Jerry's finally going level 2.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jerrymildred, Dec 13, 2017.
  1. Prodigyplace
    12,715
    11,848
    Central Virginia
    If he had it, he wouldn't miss it :confused:.
    jerrymildred and bisco like this.
  2. Mendel Leisk
    42,352
    I took it to mean: if he was trading up, he might opt for a regular fourth gen with spare.
    52,861
    yes, the present tense was lost on me.:whistle:
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Not anymore. But I don't like the idea of a blowout without one. We threw my wife's spare in the back for the trip to Ohio.
    Prodigyplace likes this.
  5. bisco
    52,861
    agreed, i have a donut back there whenever leaving the area.
    jerrymildred and Prodigyplace like this.
  6. jerrymildred
    11,517
    14,167
    Tampa, FL
    Yeah, I'm fine around town. I could always call her and have her bring it. Or, if we're both in the car, I have plenty of friends who'd be happy to give us a lift, especially if we bought them a sandwich. ;)
    Raytheeagle and bisco like this.
  7. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    x2
  8. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Sorry, my bad
    jerrymildred likes this.
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
    The deed is done! Well, it's operational. I still have to get the outlet cover and install it. I'm leaving it open for now so I can make sure nothing gets too warm.
    Charging screen on the Toyota EVSE just before switching back to the new EVSE after a quick test.
    Charging rate on the new EVSE. I forgot to get a picture of the "before" rate, hence the reversal of times on the display. The battery was nearly full by this point, so I'll want to look at it again tonight when it's depleted.
    The new sub panel, powering the water heater and the car charger. Charger was drawing less than 10 amps. Water heater was drawing 18. Panel is fed by a 40 amp breaker and #6 wire, so I think it worked out about right.
    The new EVSE at work.
    That little meter is pretty cool! especially for only $20. Plus it retains the data in a power outage. Only one control button on the meter, though, so it's pretty arcane if you want to change any setting on it. I'll put a cover on the outlet box in a few days. The charger is ramping down now because I have the car on a timer and the battery is getting full sooner than it expected, I guess. The cover plate on the mounting box is kind of ragged. Plastic was easier to cut than steel, but also easier to damage with the Dremel tool.
    The meter reads 0.11A with the EVSE connected to the wall, but not the car. When I unplug the EVSE, it drops to 0.09A. So the meter itself at idle pulls more current than the EVSE at idle. A little disappointing.
    So, far, I'm a happy camper. Now to find out if it makes much difference. Either way, it was fun! :D
  10. Prodigyplace
    12,715
    11,848
    Central Virginia
    Merry Christmas to you, a little early and some assembly required.
  11. jerrymildred
    11,517
    14,167
    Tampa, FL
    And batteries not included. But that's OK; I already have a couple in the car. :)
  12. Prodigyplace
    12,715
    11,848
    Central Virginia
    Here's your helmet.
    Iron Man welding hood - general for sale - by owner
  13. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Had to learn the hard way as i once had a flat...luckily got LCC (equivalent of AA rescue) tow the car to safety for free, turns out that the flat occurred at a high brow area of town and they didn't want to have the state Governor passing by and seeing the car there....haven't gotten a donut yet but will get one soon as i get back to town, ergo have not been driving the PIP much.
    Had an L2 EVSE installed, could not get the thing to work till my Electrician installed (buried) a separate ground cable to the house...ran it through a 50A breaker and all is well now.
    Data Daedalus and jerrymildred like this.
  14. jerrymildred
    11,517
    14,167
    Tampa, FL
    50A Breaker! Wow! That's heavy duty. Hope he used heavy duty wire. I think that calls for #6 (4.11 mm).
    I started an L2 charge this morning and have some comparison numbers with the L1. Not quite what I expected, but still great.
    1. L2 is only pulling 19% more power from the wall (2,333W vs 1880W)
    2. Current is actually less. 9.83A on L2 and 13.72 on L1. I need to look up if it's the car limiting it or the EVSE. I just noticed the difference.
    3. But it is putting 47% more power into the car according to the car's display (1.9kW vs 1.0kW).
    4. And the battery fan was running noticeably louder, which is no surprise at all.
    5. Charging just finished. Not sure exactly when, but it took less than an hour and 20 minutes from a battery that had 1.0 miles of EV showing at the start. WAY faster!!
    Needless to say, I'm pretty stoked about it, even though it will take a long time to pay for itself at current prices. (Pun not intended, but welcomed. ;))
    #34 jerrymildred, Dec 16, 2017
    Data Daedalus and Prodigyplace like this.
  15. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Electrician confirmed it was a 32A breaker, it is quite heavy duty. The EVSE i got is the emotorwerks JuiceBox Pro 40. Like i said, he had to bury a seperate Grounding/Earthing rod for the unit before the EVSE could work. Charges in less than 2 hours
    How do i check the cars display while charging?
  16. bisco
    52,861
    wow, i've never seen that display. i wonder if u/s 2015 have it?
  17. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    The display is from the the mobile phone which is used to monitor the charging from the EVSE. It displays the kilometer, percentage added and some other neat features.
    Data Daedalus, bisco and jerrymildred like this.
  18. jerrymildred
    11,517
    14,167
    Tampa, FL
    Your car might not be the same as my US car, but what I do is, with the car off and the EVSE plugged in & charging, keep my foot off the brake and hit the power button twice.
    I just plugged mine in again with a depleted EV range, but not really dipping into the HV range, and it estimates 1.8 hours to full charge. I don't recall ever checking that on the L1 EVSE. I would think it was about 47% longer, though.
    Data Daedalus likes this.
  19. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Car was shipped from the US....will try this as soon as i get back into town.
  20. jerrymildred
    11,517
    14,167
    Tampa, FL
    Maybe I should have figured that differently. L1 is 47% of L2. It's actually 90% more kW going into the battery on L2 than L1. (additional kw/original kw = 0.9/1.0) DUH! :notworthy:
    OK, I get it. The EVSE is rated at 16A, but the car is limiting the charge rate. Even so, this is nearly twice the L1 charge rate.
    #40 jerrymildred, Dec 16, 2017
    Data Daedalus and bisco like this.
