Jump-Starting the Prius C
Discussion in 'Prius c Main Forum' started by SuperABM, Jan 11, 2013.
  1. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I put a jump start pack in each car, so I can help without risking $4000 in damage.
  2. jimnjo
    jimnjo Member
    117
    2015 Prius c
  3. MichaelJai
    MichaelJai Junior Member
    toronto
    2017 Prius c
    Not sure what is wrong with jump starting another car with your Prius. Simply hook up the dead battery first and black to inverter metal casing and red to the terminal in your fuse box. Make sure 2 cables will not come in contact of each other.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Prius 12 volt battery is tiny compared to 'real' car batteries. The 'real' battery may demand far more than your Prius is able to supply. You want to ruin something far cheaper than your Prius. (Done wrong, it can be a $1000 repair for a new inverter DC to DC converter. And towing.)
    #24 JimboPalmer, Dec 1, 2017
  5. Mendel Leisk
    42,253
    Yeah, you might be ok. Or not. Especially if the other vehicle is pretty sizable. I always carry a jump pack too, would not volunteer to jumpstart, let someone with a larger vehicle or truck step in.
  6. Castanea
    Castanea Member
    39
    27
    Iowa
    I've just moved all of my stuff from my old car to my new-to-me Prius C. The jumper cables... I have always carried them, and used them from time to time mostly to jumpstart other people's cars. This thread is making me think I might do well to give the jumper cables to Goodwill to remove temptation.
    I had an object lesson about a month ago with my old car; I jump-started someone, carefully connecting the cables as one should. His car started. Without giving me a chance to stop him (I was still in my driver's seat), he removed both cables from his battery and ground, and accidentally touched them, making a nice big spark. There goes a lot of money if it had been my Prius. Even if I know what to do, how can one stop others who are not so careful from screwing things up?
    So... are there any reasons that I should keep carrying the jumper cables? Or am I prudent to ditch them?
  7. bisco
    52,769
    what if you need a jump? does the '13 c have jump points under the hood?
  8. Mendel Leisk
    42,253
    Maybe get yourself a jump pack, then you're ready to help others or yourself. Does the c have an under-the-hatch-floor tray? Handy location to store it.
  9. Castanea
    Castanea Member
    39
    27
    Iowa
    Thanks for these suggestions. I think that I will get a jump pack, maybe the little one that jimnjo mentioned above. With the Prius C, I am finding that "small is beautiful" in terms of stuff that one is going to routinely carry around in the vehicle.
  10. Mendel Leisk
    42,253
    Whatever you do, don't google JNC660...
  11. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Depends on the '13. Jan/Feb didn't. March was a crap shoot for the 13.
