just got a 2010 Prius - need advice
Discussion in 'Gen 3 Prius Main Forum' started by Ed Geis, Aug 22, 2024.
Tags:
  1. Ed Geis
    Ed Geis New Member
    Maine
    I
    This is for my 18 y.o. son who's going off to college this fall.
    Car has 160,000 miles, 2 owners, looks well-cared for.
    Needs new all-season radial tires. Am looking at BF Goodrich Advantage Control. Anybody have experience with these tires? Any other recommendations?
    Will check battery fan and clean. Anything else to check out other than the usual (fluids, suspension, exhaust, etc.)? Have Dr. Prius app. on my phone and will try and do some diagnostics.
    We'll probably only get a few years out of this car before the underbody rust gets too bad to pass inspection, but if it gets him through college that would be a win (only paid $5K).
  2. Mendel Leisk
    42,361
    Any idea if the EGR (Exhaust Gas Recirculation) system's been cleaned? Assuming not, I would get on that ASAP. Start by inspection the pipe between EGR valve and intake manifold:
    Just to get some idea of overall condition.
    See first two links in my signature for more EGR cleaning info (on a phone turn it landscape to see signatures).
    Optimum cleaning (my opinion) would be every 50k miles. Even by that mileage the EGR cooler is carbon-coated enough to reduce cooling efficacy, and the overall system is clogged sufficient to hinder the EGR valve operation and unevenly starve cylinders of exhaust gas, starting at the cylinder one end.
    3rd Gen Prius, particularly with neglected EGR system (clogged with carbon) tend to blow head gaskets, around the miles yours has. Unscrupulous owners will dump in a stop-leak product and put it up for sale.
    #2 Mendel Leisk, Aug 22, 2024
    henry ortiz likes this.
  3. JC91006
    16,937
    8,647
    I would hate to give you this news but a 2010 is one of the worst years you can buy for a 3rd Gen car. Depending on the service history, there are 3 major failures that can (and will) happen on this car (especially after 150k miles and over 10 years old)
    1. HV battery failure
    2. Brake pump failure
    3. Head gasket failure.
    Even if those 3 expensive items have been addressed, there could be some other issues with the car (especially oil burning). So get that car checked out ASAP and do whatever maintenance you need before sending your kid off with this car.
  4. ETC(SS)
    7,571
    Sell the Prius and get a Corolla?
    Failing that:
    Buy the kid about $100 worth of hand tools and consider a AAA membership.
    Get the car inspection that you didn’t mention above.
    +1 on the EGR!!
    Read 25 threads on this forum that have Head Gasket in the title and familiarize yourself with the Prius Death Rattle.
  5. bisco
    52,875
    you can do a battery health check with the dr. prius app, but idk how helpful it is. no point to replacing the battery before it's necessary
  6. Mendel Leisk
    42,361
    Telling: that all of the responders have or have had a third gen (2010~2015). We know the damn foibles.
    I would say any of the 3rd gen years are equally vulnerable to EGR clogging and ensuing* head gasket failure.
    Maybe ditto for the brake booster, but not sure; Toyota might have "woken up" on that, maybe commencing in 2012~2013, made some revision?.
    The hybrid battery longevity is on par with any gen I'd think.
    Another factor is oil consumption: 2010 till partway through 2014 have "low tension" piston rings, and are prone to excessive oil consumption, commencing somewhere around 150K.
    If you stick with it, some other services worth doing:
    1. changing the transaxle fluid (Toyota says nothing about this, so often never been done)
    2. change brake fluid (Toyota USA says nothing; Toyota Canada, as of ~2014, says every 48k kms (30k miles) or tri-yearly)
    ^ Info on those two in my signature
    * FWIW, my theory...
    #6 Mendel Leisk, Aug 22, 2024
    Danno5060 likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    After reading all the replies, I’m sorry for your loss Ed. It was a great car for the super short term.
    bbrages likes this.
  8. Ed Geis
    Ed Geis New Member
    Maine
    I
    Thanks for the replies. Wow, that's some dark perspectives on the 2010. They're really that bad?
    I'll get right on the EGR. Have an appointment scheduled to have it looked at carefully next week.
  9. Mendel Leisk
    42,361
    By dealership? I'd tread cautiously: if they're typical, they'll likely charge you an hours "assessment" labour, tell you there's no codes/symptoms, and send you on your way.
    There's a few independents that know what they're doing:
    Tampa Hybrid (Florida)
    Hybrid Pit Stop (Los Angeles. Like the name infers, they're more performance than maintenance oriented)
    Hopefully someone will chime in regarding the northeast US. DIY is what a lot are doing, almost necessity unfortunately.
  10. bisco
    52,875
    some people have had very good luck. and then, there are all the people who don't have trouble and/or don't come here for advice. you may be one of the fortunate ones. all the best!
  11. JC91006
    16,937
    8,647
    I still have a 2010 and have had good luck with it. I’ve cleaned the EGR circuit at 90k miles and will soon do it again at 180k miles. I’m currently at 165k miles.
    I’ve replaced the hybrid battery, water pump, and all the shocks and struts. Everything else seems to be holding up well except for the exterior paint and burning oil at 1 qt per 1000 miles.
    #11 JC91006, Aug 23, 2024
  12. Ed Geis
    Ed Geis New Member
    Maine
    I
    Is the dealership not able to properly diagnose the battery condition? I'll try and find an independent who knows the Prius well. Anybody on here live in midcoast Maine by chance?
    Isn't there some diagnostic procedure offered by the Dr. Prius phone app? Is that worthwhile? What's the best way to evaluate the battery?
  13. Ed Geis
    Ed Geis New Member
    Maine
    I
    Looks like my previous post is being held for moderation (?!). Was going to add: the vehicle's front windshield washer doesn't work. No sound at all when the switch is activated. The rear works fine. Have ordered a new pump. Can I access this by removing the plastic inner fender on the passenger side front? Or do I need to remove the whole front bumper assembly?
    The fun begins...
  14. bbrages
    bbrages Member
    169
    47
    St. Louis
    I've got 235k miles on mine (bought it at 207k) and it is running fine - no major problems yet.
    Have replaced brakes, tires, wheel bearings, wiper motor, blower motor - these are things that would fail on any car with this mileage.
    Have cleaned EGR and replaced water pump.
    ASRDogman likes this.
  15. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    First, the hg issue is the worse and sometimes is hidden by unscrupulous sellers through the temporary use of sealant. On these engines the only real solution once a hg fails is a replacement rebuilt engine. But some escape that fate until higher miles than yours. Some don’t.
    The dealer, Toyota and most master mechanics don’t correlate the clogged egr cooler to hg problems. As a result they only replace egr coolers and valves if a specific code appears. So the advice of the Priuschat egr believers is to remove the system yourself and clean, often over a period of days. It is a bit of work which the dealer will only do on request by changing parts for ~$1000.
    Same story as above, the dealer will recommend a change for new if it codes.
    The paid upgrade to Dr Prius will give you an educated guess and a push to buy their aftermarket cells. Resist the temptation.
    I would try to find an independent hybrid shop which can often give you better options on an gen3 Prius repair than a dealer. A dealer has high overhead and Toyota repair procedures to follow which are intended to return the failed component to a long term reliable solution. The diy’ers and small shops here try to fix it for the lowest cost unless they are trying to sell you on an aftermarket part using a discount code.
    #15 rjparker, Aug 26, 2024
  16. Mendel Leisk
    42,361
    Yes. Toyota's stonewalling on this, and the dealerships go along.
    We true "believers" all wear tin foil hats. Mine's just invisible. :)
  17. Ed Geis
    Ed Geis New Member
    Maine
    I
    Thanks, have ordered a new gasket for the EGR pipe and as soon as that arrives (love Rock Auto!) I will clean out that pipe and see how things look. Will report back.
    Any thoughts on the windshield washer fluid pump access? Really hoping I don't have to take the whole bumper assembly off...
  18. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    350,7++ miles today.....
    Replaced head gasket at 301,000 miles. I had planned on doing it within a week or two
    before I got the knocking once or twice. So I did it sooner. It wasn't too bad to do.
    I did a LOT of cleaning. And had 1 valve that was leaking ever so barely. So I seated them
    all in and replaced the valve guide seals.
    I also did the egr system cleaning.
    I just did another one this past Friday. I have a spare cleaned cooler so the job went fast.
    4-6 hours depending on how you clean the cooler and how fast you want to work.
    If you are concerned about the hybrid battery, get the Prolong system and run the full 4 charge 3 discharge
    cycles with the last charge going for 8-10 hour after the voltage levels off. This will "balance" the pack.
    I got almost 3 extra years using it. In May i replace the hybrid battery with the lithium one. I'm happy with it!
    A lot of this stuff you can do yourself, if you are semi mechanically inclined and have to tools.
  19. Mendel Leisk
    42,361
    Yeah to keep a third gen past 150K, it helps to live in Tampa or LA, or be able to wrench. Dealerships and Toyota are a cruel joke.
    I've never taken on anything that arduous. I'm hoping EGR cleaning (twice so far), frequent oil changes and periodic extensive drives, will keep it going. Our kms are piling on ever slower, might never get into the danger zone. Miss all the "fun".
  20. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Check the fuses that supply 12V to the windshield washer pump. And also the washer fluid level.
