5K if you use "dino" oil but they recommend AGAINST that..
    jerrymildred likes this.
  9. Trollbait
    12,528
    One of the reasons to change the oil is that some protective additives get used up over time. One is acid neutralizers. Acids form in the oil when water gets in, an that can happen while the car is parked. Then air is getting, and oxidizing the oil.
    But some of this could be for dealers' service departments.
    @Mendel Leisk has a gen3 in Canada. Up there, the change interval is 5000 miles to our 10k.
    Noticed a footnote in the Camry's maintenance schedule that the oil should be changed at 5000 here when experiencing freezing temperatures.
  10. Prodigyplace
    12,552
    11,772
    Central Virginia
    You and I bought from Toyota US. Mendel bought his from a different company in a different country.
    This is a Prius forum. A non-Hybrid Camry is not a valid comparison either. I do not recall that interval mentioned in my 2017 Prius manual.
  11. Mendel Leisk
    41,411
    With fourth gen Toyota Canada's in line with the US 16K kms (10K miles) or yearly. Still, there's nothing stopping owner's shortening the interval, might be overkill, but who knows.
    Tideland Prius likes this.
  12. Tideland Prius
    16,555
    Yup. And there’s always the “severe service interval” for those that routinely drive on dusty roads, or short trips where the engine doesn’t reach operating temperature.
  13. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    I just took mine in for 5000 mile service. Nothing in the correspondence to me mentioned oil change, and the service advisor told me no oil change until 10,000 miles. 5000 mile service was only tire rotation and inspections.
    Prodigyplace likes this.
  14. Trollbait
    12,528
    They are both subsidiaries of Toyota.
    It's there in the Prius schedule. I missed it the first dozen or so times I looked in the maintenance schedule.
    I misremembered what I read. It is a shorter interval for repeated trips of less than five miles in temperatures below 32°F / 0°C, not just the lower temperature.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    First gas purchase in over five months!! We've taken a few short road trips so far this year, but nothing major since last year. Therefore, this last tank set a record for miles and cost per mile. Here are some of the stats since we got back from that big trip in May, 2019. That's not only the most miles, it's the least expensive gas I've ever put in the Prime and the longest predicted DTE since I started tracking it.
    We plan to burn off this tank and a few more in October on a trip to Ohio.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Very impressive;).
    Column I header with "fullup" might need an edit, unless intended:whistle:.
    While electric and fuel rates are higher out here, the Prime is still a great vehicle(y).
  17. jerrymildred
    11,517
    14,151
    Tampa, FL
    Spreadsheet typo fixed. Thanks for catching that, Ray. I've only been looking at it for about 10 months without noticing it. :ROFLMAO:
    Raytheeagle likes this.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    No worries;).
    Attention to detail is something I focus on in daily life:).
    Especially in spreadsheets(y).
    Merkey and jerrymildred like this.
  19. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    OK. I just bought a used front grille sub-assembly parts (OEM parts# 53101-47040/50) with multiple cracks off from 2017 PRIME Advanced. I had planned to PlastiDip paint or wrap the acrylic part of my new 2020 PRIME to prevent a future crack like what happened on my previous 2017 PRIME. But I was hesitating to take off the part and modifying it on a brand new car. Now, I have this spare part to play with, I can try something onto it and even if it doesn't go well, I would not care much.
    The question is what can I do to strengthen the acrylic and protect it from future damages. I am going to first try repairing the cracks using Weldon #3 and some other epoxy-based filler/adhesives, then using PlastDip or Wrap on the acrylic part. The PlastiDip or Wrap should be removable, so if I mess it up, I can re-do it. However, I just don't think either option will give much strength to the acrylic for longlasting protection. Does anyone have any other material that would work on this project? As long as it does not cost too much, I am willing to give a try.
  20. Trollbait
    12,528
    Something like fiberglass behind the acrylic might make it rigid enough to reduce the chance of cracking. Seeing how the FG resin is cleaned with acetone, it might chemically weld to the acrylic. While the FG can give strength to prevent breakage, it won't help prevent surface marring. I don't know if the effort would be worth it to bother getting the supplies needed, but if you already have them...
    Some type of fiber should have been used in the acrylic for this use.
    A wrap may add a little protection, or could avoid damage while hiding a new crack underneath. It will be more protective than PlastiDip.
    #640 Trollbait, Aug 16, 2020
    Salamander_King likes this.
