Jumping 2013 prius from 2013 camry hybrid - burning smell
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NWDiedrich, Feb 18, 2022.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,135
    6,298
    Texas Hill Country
    Toyota recommends the 5 minutes to equalize a significantly discharged Prius battery prior to a start attempt. Sometimes the discharged battery will drag the typically small diameter jumper cable voltage down and may make a quick first attempt fail.
    jerrymildred likes this.
  2. NWDiedrich
    NWDiedrich Junior Member
    32
    Grand Rapids, Michigan
    Then for step 5 right after that instead of following the instructions I disconnected the cables before starting the prius based on some info I read elsewhere that this may be a safer option. The Prius did start right up but it may be that doing it that way may reduce the chances of a successful start. I don't know for sure.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Deleted. Concern not valid....
    #23 jzchen, Feb 19, 2022
  4. rjparker
    10,135
    6,298
    Texas Hill Country
    It is possible. A large 75 amp dc arc at the point of disconnect can create a more sustained arc than ac. Partially because there is no zero crossing to extinguish the arc quickly. That arc could be what the OP detected. If so, no problem.
    #24 rjparker, Feb 19, 2022
    NWDiedrich likes this.
