"Jolting" in Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AZDriverMan, Jul 10, 2012.
  1. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Dealers ALWAYS overfill the prius. They don't understand it is an atkinson engine, or maybe they DO understand and want to gum them up and ruin them. They are criminals in my mind. I wouldn't worry about the brake fluid, it changes a lot based on heat, it's fine overfilled.
    Now you can easily get at the oil drain plug up by the passenger wheel and slowly loosen the drain bolt and drain about 1/2 quart depending on how overfull it is. Then you should pull off the air filter plastic air box and remove the filter and look down with a flashlight into the throttle body to look for black stuff on the throttle valve. (there is a spring on the outside you can turn to open the throttle.)
    Don't touch the sparkplugs. They are iridium and 100k. You can gently drip some alcohol or something on the MAF resistors. They unscrew from little tube that goes down into the throttle. There are many pics and threads on here.
  2. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    Wow, that's awful. If Toyota wants to have a good reputation for good cars, they should really do these things right.....I will definitely check those things, and drain the oil as necessary. I am going to have my mechanic take a good look to see if he sees anything wrong. If it might be the transaxle, then the Dealer should cover it because I have a warranty (even though they usually have to "check" to see if it is covered under the "bumper-to-bumper" warranty). If they don't hold up on their warranty and there is an issue, I am going to complain to Toyota.
    The main reason I thought the dealer would be good for the maintenance intervals was because they can check all the hybrid components also.
  3. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    If you have a warranty still, don't touch anything.. Take it to them and tell them
    " I was in park today, and for the second time in a week, the car started shaking really badly when the ICE was on"
    And hopefully the parking jolt is reproducible. There is something wrong in the transaxle, which may also be why it shakes with ICE on.
  4. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    The jolt should be reproducible. The shaking not so much. The shaking happened kind of randomly. The jolt should work as long as the ICE is on.
    I also have a strange squeaking noise, although they claim it is the brakes. It never did it before a certain point, but now my brakes squeak a lot. Also, they squeak louder in reverse. That's kind of a side note.
    The only problem I have with taking it to the dealership is that the hybrid technician acts like I am just really clueless with the Prius. He always tells me that codes will always come on if something is wrong. I am considering taking it to another Dealer, but I could probably just demonstrate it to the same dealer.
  5. Mendel Leisk
    42,254
    The 2 dots on the engine oil dipstick represent low and full. How much is it "above that second dot"? Something like a 1/4" is no big deal, just a frustration. I think most dealerships do overfill, some slightly, some a lot. A little is maybe that 1/4". Their mentality (I think) is "better too much than not enough".
  6. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    Ok, I think it's about 1/4" above that line. So then that should be okay. That probably would not be the reason for these other issues, then, I assume.
  7. bisco
    52,772
    that's the cheapest i've heard of. my oil is always overfilled, never had a problem with jolting. get it in there and let us know the diagnosis. i don't think we're gonna fix it here.:cool:
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    An oil overfill could explain the "shaking". That sounds like misfire. Clean the throttle body. It is easy and there are many posts here detailing the procedure.
    The hybrid tech was correct in that you won't get any free warranty work done in the absence of a trouble code. So, so many stories of people who had the engine water pump be diagnosed as bad at the first service after 60,000 miles.
  9. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    I would maybe speak to the right person like a service manager or toyota total whatever care. The shaking in park is an indication or something. I guess they would just rather replace the whole transaxle when it finally comes apart rather than diagnose what is wrong now without any codes. Just make sure you kill this thing before your warranty runs out. You should still drain out oil if want the ICE to run well. It only takes 5 mins and you don't have to lift up the car even.
    I'm guessing if you mention you park around small children and your wife was walking in front of the car when you park in the garage and it lurches when you step off the brake and it is unacceptible they don't look into it, they will deal with it. Nothing like a possible NHTSA report to make them look into it.
  10. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    Thanks for the input!
    I am confused, though. Because this same hybrid technician diagnosed I needed a new brake actuator around about 65,000 miles. There were no codes and I actually was coming in for another issue.....but there were really no codes. It had some kind of a bad squeak when touching the brakes which I hadn't even noticed. The brakes do squeak now, although he said they are totally fine (mainly squeaks in reverse but occasionally squeaks other times).
    Yet the brake actuator was placed without "codes" at all. I find this really confusing.
    The shaking that happened twice was not just a bucking (just so you know). It was relentlessly shaking until the ICE shut off. Then it stopped and didn't do it after that point (both times). Is there anything else to worry about with a misfire? I will definitely get the throttle body cleaned.
    I guess I just disagree with the principle they have behind the trouble "code." If they cannot fix a car without a trouble code, it makes it sound like they either don't know what they are doing (yet the techs are trained for this, so they probably know), or that they are trying to avoid warranty work. Toyota should stand behind their cars, so I think that they should not rely solely on trouble codes.
    Here is an example, although it is a different car company (and also a car likely not as reliable as the Prius). I had a Nissan Maxima, and after about 15 minutes of driving, I felt the transmission slipping. The car was jerking really bad as you slowed down, sped up, and shifted from park to drive to reverse and vice versa. That car never had any trouble codes or check engine light or anything, and it obviously had an issue.
    It just seems like for some reason that cars may not always shoot trouble codes for the engine misfires/problems.
  11. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    Haha. Ok, good observation. I don't really have that excuse though. I am not married yet. Otherwise I could mention "My wife..."
    Do you think that is why it is not running any codes? Maybe only one part of the transaxle is "breaking"? I think it is called MG2 (which one is the Gas Engine transaxle part again?) Why wouldn't they want to fix the part that might be bad now? To cost them $500 now sounds more logical then costing them $5,000 later.
  12. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Because odds are it will last until about a month or two after your warranty expires. They don't know about your details. Maybe you visit your family a lot and you parked the car and your mother walked in front of it in the garage and it jolted and it is unacceptable. Sure it didn't move but felt like it could and if there is a NHTSA issue they might get a black eye over they might look into it. It's a safety thing if it isn't chewing up your transaxle.
  13. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    Ok, I will definitely look into it. I am going to make sure I can demonstrate it (when it sometimes does not do the jolting it is annoying). For some reason when I go to the repair man the issue does not come up as often...haha....figures. It has been doing it pretty often. I have to make sure it does it, and hopefully they can be of help. That is a really good call with the safety issue.
  14. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    If you make up (probably could be real story) a story about going to the grocery store and parking the car and some kid was passing between cars when it jolted... They will probably keep it overnight.
  15. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    That sounds good. I will look into that. I hope it is not the transaxle. I suppose it is not a big deal if it is...because I have a warranty. I am just shocked though that the transaxle in the Prius could fail at this low of miles. How long does the transaxle in Generation 1 or 2 Prii (or Priuses?) last? How common is transaxle failure in Prii?
  16. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    Although I think that would make sense, as it runs rough when gasoline engine is on. So one part of the transaxle could be having the issues. Which, like you said, could explain the shaking also.
  17. AZDriverMan
    AZDriverMan Member
    102
    Chandler/Phoenix
    Sorry I didn't write back before. I took it to my mechanic, and he didn't think anything of the "jolting." However, I am not sure how much he knows about the hybrid engine. It was the gasoline engine. It just seemed a lot different than I have felt before, so I am probably going to take it to Toyota soon. He called it engine "torque," although I am pretty sure the torque was not that strong before, as to create a "jolting" movement.
    No warning lights have appeared on the dash (aside from a low tire pressure indicator which was better when I refilled the tire). Other than that, no lights on the dash. A couple of times, I have been surprised that the occasional "misfires" of the engine have not set any codes. Other than those things, all is good. Will let you know if I get any updates.
