Just changed brakes, now they are sticking. HELP!!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by laser411, Sep 25, 2017.
  1. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    The latest software is required for the latest model year Toyota/Lexus/Scion/Daihatsu.
    I sincerely doubt you can upgrade the firmware. Why? You are purchasing a $20/$35 imitation copy of a $400, Toyota licensed and approved OBD2 cable, called Mongoose Pro, made by Drew Technologies. This company supports their products, on behalf of the auto manufactures they have a licensing agreements with: Chrysler, GM, Ford, Honda, Jaguar, Land Rover, Nissan, Audi, VW. I just can't picture the counterfeiters in China, providing that same level of support.
    MongoosePro Toyota 2
    I don't know what version my imitation cable is when I purchased it a few years back. As far as I know, I am able to do everything, and it works fine with Techstream ver 8.0.
    Maybe the latest Techstream software truly requires the latest imitation cable? This will be your call.
    Assuming you are going to recheck and bleed the brake system, you might want to first clean/replace the shoes, adjust the shoes, and relube the rear brake shoe contact points on the backing plate. It is next to impossible to remove the rear brake shoe tensioner spring w/o accidently causing the rear brake cylinder piston to move, which will require the rear lines to be bleed.
  2. Mendel Leisk
    42,373
    I'm not familiar with second gen Prius rear drum brakes, so please, if I'm off-base, have mercy. That said:
    It's very easy to shift drum brake shoes a bit left/right, say when the drums off for lube of the shoe contact points with the backing plate. When doing this lube on various Honda drum brakes, I would:
    1. Remove the tensioner clips, so the shoes can be lifted slightly away from the backing plate.
    2. Sneak a little grease in, at the (three) bearing points, shoe to backing plate.
    3. Reinstall the tensioner clips, and shift the shoes slightly left/right, to distribute the grease.
    I don't see how this movement compromise the brakes, necessitate subsequent brake bleeding. The piston is shifting withing the cylinder yes, but no air is being pulled in, as far as I know.
  3. exstudent
    2,214
    906
    Torrance, CA
    My experience was a the exact opposite. The slight movement of the shoes, likely got translated into the brake shoe piston, which was probably enough to upset the brake system and the computers.
    I thought all was well. Put the car back on the ground and went for a test drive, only to have to raise the car and remove the wheels, due to DTCs having been triggered from this.
    Maybe the Gen2 is very sensitive to any movement the system itself does not make?
  4. Mendel Leisk
    42,373
    Could it have been excess brake pedal travel detected? That's one thing I've heard can trigger a warning. My drill with the (3rd gen) Prius is always to disconnect neg 12 volt cable first, and when everything is put back, do multiple pushes of the brake pedal, take up any slack, before reconnecting 12 volt. But again, this is third gen, all disc brakes.
  5. exstudent
    2,214
    906
    Torrance, CA
    Maybe.
    I was just swearing up a storm b/c I had just lowered the car. Now I had to relift the car, remove the wheels, and bleed. But, all was well after the bleed.
  6. laser411
    laser411 Junior Member
    35
    NC USA
    I got my cable and techstream but I cannot seem to access the abs system or many others for that matter. here is a screenshot
    I am sure the systems are fine, what could be wrong?
  7. ChapmanF
    19,055
    I am unable to see it for some reason.
    Have you tried the test suggested in post #2? It might point in the direction of what is going on.
    -Chap
    #27 ChapmanF, Sep 29, 2017
  8. laser411
    35
    NC USA
    What do you mean "test suggested in port #2"?
    And here is another screenshot, posted in a different way:
  9. laser411
    35
    NC USA
    Oh, I think you mean post 2. Yeah, so right this moment I am just trying to see if I can get techstream to access the abs system. I don't have time right now to pull the wheels off, I'll have some time Sunday to try and figure it out.
  10. ChapmanF
    19,055
    Sorry, yes, I meant post.
    Perplexing screenshot. Is that after running the Health Check?
    -Chap
  11. laser411
    35
    NC USA
    Yes that was after health check, and I did run the "cable check" and got k line and whatever was below it both failed. Think it may just be a bad VCI cable?
  12. ChapmanF
    19,055
    That would be my guess. It ought to Just Work....
    -Chap
  13. laser411
    35
    NC USA
    Is there something that all of those systems have in common? Like using the K line? It's weird too because I ran the can bus test and it failed outright, but the cable test said can lines were fine. Clearly I have can bus communication or else my car would be really wonky.
  14. ChapmanF
    19,055
    Right, I don't think it indicates any problem with the comm networks in the car, just a problem with the VCI.
    Keep in mind that the original Mini VCI was already a cheap version of other J2534 dongles, and if you bought it at all recently, it isn't even a real Mini VCI, it's one of the super cheap clones that drove XHorse (original Mini VCI maker) right out of the business.
    So it's unfortunate if the one you got doesn't work, but not at all unheard-of....
    -Chap
  15. laser411
    35
    NC USA
    Do you know if one that is known to be good?
  16. ChapmanF
    19,055
    Not for sure. The Mini VCI that I ended up with has issues of its own (though not the same issues as yours). I've been thinking to try out a VxDiag and/or a Tactrix OpenPort (both for more money) and compare, but never gotten around to it yet.
    -Chap
  17. Mendel Leisk
    42,373
    It's maybe too easy to stand on the side criticizing, but it feels like this quest to get Techstream running is supplanting the brake problem. OTOH, TS is maybe the best (or only?) way to proceed?
  18. ChapmanF
    19,055
    Thanks for the refocus ... I was thinking up in post #2 that the information most necessary to be gathered could be gathered by wrenching open one or both front caliper bleed screws and observing what happens ....
    It's not necessary, by the way, to remove the wheels for access to those bleeders; they're easy to reach.
    I guess the digression into Techstream arcana began in the question of whether that test might set warnings that Techstream would be required to clear.
    -Chap
  19. laser411
    35
    NC USA
    Since I figured I would need tech stream at some point, I went ahead and ordered everything I needed for that. I just did not have the daylight or time to perform those tests but did have a little time to play with TS. Still isn't working and I have ordered another VCI cable. Hopefully this one works correctly. I'm a bit worried now though. Today is the day though, I'm about to go out and take another look at the brakes.
    Side note though, Any chance the missing shims would cause this issue? I did not know those get reused and they did not come with the new brakes.
  20. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Shims at the back of pads, no. They are there just to make brakes quieter.
    Shims at the ends of pad, maybe.
    -If you just left the old shims there pads can be tight between them. If there tight enough they won’t return. But you should notice this when installing the pads.
    -If you left those shims out pads are super lose and there’s no smooth surface for them to slide along which could cause them not to return. But I don’t think you could just but it back together without those and not think why it’s so lose.
