Just bought 2nd gen Prius with 175K. Thinking about doing major maintenance
Discussion in 'Gen 2 Prius Main Forum' started by Brando714, Jun 2, 2020.
  1. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    Ok thanks for the heads up. So before over assuming to do my oil in 5k miles after putting in full synthetic, I will test it after about 1k mile and see of the same amount s still there. Would it really be a huge problem if I add more than the recommended oil? Like if I didn't check the dipstick and instead put half a qt every month
  2. Patrick Wong
    18,210
    6,510
    Yes, it would be a significant problem. Check the dipstick, then decide whether oil is needed. An excess oil level can cause a crankshaft seal oil leak.
    Kaptainkid1 likes this.
  3. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    ok thank you. I just did my oil change about 50 miles ago so I would check it in about a month
  4. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    Did you every find out how much your Prius was burning oil?
    SM-J737T1 ?
