Just bought an 04 Prius
Discussion in 'Newbie Forum' started by stevemcl, Jan 2, 2016.
  1. stevemcl
    stevemcl Junior Member
    Ohio
    Bought it 3 days ago.It has 233,000 miles.Had some exhaust work done today for $50,hopefully that is what triggered the check engine light.My neighbor is bringing his scanner over to check the codes.Im happy with it so far.
  2. xx17p
    xx17p New Member
    Nashville, Iowa
    2002 Prius
    I am considering the purchase of a 2004 with 120K for approximately $5K. Did you use KBB or Edmunds to estimate the value? This would be a private sale. With 233K miles did you take it for an inspection?
  3. stevemcl
    Ohio
    Yes I looked at KBB.I got the car for $2750 plus all the fees it was $3300 out the door.I didn't take it for inspection,probably should have.Midas does inspections for $30.I looked underneath while getting an exhaust repair estimate.I drove it for about an hour and everything seemed ok.The Check engine light didn't come on until a couple days later.The passenger side headlight is out of adjustment and the adjuster doesn't work.May just buy an aftermarket assembly.
  4. JC91006
    16,933
    8,643
    You most likely need a catalytic converter
  5. bisco
    52,780
    welcome! the '04 is a beast and should serve you well. all the best!(y)
  6. stevemcl
    Ohio
    Why do you say that?
  7. JC91006
    16,933
    8,643
    The check engine light is emissions related, that's usually that part that fails with high miles. What exhaust work did you do?
  8. stevemcl
    Ohio
    Had the pipe that goes to the muffler replaced.
  9. JC91006
    16,933
    8,643
    if you read the stored DTC's on the car, it'll tell you if the check engine light was related to the catalytic converter or not.
  10. stevemcl
    Ohio
    The code reader did not work for some reason.Just came up as error.I disconnected the battery for 5 mins and CEL went off.Drove it about 15 miles and it stayed off.
  11. Peneloprius
    Peneloprius Junior Member
    parkville, md
    Yes the 04 Prius was motor trend car of the year that year
  12. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Yeah well, the AMC Pacer was also a Motor Trend car of the year. I agree that the 04 was well built, but never trust the Moto Trend...
  13. pnyglfr
    pnyglfr Junior Member
    My check engine light came on and it was the cat. Got a replacement for $300.
    iPad ?
