Just bought my first Prius and have MPG question
Discussion in 'Gen 3 Prius Fuel Economy' started by Rachael71, Jun 6, 2016.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Yes, but you need a passport. My family does not have them. However I do for business. It would have shaved off 1 hour minus the border delays.
  2. bwilson4web
    16,202
    Many Interstates have mile-markers. Compare your trip meter distance to the mile markers over say 50-100 miles and you'll get a clue as to what causes the error.
    Bay Stater likes this.
  3. Bay Stater
    534
    771
    Central Mass
    I will try the mileage comparison on the return trip this Sunday. It would be good to know.
  4. Bay Stater
    534
    771
    Central Mass
    The second tank calculated out to be 44.7 MPG. A little bit lower than expected. Could be the different gas stations factor.
  5. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    It's fine to do that to check the accuracy of your car's odometer. However, it will do very little or nothing to explain the discrepancy between the indicated mpg shown on the display and actual mpg figured from amounts actually put into the tank.
  6. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    So, I took my trip to Chicago this weekend, actually I was driving to Grayslake which is 230 miles from Iowa City avoiding the toll roads. I drove in power mode because so far I like that better on the highway- I'm fine in Eco mode in town. On the drive there, I gunned it all over the place, passing people, going 80 mph in many places, A/C was running, though I set it to 78 because I don't need it super cold. I was in a rush to get to my sister's in time to go pick up my other sister from the airport. I thought surely my car would manage 40 mpg at best. I got 52 mpg per the computer- When I went to fill my car for the drive home ( it went nowhere until today, we drove my sister's car) When I went to fill up, it took only 4.7 gallons gas- So I calculated about 49 real mpg for the trip. So, on my trip home I took it much easier. I did still go in power mode. I only passed one car on a two lane highway this time. I went average of 75 mph and went slower and slower as I got closer to home. I got to the grocery store at my house and my car read out 53 mpg for the trip. Then.. this part is fun. I drove the last jaunt from store to my house, coasting down hills but still went up 2 small hills to get to my house ( in eco mode) and i got 99 mpg! wow. I guess my battery is fine. :) One thing I did notice though is that my car's alignment is off, wanting to pull to the right. I'm hoping the dealership will fix this for me as part of their 3K, 3 month warranty- I had suspected it prior but really noticed it on this trip. I mentioned it to the dealer and they said if it wasn't too bad they would do it free of charge.
  7. bisco
    51,895
    well done!(y)
    Rachael71 likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I drive a Prius TOOO...to two...II...double snake eyes...conjoined twins..model. And I don't care how Toyota changed the designation, If I say 2013 Prius II? I'm counting on the intelligence of the reader to NOT be confused by the technical misstep of not matching Toyota's Prius trim designation shell game.
    I don't feel the need to give the history of Toyota's rather odd scrambling of designations.
    Just FYI...
    I barely use power mode.
    I think it's best application is when you may need to merge onto a fast moving highway.
    You can get the same acceleration kick, for passing, by just pressing your accelerator pedal more aggressively in either normal mode or ECO.
    The longer I own my Prius, the more I just drive it in Normal. Seems a good compromise in pedal mapping and accelerator response between Power, which awakens the engine far too aggressively for my liking, vs. ECO which may allow for more sensitive and economic driving but sometimes gives The Prius a "Walking Dead" zombie feel.
    But if your choice of using Power Mode, is primarily for just ease of passing once already up to speed?
    Pressing down more agressively on the accelarator will allow that to happen without being in Power Mode.
    OBJ and Rachael71 like this.
  9. breakfast
    breakfast Active Member
    266
    199
    I use Normal Mode virtually 100% of the time for the same reasons.
  10. Bay Stater
    534
    771
    Central Mass
    I too drive in normal mode, but power mode does make the car respond better without having to floor the accelerator. It's personal preference more than anything else. I do use power mode on the HW when in a hurry (not too often).:cool:
    bwilson4web likes this.
  11. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I use power mode when I want/need quicker response from the car; such as in heavy high speed traffic through cities like Houston or when merging with high speed traffic. I don't like having to "think" about pressing the accelerator harder/quicker and there's still a delay factor. I also use it going up steep hills in heavy traffic when I don't want to get out of line or hold people up. Between here and Flagstaff, if you get out of line, you might be there for awhile.
    Bay Stater and bwilson4web like this.
  12. bwilson4web
    16,202
    You've both brought up a good point that I hadn't considered before, moderating the high-power range.
    Living on 'river bottom' land with few, well know, steep slopes, I'm mostly moderating my acceleration with rare, if any, peak power events to reach cruise control speed and thereafter, cruise control handles the rest. Using a Scanguage II, I keep the engine rpm under 3200 rpm and my problem at higher power levels is solved. But I keep an eye on the engine rpm and 'pat' the cruise control to keep it under 3200 rpm.
    The 3200 rpm is the threshold between variable EGR settings and when the car goes into a maximum setting. Above this range, the car has to use other means to protect the exhaust valves and catalytic converter. The only remaining option is fuel enrichment.
  13. Priyzf
    Priyzf Junior Member
    Ohio
    2013 Prius v wagon
    Bob
    For those who don't have a Scanguage, where on the eco meter do I need to be to stay below 3200 rpm? Do you think living in the "red" power zone will decrease engine life span? Thanks
  14. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    I'm not convinced yet that the modes make a whole bunch of difference. I drove that same trip from grocery store to home (I got 99 mpg in regular mode) in power mode and got 98 mpg- it's mostly downhill with one big hill and one little right at the end. For me, power mode gets me up to coasting speed quicker and I feel like a temporary burst of speed fuels the battery to allow better driving in all electric mode. I noticed my car goes in to all electric mode more rapidly- Of course I'm new to my Prius and it could all just be an illusion to me- My sense when I push the pedal down firmly in eco or regular mode is that the fuel response is throttled and it's somehow making the car work harder in terms of resistance? - I'm not a lead foot either who enjoys speeding for no reason. I like coasting and gliding a lot. And the sedateness of the Prius ride is rather tranquil :)
  15. breakfast
    266
    199
    Fuel enrichment means you will just be using more fuel.
    Just drive it. Occasional use of the red power zone is nothing to worry about. If you're constantly above 3200 rpm in the rolling hills of Ohio you're going *well* above 70 MPH ...
  16. Priyzf
    Ohio
    2013 Prius v wagon
    I'm tryin to get into the 500,000 mile club!
  17. fuzzy1
    10,433
    Outside some climate control and cruise control tweaks, it is just a user interface change. Any difference depends entirely on the interaction of the user with that interface.
    A super-human driver with perfect dexterity, zero reaction time, infinite patience, and great foresight, should be able to achieve the same results in all modes. Different real-world humans bring different limitations and frailties, thus will get different results. While a plurality of us do best in ECO, others do best in another mode, and some see no meaningful difference between modes.
    Use whatever mode best suits your own tastes.
    Rachael71 and CR94 like this.
  18. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    Use whatever mode best suits your own tastes.[/QUOTE]
    So, for around town driving,I just use regular mode. My first trip of the day if less than a few miles, I use eco mode. For my frantic drive to work for 2 days a week (telecommute the remaining three) I use power mode. So, I will use all three modes- I don't want to have to pay too close attention to my driving tactics, at least not on the regular. Anyway, MPGs isn't the main reason I got this car. It was an environmental choice for me-( just wanted to make sure my car is performing correctly per the MPG expectations ascribed to it) I probably don't drive enough for my Prius to pay off in big dividends. But, I really love this car so far! I love the dreamy detached ride..or numb as car magazine reviewers describe it. The floaty feeling reminds me of my first car in high school, an Oldsmobile Vista Cruiser (station wagon), minus the 8 cylinder oomph. And coming from most recently driving a Nissan Sentra 2002 GXE, I feel enveloped in luxury where others might just see it as serviceable transportation :)
    Bay Stater and breakfast like this.
