Just drove 1/2 way of my trip [1500 miles] averaged = 41.1 mpg-Original hybrid battery
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 19, 2020.
  1. ski.dive
    ski.dive Active Member
    893
    230
    Hutchinson Island,FL. Mt. Snow,VT
    ***Will drive another 1500 miles back home in 2 weeks
    jzchen and Tideland Prius like this.
  2. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    I once did an 80mph banzai run to Phoenix and back in 115F weather with the a/c going full blast. That's the only time I've ever seen a figure that low.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,200
    5,896
    Columbia, SC
    Regardless of where he's going, it's uphill, so that may have some effect. Let's see how it looks on the way home.
  4. ski.dive
    893
    230
    I thought 41.1 MPG was great... Considering I was traveling on the HWY at 75-85MPH average speeds
    jerrymildred likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    I'd say that's about right for those speeds. And I assume there was some elevation gain as well.
  6. ski.dive
    893
    230
    Yes,
    Elevation when I arrived in Vermont...The Prius got down to 2 purple bars on the way up the mountains.
  7. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Consistently reduced fuel economy and faster SOC depletion are possible indicators of a weakened HV battery.
  8. ski.dive
    893
    230
    When coming down the mountains [with foot off the gas], the 2 purple bars went to green bars.
    Today I started the Prius and I had all Green Bars.
    My Prius really needed this 1500 HWY drive.
    It helped charge up my HYBRID battery, during this Corona Virus Era of not much use of the Prius.
  9. JoeOIVOV
    JoeOIVOV New Member
    Sacramento, CA
    Four Touring
    Clean your battery fan if you haven't lately. It made a noticeable difference in mpg the last time I did. Every time I do coolant change 50k miles, I wash this fan. Water doesn't appear to damage it in my experience.
    Watch your battery on long trips via OBD2 -> Bluetooth, the temperature of 'battery sensor 2' could be around 115F, when it gets to 130F it starts refusing to charge and mpg will go down to 35-40.
    Most people think their battery is bad but its not, its just getting too hot especially on long trips its more noticeable.
    Also check your tire air pressure, seems insignificant, but its not in my experience. Mine was 30psi, and it was suppose to be 45psi max. Once I put the correct amount of air in my tire, it went above 50mpg driving normally instead of 44-45.
  10. C Wagner
    C Wagner Member
    182
    58
    Boston
    I'm new to the group and my new-to-me,aged prius/HV battery. Two more potential sources of low mileage in addition to HV battery health, driving style and tire pressure could be: 1. dying 12v accessory lead acid battery - the ICE (engine) comes on more when the accessory battery is weak and not holding a good charge, I've read on PC. 2. The AC, electric cabin heat and defroster accessories use a huge amount of power. If your driving requires these, it makes sense that your mileage would be worse.
    #10 C Wagner, Jan 14, 2021
  11. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    SPEED is the biggest factor in fuel mileage, no matter what kind of vehicle you drive.
    A conventional hybrid car gets little to no benefit from the hybrid battery when your speed is constantly above about 70 MPH.
    Some designs won't even try to use the battery.....or charge it much.....at those speeds.
    C Wagner likes this.
  12. AzusaPrius
    AzusaPrius Senior Member
    1,855
    812
    @Sam
    I actually was able to use pure battery, no engine at 70mph not long ago on the 15 freeway north.
  13. sam spade 2
    7,035
    2,788
    2017 Prius c
    Going downhill ?
    Decelerating from 80 MPH ?
    Given the way that my C works, I find that a bit hard to believe just in general.
  14. dolj
    dolj Senior Member
    7,632
    3,850
    Wellington, New Zealand
    It may be hard to believe, but it doesn't mean it didn't happen.
  15. sam spade 2
    7,035
    2,788
    2017 Prius c
    Sure. Even if it wasn't actually designed to do that. Right.
    More likely a misunderstanding, I think.
