Joined the 2nd Generation today
Discussion in 'Gen 2 Prius Main Forum' started by tada, May 29, 2019.
  1. tada
    tada Member
    73
    77
    Tucson, AZ
    2002 Prius
    95209DC1-3C5C-4FE3-9FED-0C3AABE6C960.jpeg I still own my first generation 2002 Prius and it’s running well with 132,000 miles. But today I was able to pick up a running 2007 with 122,000 miles for $1100.
    The main problems are a totally dead 12v battery, the rear latch is goo and won’t open, the MFD is cracked, but still displays. The digitizer touch screen does not respond. The front windshield needs replacement.
    But it drives, the tires are so, so. The body is clean. The interior is in good shape but needs a thorough cleaning. Has the strong scent of foo foo, or about 20 scents of Febreeze combined.
    All in all, I think it’s a good buy for $1100. With a little investment, I should have a vehicle that will go for many more years.
    #1 tada, May 29, 2019
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Cool! Have fun fixing it up.
    Skibob likes this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Sounds like you can do everything yourself with the exception of the windshield. Best of luck.
    jerrymildred likes this.
    52,594
    congrats, all the best!(y)
  5. psymon100
    psymon100 Junior Member
    Auckland, New Zealand
    seems like a very good buy. any plans to test the main battery with dr prius or similar?
    it looks really tidy from the outside.
  6. tada
    tada Member
    73
    77
    Tucson, AZ
    2002 Prius
    I changed the inverter coolant pump out today. This is why the previous owner sold it. I’ve got the job down to about 30 minutes now. Took it for a long drive. It’s tracking well. It’s going to need new struts and its front suspension tightened up. Now I’m trying to find my mini VCI cable.
    Skibob and jerrymildred like this.
  7. Skibob
    2,912
    1,505
    Northern California
    Struts you say? OEM struts are KYB so you can buy them pretty cheap on Rock Auto. They even have a KYB complete drop in option for the fronts if you don’t want to dissemble yours.
    Data Daedalus likes this.
  8. tada
    tada Member
    73
    77
    Tucson, AZ
    2002 Prius
    That’s the way I’m going. The KYB quick struts. I’ve done a full set of no name struts from eBay on my 02 and they’re not bad, but they could be better. Got a new windshield today, an alignment, and my AC serviced.
    Data Daedalus and Skibob like this.
