Just bought a Prius have many questions
Discussion in 'Gen 2 Prius Main Forum' started by Tboy160, May 30, 2018.
  1. Tboy160
    Tboy160 Junior Member
    27
    Flint, MI
    2008 Prius 220,000 on it. Remarkable how many I drove with over 200,000 and they all felt solid.
    1 - Car only came with one fob, it isn't the proximity fob, but whats the least expensive route to acquiring a spare?
    2 - I have driven about 4000 miles and I have yet to be able to fill more than 8 gallons, tank claims 11.9 gallons, the one time I even had the last pip blinking.
    3 - My Prius doesn't have an aux input, vaguely looked into installing one, but curious if a new head unit would be a better option? Are there any that would still allow use of steering wheel buttons? Any other issues? If the aux input option is best, is there a part number of the best one? Mine is CD player, not changer and no Satellite radio.
    4 - I want to install the EV switch, would like to know what the most recommended one is? and where to purchase?
    5 - I would like to see more information while driving, temps, rpms, other various stats, any good way to display those?
    6 - Any conclusions on what the best tires are? Also the best snow tires?
    7 - Any specific locations where rust usually starts? So as to keep my eye out?
    Best tank was 333 miles at 6.2 gallons. Average over 4000 miles is 48.6 I am still learning.
    Thanks in advance for any help provided. Love this car so far!!
    VFerdman likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I don't understand what you mean by it's not the proximity fob. Is this a 2008 that doesn't have SKS? or is the SKS button just deactivated? or is the battery in the fob dead? Every gen 2 I've owned, I've been lucky enough to get both original fobs. They've always been SKS models and both fobs worked normally for proximity.
    My 2007 has the standard CD player with an aux input plug inside the center console near the bottom, by the power port. Have you looked there?
    SFO likes this.
  3. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    Welcome. I am also a relatively new Prius owner with a 2007 purchased last July with 175K miles. It now has almost 191K and so far no problems. My average since I bought it is in my signature. Summer is much better for fuel economy than winter. There are many reasons that you can find in numerous fuel economy threads on this site.
    1. Not sure, but I think there is a way to get an aftermarket fob and program it as long as you have the one that works.
    2. You do have an 11.9 gallon tank and those pips in the fuel gauge are not very accurate. In most cases you can drive with a blinking pip for a looong time. I usually reset my consumption screen at fuel up and then towards the end of the tank I can have a pretty good idea of my remaining range. I do it the following way to be very conservative in my estimate and avoid running out of gas. I subtract about 4 or 5 mpg from my average for that tank (that is why I reset the meter after filling up) and use the result to multiply by 10 (gallons). That is my current tank's range very conservatively estimated. So if my consumtion average reads 45mpg. I take (45-5)=40 and multiply that by 10 and I get 400 miles. This leaves about 1.9 gallons as a reserve and also discounts the usually optimistic consumption screen reading. So if I have 400 mile range and my trip odometer for that tank (which also gets reset when you reset the consumption screen) reads 295, I really don't need to pay attention to the blinking pip on the gas gauge and I know I can comfortably drive for another 100 miles or so before looking to gas up. Even with this strategy I have not filled the tank any more than with 9.5 gallons. I just don't push it as I really do not like running out of gas.
    3. I have seen videos of aux input being added to a Prius using some gadget or other. Look on YouTube, you'll probably find it. It involves taking the dash apart, which is not as difficult as it sounds.
    4. I have no idea about the EV switch and frankly, from what I have read and understood, it's not all that useful except in very special circumstances. Most of the time it can do more harm than good.
    5. You can buy a $20 OBDII bluetooth dongle from Amazon and connect it to your smartphone and see all kinds of info. The app and dongle will run under $40.
    6. No idea here.
    7. No idea here either. Following.
    Tboy160 likes this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There is a flexible bladder inside the 11.9 gallon tank. It flexes less in the winter and more in the summer. But the tank is anywhere between 6 and 10 gallons, depending on outside temps. As such, you cannot trust the gauge, do NOT drive on the blinking last pip.
    I do not recommend ever using it. At best, use it to move the car around a parking lot. Ev (Electric Vehicle) Mode switch for Prius 2004 - 2009
    www.amazon.com/ScanGauge-Automotive-Computer-Customizable-Real-Time/dp/B000AAMY86/
    There are Android software apps as well. Torque Pro (OBD 2 & Car) - Apps on Google Play
    Tboy160 likes this.
  5. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Add me to the list. I added it despite all the warnings, used it twice, and never touched it again. Literally the only time it has value is if you are moving your car <100 yards, and who does that very often?
  6. Tboy160
    27
    Flint, MI
    I thought the SKS was keyless start, and had buttons on the handles? My key goes into the slot in the dash and there are no lock buttons on my door handles.
    There is not an aux port in the center console.
  7. Tboy160
    27
    Flint, MI
    2. So many people claim once that pip was blinking, fill up! I havent pushed it.
    3. I may just install an entire new radio, seems prices on adding the aux port are higher than I wanted.
    4. there are plenty of times I want to move the vehicle at the jobsite, in my driveway etc. I dont need the engine to come on and run for 10 seconds needlessly.
    5. Other people used the scangauge, but I may check out this bluetooth dongle you mentioned.
  8. egg_salad
    545
    426
    Las Vegas, NV
    I sit on the fence with the same question. For under $100, I can install a simple, yet modern radio that adds a lot more features than just an AUX port. I'm just not sure I will like the aesthetics.
    Tboy160 likes this.
  9. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Tboy160, I have an aux port and wire harness from a wrecked 2007. Found it while cleaning out the garage over the weekend. If you'd like, I can post a photo of it this evening so you can see what it looks like. Maybe there's already a cutout inside the console or maybe the wire harness is there under the carpet or something. I'd be happy to send it to you if you think you could use it. It's OEM, so it's only the aux port and harness/plug, no USB or anything like that.
    Tboy160, SFO and Raytheeagle like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Here's a link to the plans I used to install an EV button on my old '05. As you have already heard, its only real value is if you just want to move the car a few feet and don't want to start the engine. And it's very good for that. But it is a quite a bit of work. Also, note that you'll want a push button that won't bounce because it's easy to double-push the button and turn EV back off before you get your finger off the button. I didn't have the right kind of button and did sometimes experience that.
    http://www.calcars.org/prius-evbutton-install.pdf
    Tboy160 likes this.
  11. Tboy160
    27
    Flint, MI
    Very gracious offer, but I think I am set on a new head unit. Much appreciated!
  12. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    The aux port is not inside the center armrest next to the 2nd 12v adapter plug? That should be the case for 2006 and newer.
    EV mode happens automatically when you barely press on the gas pedal. A switch might cause you to run down your battery lower than normal reducing its expected life.
    Torque app can display engine info.
    Tboy160 likes this.
  13. jerrymildred
    11,517
    14,167
    Tampa, FL
    Only after the engine is warmed up. That's the whole point. As per post #5 and #10, it's just for moving short distances WITHOUT turning on the engine. If you want to move the car, putting it in ready will always start the engine after about 7 seconds. EV button protects the engine from the effects of a cold shutdown and eliminates the need to either shut it down cold or wait for it to warm up just to pull it out of the garage and wash it or something.
    For normal driving, EV is not only a bad idea, it's really hard to do. Anything more than the barest nudge on a Gen 2 throttle will fire up the ICE. And then there's the speed limitation.
    EV button is harmless, but also of very limited utility. But, when I wanted the one I installed in my '05, it was very handy.
    Tboy160 likes this.
