joining the club... head gasket specific questions
Discussion in 'Gen 3 Prius Technical Discussion' started by Eddie25, Feb 15, 2024.
  1. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Joined the club this week. 222K, Won't bore you with too many details, but I only experienced about 3-4 instances of running rough and no noticeable coolant loss, so I caught it quick at least. CEL came on as I was pulling into the garage. I have a lot of the prep work already done as I await parts.
    First question:
    How are you all torqueing the crankshaft bolt? I know some people just impact it back on, but I'd like to try to get it torqued correctly.
    Any clever DIY tools? I can fabricate decently, should I just build a Y bar with bolts through it? Anything even easier than that?
  2. JC91006
    16,936
    8,647
    CEL doesn't mean you have a bad head gasket. You might just have some emissions issues. Unless you want to tackle the HG now, you might want to find the reason for the CEL
  3. Mendel Leisk
    42,323
    Yeah, you’ve got to restrain it somehow, or just use impact lol. Funny thing is, it’s just to hold on this beltless pulley.
    have you done boroscope inspection?
    #3 Mendel Leisk, Feb 15, 2024
  4. Eddie25
    503
    213
    MI
    It’s been confirmed with borescope.
  5. Eddie25
    503
    213
    MI
    Anyone know thread pitch for the two crankshaft pulley holes off hand?
  6. Mendel Leisk
    42,323
    M8x1.25, same as the brake rotor threaded holes. They're 86~ mm c/c.
    Mr. F and Eddie25 like this.
  7. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    I used a loaner fan clutch holding tool with two M8-1.25x45 mm socket head cap screws from Home Depot. Grade 12.9 is necessary to resist yielding.
  8. Eddie25
    503
    213
    MI
    Excellent, I will try exactly that. Thanks!
