JL Audio subwoofer and amplifier installed
Discussion in 'Gen 2 Prius Audio and Electronics' started by don_chuwish, Dec 18, 2009.
  1. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
  2. Grayson73
    Grayson73 Junior Member
    62
    Maryland
    Darn. I want an install without modification and was hoping I could use this. I guess I have to look at the Boss BASS subwoofers.
  3. don_chuwish
    823
    190
    Southern Oregon
    Without the grill on it will just sneak in under the stock floor panel. I'm not sure if there would be clearance issues (enough airflow) while playing music or not. It was a fun DIY project for me and really quite easy to make the replacement floor. But something like the Boss would certainly be simpler.
    - D
  4. drulanier
    drulanier Junior Member
    24
    Louisville, KY
    Don, do you have the exterior measurements of this box? I'm wanting to install an 8w3v3 in the exact same location. Did you use 5/8" or 3/4" MDF? Thanks in advance!
  5. don_chuwish
    823
    190
    Southern Oregon
    Hello,
    I didn't make the box, it's a complete product from JL. I found the page for the current one on their website:
    JL Audio CP108LG-W3v3
    Dimensions are listed in the Specifications tab:
    External Width (W)18.625 in / 473 mm
    External Height (H)11.0 in / 279 mm
    External Depth (D1)5.125 in / 130 mm
    Net Weight17.40 lb / 7.89 kg
    I have to say, even this many years later I'm still quite happy with the sound it produces.
    skorpyo33 likes this.
  6. drulanier
    24
    Louisville, KY
    Don, thanks - so the JL box fit under the cargo cover with only cutting the hole to allow the sub grill to protrude slightly? That is awesome. Much easier than expected. I appreciate your reply!
  7. don_chuwish
    823
    190
    Southern Oregon
    Keep in mind that I replaced the cargo cover with a home made one. I didn't want to cut the original.
  8. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    I'm thinking about using the same location for my 3rd Gen Prius I wasn't able to find anyone who did this even those it's a great use of space.
    I would assume if it wasn't for the custom trunk it would probably rattle? Also, does the gen 2 have a spare tire? I'm wondering how your plastic tray stays in place? If I remember correctly, mine just sits in place without any hardware.
    TIA!
  9. don_chuwish
    823
    190
    Southern Oregon
    Hello,
    I don't think I did anything special to avoid rattling. The only reason for the plywood 'floor' replacement was to allow for the hole the grill fits into. Spare tire is under the plastic tray - a bit of a hassle if I ever have to get to it!
  10. skorpyo33
    skorpyo33 Junior Member
    30
    Sebastian, FL.
    How much rattle in the prius from that 8" cause I wanna get the 10" w jx500 amp.
  11. don_chuwish
    823
    190
    Southern Oregon
    Zero rattle. Just good bass.
