#JimThePrius Overland Conversion in the making.
Discussion in 'Gen 2 Prius Main Forum' started by Minima Domum, Apr 8, 2020.
  1. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Hello Everyone.
    I've finally decided on a name for this project so I guess its time to introduce it to everyone:
    #JimThePrius started life as a taxi in Melbourne, Australia and came into my possession for the princely sum of $2350 with 415,000km on the clock.
    After stripping some of the parts from my previous Subaru build I began by fitting a light bar, switches to run them, a dash cam, and daytime running lights (with switchback indicators replacing the original front globes)
    Then it was time to drive 8 hours back to my home city of Adelaide.
    And that seems like a logical place to end my first post... Stay tuned for more!
    3rd3rd, offib, Bunce and 7 others like this.
  2. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    After arriving back in Adelaide I needed to take the Prius in for an ID check as it was bought with no registration, unfortunately the light bar didn't pass the inspection as it was too high and the corners were too sharp, luckily they let me unbolt it in the carpark before giving me my registration plates.
    The next stage was to get rid of the horrible yellow/green paint job, I chose a much less garish low sheen grey from the Taubmans Exterior house paint range, including some rollers, tape and sand paper it set me back $100.
    After 2 days of furious sanding and rolling the outside was complete! I still need to do a few edges and the door jams and stuff later on but that can wait.
    And that brings an end to this post... Stay tuned for more!
    offib, SFO, ice9 and 4 others like this.
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    With that mileage on the car, you maybe kinda start planning for a replacement pack, or so, then think about ICE, for future repairs or replacement.
    I like the brightness of the modded lights though.
    Dxta
    offib, Data Daedalus and Minima Domum like this.
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    So did you used that brush you have on there manually painting the body, or you made used of a spray paint machine?
  5. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Yes I used the foam rollers to manually apply, not as good finish as spray paint but much less preparations needed, and gives me the look I wanted. I still need to get some smaller brushes for getting in some tight corners I couldn't reach with the rollers.
    offib and San_Carlos_Jeff like this.
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Wao!!! This is an eye owner to me here. I never thought that brush could even paint it the way you've done. It looks cool. I have the roller type of brush, and the other Ines, but never thought it could be used for cars. I always thought they are for painting apartments.
  7. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    That's a really good looking paint job, especially for using a roller. It looks so smooth. I don't know if the flat paint helps with that, but I like the paint style and color too. Are you thinking of modifying and refitting the light bar?
    Minima Domum likes this.
  8. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    It's not completely smooth like normal spray paint, but has a slight textured finish similar to the walls in your house would have.
    Funny you should mention the lights, that will be my next post!
  9. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Now that the paint is pretty much complete and another interstate trip back to Melbourne was looming I turned my attention back to the lights.
    I bought some new ones in the meantime that are much higher quality than the first set, and was tossing up between making a new bar to mount them on or just modify the existing one when I discovered there's actually enough room between the headlights for both sets!
    I still wasn't convinced on the bar though so I removed the front bumper to see how much room there was without all the plastic in the way, this is when I discovered that the factory aluminium bumper reinforcement bar was the exact right shape and location to hold the lights!
    A couple of bolt holes and some trimming of the plastic grille later and my new lights look right at home
    I still may add the other pair because too many lights is never enough, and I will also swap the factory fog lights for the small LED lights from the old bar which I need to get yellow filters for.
    That's all for today, stay tuned!
    offib, SFO, ice9 and 2 others like this.
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    This light is extremely bright dude! Nice job
    offib, Minima Domum and Data Daedalus like this.
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Could you explain how you powered the LED lights pls? Did you tapped into the existing circuits on the Prius headlights, or you powered the lights differently from a different circuit?
    offib and SFO like this.
  12. Mendel Leisk
    42,364
    Yeah that's what I was thinking, definitely some "orange peel", lol. I like what you've done, and think a textured, sorta satin finish is just fine. (y)
    Shelby profita and Minima Domum like this.
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm impressed, from the very first post and very first pictures with how straight and clean the body looks. For a Taxi service, 11 year old Prius with high miles, it looks incredibly straight. and clean.
    This is a no lose scenario to me. Because I sense through the posts and pictures that it seems you're enjoying this project. Your original buy in was economical, -read cheap, and it seems you're willing and able to do a lot of the work and labor yourself, which keeps further investment in check.
    So, I say carry on. Keep having fun. In the end? You're going to have a unique, only one in the world like it vehicle.
  14. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    I have added new circuits for the daytime running lights and the spotlights.
    The daytime running lights are powered by a spare fuse in the under dash fusebox that is only live when the ignition is "on", they then have a relay triggered by the park light circuit to turn them off when the headlights are turned on, there is also an over ride switch if I want to turn them completely off for some reason.
    The spot lights are powered from the positive 12v battery terminal in the under bonnet fuse box, they then have their own external fuse and a relay which is triggered by the high beam lights so they only come on with high beam. Once again an over ride switch to turn them completely off.
    If/when I add the second pair of spotlights they will be wired the same as the first set, and I will have a separate switch for each depending on driving conditions. The LED fog lights will just be connected straight to the factory wiring.
  15. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Here's some better pictures of the difference the lights make. I will be polishing the factory headlights and upgrading the globes eventually too, just havnt got around to it yet.
    All camera settings locked in "manual" mode, as close to what I see in real life as I could get
    Stock Low beam:
    Stock high beam:
    Livid Hyperdrive mk2:
    And the reason I need these lights:
    3rd3rd, offib, Blurredforlife and 5 others like this.
  16. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I wished I could do these on my Infiniti M45 .
    Were the sport lights Assembly new, or used you got the as a whole, and just did the wiring and setup?
  17. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
  18. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    You can do it on any car with a little bit of time and creativity. I got the lights second hand and did the wiring and setup myself.
    Haha no I removed the logos before paint, I just hadn't refitted them yet in that photo.
  19. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Now that the outside is relatively together il move my attention to the inside, the next few mods were installed at random times during everything else but il put them all together into one post for ease of reading.
    First the switches for the lights, the far left is for the big spotlights, the far right is for the daytime running lights, and the middle 2 are spares for now. You can also see my phone holder peeking out from under the steering wheel, it's just a steel L bracket that sticks to a magnet glued onto the back of my phone.
    The next thing to go in was a switch (in the bottom right corner of the top glove box) that turns the radio on without the key in the ignition, this will be more useful later when I've upgraded to an aftermarket radio without all of the controls on the MFD screen. I also fitted a volt gauge that comes on with the same switch (or the key) this allows me to keep an eye on the 12v battery.
    Moving to the other side of the top glove box I fitted 2 more switches, these are connected to the front speaker wiring and swap it from the factory door speakers to a pair of speak-on plugs that I can plug my external speakers into while camping or at parties.
    There are also some of these plugs replacing the rear door speakers but I forgot to take a photo of that. The external speakers sound great and are quite loud even just running off the factory head unit.
    There will be much more extensive audio upgrades later, but that's all for now.
    offib, SFO and San_Carlos_Jeff like this.
  20. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Next on the list was a towing hitch, but since I live on the wrong side of the world buying one from Amazon wasn't an option, instead I decided to adapt the one from my old Subaru.
    I ended up using the same tow hook bolts that the Curt ones use, and also braced it with the factory bumper reinforcing bar mounts, this puts it a good 6" above the normal ones and means it's completely hidden by the bumper and flat under floor panels for optimal aerodynamics and ground clearance.
    Compared to a Curt Hitch:
    Finished product:
    3rd3rd, PriusCamper, ETC(SS) and 6 others like this.
