Just bought a 2008. What maintenance should I perform?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hertigg, Nov 5, 2016.
  1. Hertigg
    Hertigg New Member
    Phoenix
    I just bought a 2008 Prius with 103,000 miles on it. I plan on replacing air filter, cabin filter, doing drain and fills on oil, transmission fluid and coolant. What else would be optimal? Thanks!
  2. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Welcome to the forum. Go to Toyota's site and make sure your car is up to date on the recalls. It may be worthwhile doing a Carfax check if you haven't already.
    Include both engine and transaxle/inverter coolant.
    If brake fluid is darker than honey, it's time for a flush.
    Throttle body and MAF sensor may need cleaning. Do a search here for that.
    Keep an eye on the engine water pump, if it hasn't been replaced yet.
    One of the more important things you can do is to keep a close eye on the engine oil level. They start burning oil before they reach 150K miles, typically.
    If the car is from the Phoenix area, the hybrid battery may be stressed from heat. If you're a hobbyist/DIYer, considered getting the MiniVCI working on an old laptop so you can easily monitor battery block voltages and resistances. Listen for the battery cooling fan (vent in the back seat), if that starts running frequently it's a sign.
    Enjoy the car. Except for the heat and battery thing, Phoenix is a great place for a Prius.
  3. Patrick Wong
    18,199
    6,464
    Replace the serpentine drive belt now. Look at the engine coolant pump pulley. If you see pinkish deposits from leaking antifreeze, on the pulley interior and/or on the AC compressor housing, replace the pump.
    Check the condition of the front struts and rear shocks. If you see fluid leaks, definitely replace them. However the lack of a fluid leak is not proof the struts/shocks are in good condition.
    Replace the iridium spark plugs and PCV valve at 120K miles, if not sooner.
    I have 225K miles logged on the 2004, which still has the original equipment traction battery. I agree though, that hot weather doesn't help the battery's longevity.
  4. srellim234
    srellim234 Senior Member
    1,193
    1,681
    Laughlin, Nevada
    Unless you know the owner was a DIY person it might be worthwhile to get a CarFax on the car and see if there are good maintenance records through shops that report their repairs and maintenance. You might find some of the things above were already done (as we were lucky enough to find out with our 2008 purchased at a mileage similar to yours).
  5. Hertigg
    Hertigg New Member
    Phoenix
    Thank you so much for the tips! I am excited to be a Prius owner and want to make sure I take care of it so it will last a long time.
  6. Hertigg
    Hertigg New Member
    Phoenix
    Is the VCI necessary, or would any OBD2 reader work? I have a bluetooth OBD2 reader already.
  7. Patrick Wong
    18,199
    6,464
    A generic OBD code reader will not pick up all DTC logged by the various Prius ECUs. Mini VCI is your best bet as it is the clone of the software used by Toyota dealer techs.
  8. andrewclaus
    993
    324
    Golden, CO
    What Patrick said, not only for diagnostics but also for testing, monitoring, maintenance, and even customizing. It's not the most robust tool, but it usually works pretty well, considering the $20 +/- cost, plus an old laptop.
  9. Hertigg
    Hertigg New Member
    Phoenix
    Thanks. Is there a guide on here somewhere on how to use the minivci?
  10. andrewclaus
    993
    324
    Golden, CO
    Hah! Good question. I haven't found anything. You don't get that for $20. I found a couple of tutorials on YouTube, minimally helpful.
    You might need a few computer smarts to unzip some files and get things loaded. Then it's pretty much menu-driven, probably mainly for associates degree level techs.
  11. Hertigg
    Hertigg New Member
    Phoenix
    I am fairly handy with computers, and I can do basic car repairs. Things like changing fluids, belts, brakes. I am definitely not an expert. Not sure if I will be able to decipher the mini vci, but it is only 20 dollars so I will give it a shot.
