Just did tune up and now I have white smoke? Please Help
Discussion in 'Gen 3 Prius Main Forum' started by Sidewayzgt, Mar 5, 2017.
  1. Former Member 68813
    3,524
    983
    US
    i know it's contraintuitive, but dielectric grease actually improves conduction where tight metal to metal connections exist. Not sure why, it could be due increased pressure or isolation from oxygen/moisture at the connection.
    but, I only use it where intermittent problems exist (works great) and not routinely put it on all connections. it the OP put too much of it everywhere it could be simply too much.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I don't know of a Hybrid Mechanic. However, you have done all you can at this point with your car. I don't think you did anything wrong. If it is a head gasket, changing the plugs and tuning it up will make all other areas of the car run better, while putting pressure on an already worn out head gasket, thus the sudden white smoke. This use to happen to me with my 72 Datsun 510. The L-18 engine had the most sensitive head out there. Torque it wrong and it warped way to easy. I would take your car to a dealer to verify that it is indeed a head gasket issue and then look at your options financially to see what is best for you. Some here in Priuschat have advised getting a used motor. I think that is best. Labor will cost the same.
    Raytheeagle likes this.
  3. Sidewayzgt
    Sidewayzgt Junior Member
    Los Angeles
    Thank you for your reply.
    I really do not think that it is a head gasket because the white smoke did not start until I changed the spark plugs and started the car cold (sitting outside for two days without starting). I did not have the misfire when I first started it either but it did gradually get worse. I put dielectric grease on the springs inside the ignition coils which in turn coated the spark plug ends (I think the dielectric grease stops the electricity from getting through or arching?). The spark plugs do not snap in to the coils, they just sit below the springs with resistance. I still have not taken everything apart again but will tonight. Yes, I will probably have to bring it to the dealer but I will cross my fingers that this works as well.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm not sure, but my parochial school back-ground seems to remind me that I think that means we've selected a new Pope.
    jerrymildred and Mendel Leisk like this.
  5. JC91006
    16,768
    8,565
    Bring your car to Avi's shop. You can find him at hybridfix.com. He's a member on this forum and maybe you can call him to see his take on this. He's seen a lot of hybrids.
    m.wynn, AzWxGuy and jdenenberg like this.
  6. Sidewayzgt
    Los Angeles
    Ok, here's an update. I have the car at Lexoligy in Redondo Beach. They received good Yelp reviews. They are still not sure what is going on? They are able to duplicate the cold start misfire issue but it is intermittent from there. They said that after the initial issue that the car drives fine and does not seem To misfire after that? They said nothing about anymore white smoke. I just need the car to be fixed and reliable because of my 100 mile commute so I am at their mercy.
    #66 Sidewayzgt, Mar 10, 2017
  7. JC91006
    16,768
    8,565
    Maybe your car is not broken
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I may be WAAAY off base here but wasn't there a problem and service bulletin on the 2010/2011 exhaust manifolds rattling cracking and causing cold starting issues?
    is the white smoke condensation?
    cold air being sucked into a hot exhaust system could cause it.
  9. sktn77a
    sktn77a Member
    303
    NC
    I suspect the EGR system. Go over it again and check everything.
  10. Sidewayzgt
    Los Angeles
    Well,
    Lexoligy has diagnosed it as a blown head gasket. This is very rare for a 107k car. I am having it done and it is costing me $1900. I want to make this worth my while so is there anything that I should have done while the motor is apart? I need this car to last at least another 100k. They also offered to put in another 59k motor for $3300 but I did not think it's necessary.
    Raytheeagle and Mendel Leisk like this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Inspect water pump?
    m.wynn and jerrymildred like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    Absolutely! All the blown head gaskets I've seen are from warped heads from a cooling failure from a leak or a water pump not pumping.
    Maybe put in a new timing chain while it's apart? Inspect camshaft & bearings? Or a new head if it's warped.
  13. mattdhurley12
    mattdhurley12 New Member
    29
    El Dorado Hills CA
    The same thing happened to me. Identical symptoms. Blown head gasket, sorry to say.
  14. Former Member 68813
    3,524
    983
    US
    this is low miles for HG. people reported it here closer to 200,000 miles. anything special about this car? could you figure out what the previous owner did to this car?
    edit: googling for HG prevention gave me some ideas: Preventing Head Gasket Failure
    what if cooled EGR flow is poor increasing cylinder temps and detonation? lately, as my car is inching toward 90,000 miles i can hear some subtle rattling somewhere in the engine bay, sometimes coinciding with acceleration. i cleaned intake and EGR pipe but didn't do the EGR valve or cooler yet.
    according to this: Blown Head Gaskets and How to Avoid Them
    air pockets can produce local overheating. i bled air in coolant in my prius once and it was not exactly easy.
    #74 Former Member 68813, Mar 16, 2017
  15. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Here's a wild idea - what if the EGR cooler itself is cracked and leaking? Possibly leaking coolant into the intake? That would show up in a pressure test and might lead the mechanic to believe it's the head.
  16. Sidewayzgt
    Los Angeles
    Well, I got my car back after replacing the head gasket and the problem is solved. Thank you everyone for your help and suggestions. On to the next issue.
  17. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Replace the piston rings?
  18. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Good it's back -- sorry to hear ... my fear was correct.
