Jump-Start DC Power Plus
Discussion in 'Gen 2 Prius Audio and Electronics' started by zenMachine, Sep 5, 2007.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Does anyone have this unit? Do you think it's a good device to keep in the Prius?
    [attachmentid=11176]
    Jump-Start charges a car battery in minutes and powers a laptop, cell phone and more.
    $39.95
    * Charges a car battery in minutes without jumper cables.
    * Portable power source for cell phones, laptops, camcorders, and other devices.
    * A super-bright LED flashlight is built in.
    * Charges in a dashboard DC power socket or any AC outlet with the included adapters.
    http://www.sharperimage.com/us/en/catalog/product/sku__AU400
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    You'd need to modify the power socket to be 'always on' since there is no 'connection' to the battery when the car is off.
  3. beboyle
    beboyle Junior Member
    39
    Phoenix
    <div class='quotetop'>QUOTE(zenMachine @ Sep 5 2007, 03:31 PM) [snapback]507539[/snapback]</div>
    Yes, but - it will only work to charge your battery if you have modified one of your 12-volt accessory outlets to be always on, as described at http://www.coastaletech.com/power_outlet_mod.htm. The standard Prius disconnects the accessory outlets when you turn off the power. Unfortunately, there must already be enough power for the computer to boot before it is able to reconnect the accessory outlets, so just plugging in the charger and turning on the ignition as described in this product's manual won't work.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(Bruce Boyle @ Sep 5 2007, 07:02 PM) [snapback]507564[/snapback]</div>
    Or you can make a small set of jumper cables to allow a direct jump to the posts under the hood.
    Tom
  5. zenMachine
    3,355
    300
    Thanks for all the feedback.
    I've been thinking about adding an Always-On 12V socket to my trunk for sometime. This jumper thingy may just be the incentive I need.
  6. anu73
    anu73 New Member
