Just Bought Prius 2007 gen 2. AVG MPG 31-34
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by soulgun007, Sep 25, 2019.
  1. soulgun007
    soulgun007 New Member
    San Francisco
    I just bought a used prius and I am getting what seems to be low miles per gallon. What can I do to find the issue? I do have an OBD sensor and when I checked the main battery, it appeared to be just fine. I do not know much about cars let alone prii, please help. I do drive it for about 5 to 20 minute intervals if that helps. I was suggested to check the 12 volt battery with the vehicle signal check mode and I got a reading of 11.6 Volts. But when I took it into auto zone, they checked it and said it was fine and was reading over 12 volts. Thank you
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
  3. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    The shorter the drive the worse your mileage will be. The car is barely warmed up in 5 minutes. Sounds like a case of you would have been better off getting a Corrola.
    49,694
    congrats and welcome!
    how many miles on her?:)
  5. soulgun007
    San Francisco
  6. bisco
    49,694
    spend some more time checking the 12v. its a tricky situation when it starts to get low. a new battery is close to 13 volts.
    its the load that the car puts on it when you press power that brings it down, and the drop is what matters.
    regarding mpg's, we need more info. the best way to measure them is long term calculating at the pump, and keeping records to track them.
    in the mean time, there are many things that can cause lower mpg's on a 12 year old car with 140k.
