Jumping 12V Battery direct from Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chodronish, Jul 11, 2020.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No sorry, it doesn't "mean" that at all.
    It MEANS that you should not connect a charging source that will force more than 4.2 amps into it.
    As a practical matter, and if you can see the charging current on a meter, most any smart, automatic charger should be OK.......because it won't come anywhere near it's max. current capacity unless the battery is completely DEAD with some shorted cells.
    Of course, if you won't have a meter to look at (usually ON the charger), the safe thing to do is get a charger with a capacity no higher than about 5 amps.
  2. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I have actual experience using a 6 A rated charger (mode). Charger said complete, disconnect and immediately reconnect, started charging again/not fully charged. I could repeat this ad infinitum but kinda got tiring after a while. (Schumacher XC75W-CA if it matters). Switched to below 4.2 A spec charger, and it charged fully, disconnect and immediately reconnect, still full...
    moto g(7) power ?
    #22 jzchen, Jul 12, 2020
  3. sam spade 2
    7,035
    2,804
    2017 Prius c
    That experience you had with one specific charger means nothing as far as the advice from Toyota about charging rate.
    In neither case did you KNOW what the charging rate actually was.
    One more time: The max. rated charging capacity of a charger means virtually NOTHING in most normal circumstances because the charging current usually will not come anywhere near the max. capacity.
    As a matter of fact, a really LOT of automatic chargers will do what you observed and it is not necessarily a problem.
    The subsequent charging should only last a few minutes......as the charger makes SURE that it really is full.
  4. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    Knowing little to nothing about all of this, I have gathered that it is adequate (and safer? - I don't know) for me to get a charger from 1.5-4 amps, probably on the higher end to charge a dead battery rather than just maintain a battery. I have a gift of making things harder than they need to be.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Since it's dead yes 4 amps is preferred. Don't know of a 4.2 amp or 4.1 amp charger. It would take longer otherwise...
    moto g(7) power ?
    Chodronish likes this.
  6. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    jzchen likes this.
  7. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    Was gonna get the Costco 4V one, but Costco is more of a drive and a production to go into. Thanks to everyone for the advice! I really appreciate it!
  8. bisco
    52,855
    looks like a good unit
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    Others share that tendency.......a LOT of others. :)
    Just be sure it is an automatic battery maintainer......and NOT a cheap trickle charger.
    I've had good luck with Schumacher's.
    Go for it.
    cyberpriusII and Chodronish like this.
  10. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I'm so sorry I did not see this question until now. I was busy trying to warn against possible issues with a charger rated above 4.2 A that I have. I know you're planning on getting the Schumacher unit and I've selected "Like" as approval. The Duracell unit does not mention "smart" but does explain features of smart chargers, one being it will not overcharge if left connected for extended periods. Anyone considering it I do believe it is a smart charger.
    moto g(7) power ?
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    And....do you now understand that a charger will almost NEVER actually supply the full rated current ?
    And that recommendation is for actual current.......and NOT the max. capacity of the charger ??
  12. Mendel Leisk
    42,345
    Sam do you seriously think when the Owner's Manual stipulates a max charging rate that's the intended message? If you just take the amperage mentioned in the Owner's Manual as the charger rating, you'll have a charger that'll work fine, get the job done. Maybe doubly safe, if your take holds water, but what does it matter?
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes. Because that is what it SAYS.
    It does NOT say "Do not use a charger with a capacity of more than XX amps."
    It just doesn't.
    And what else it doesn't say is "for an extended time".
    Using a smart 10 amp charger, for instance, that provides 6 or 7 amps for the first minute or so is perfectly fine IF it drops down to around 4 for the remainder of the charging time.
    I think that a max. capacity of 6 amps is probably ideal.
    That has the potential to give it a little extra if the battery is REALLY low, without having the capacity to hit it REALLY hard.
  14. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    "Never add water nor charge quickly." The first line.
    Sam, you're making a determination here that can affect someone buying a charger for the first time.
    For me, I have 8 cars on various brands, models, even versions of chargers/maintainers. I have this battery on a 1.5 A Schumacher, and a NOCO G7200 sitting on the sidelines. I follow your advice and I get the results that I posted. I have a charger that effectively does not fully charge my battery in the lowest setting. No biggie for me, I swap out one for a different one.
    Looks like the OP doesn't have a charger to begin with. Why do you go through all this trouble to make a point when the goal is a successful charge for the OP? JPEG_20200713_081137_1594182004117440757.jpg JPEG_20200713_082047_6073103284925423753.jpg
    moto g(7) power ?
  15. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    The only way to guarantee you won't ever charge at a rate above 4.2 A is to use a charger rated 4.2A or below. Even just using the 4 A Duracell I saw a little discharge from the vent one time from this battery, hence why I set it away from the wood. (Probably should put a tray now that I think about it).
    moto g(7) power ?
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Because of exactly what you posted your very self.
    It is a "biggie" for most people.
    And the truth is the truth.
    Buying a charger with a slightly higher capacity does NOT necessarily mean that it will charge significantly faster in an identical situation.
    A 4 amp smart charger is a much better choice for a person who will only have ONE......than a 1.5 one or a .75 one.
    And a 6 amp SMART charger is a better choice too........because it will not force 6 amps into a battery that doesn't need it.
    It just won't.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    While that is true, it is NOT that critical.
    Really it isn't.
  18. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    Sadly, but not surprising I guess, I got the reading, "Charging aborted - bad battery." So now....I have to figure out how to get a new 12V into the 2008 Prius without blowing myself or anything up. Perhaps have someone from Midas where I get my oil changed come do it if they will?
  19. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    The 12 V system is separate from the one that could really hurt you. Besides pulling all the stuff out of the trunk to get to it, there is no difference. I can find the torque specs if you will use a torque wrench.
    moto g(7) power ?
  20. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Love the "others share" comment.! Would I be in there....hopefully not. :whistle::whistle::whistle::whistle:
    kris
