Just got a P0A80 error
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeri Nelz, Dec 4, 2014.
  1. bisco
    52,785
    hopefully, the fan is clogged, the battery overheated enough to set off the code, but no damage was done. all the best!(y)
    dorunron likes this.
  2. Jeri Nelz
    Jeri Nelz New Member
    On top of it all you could feel a bit of warmth on the back seats of the car so I am hoping it's really the fan.
  3. Jeri Nelz
    Update: It seems cleaning the fan was caught too late and the battery is a bit damage, so much to now I am sometimes losing power in acceleration, the shop owner tried to get me a loan for the repair but due to reasons unknown despite having a very good credit score for someone my age I was only given $700 from their loan department, I was told to call a number to try and get a better chance over the weekend due to my address not matching where I currently reside. I was in a sad rut as I am working together to get the funds only to find out my car finance came with insurance that doesnt expire until my car hits 110k miles, so I am hoping that when I get a call back next week they can approve my car to be repaired, I also apparently have a rental covered under this plan and discount from my job so I am going to try and rent a car next week and leave the car in the shop.
  4. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Asking the more experienced posters on this thread...in Jeri's situation now, would it make sense to try a grid charger on that battery, or do you think it's a goner?
  5. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I'm assuming (based on what you said above) that you're out of warranty and can't afford a new battery right now. If so then maybe you can buy some time with the slightly damaged battery if you're careful with the levels of charge. Basically you could try a few trick that I use to "nurse" the battery along a bit.
    If the battery is only slightly damaged then it may still function well enough if you can keep the charge levels at around 6 bars and try to avoid too many large variations. Essentially you want to try to keep the levels between 5 and 7 bars on the display as much of the time as possible.
    One trick to minimise charge excursions is to always let the car warm for approx 40 to 50 seconds when you first start it up. I know that seems like a waste of time when you've probably got warm weather, but even in warm weather it does help. Why it works is because the prius tries to use the electric power in preference to the engine when you first start up, until the catalytic converters warm up. And even in warm weather this takes around 40 seconds or more. If you let the cats warm before you drive then it doesn't punish the battery nearly as much. (Note that you may have to hold the brake and tap the accelerator to force the engine to start in warm weather. If the engine immediately cuts back out then that just means it's already warm enough).
    I know you probably don't have a whole lot of mountains around Orlando, but if you are driving in terrain with large hills then the other tip is to use "B" mode on descents to avoid getting too much charge on the battery. This works ok on moderate hills, but not so much on larger mountain passes.
    BTW Jeri. Can you confirm the status of your 8yr 100k mile battery warranty. I know you are under 100k on the miles, but when exactly did the 8 years expire?
    #25 uart, Dec 5, 2014
  6. JC91006
    16,933
    8,643
    I would call Toyota HQ and ask them for a goodwill warranty on the battery. Toyota has been pretty generous lately on these warranties, where they cover the entire price of the battery and the owner just pays for the labor to install.
    Your car is fairly low in mileage to have this breakdown. I'm thinking Toyota will be helpful if you call them.
  7. Jeri Nelz
    From my records I dug up on the car, 03/05/2006 was when my car was manufactured and shipped to the dealer and 04/06/2006 was when it was first registered by a driver. I am going to try and call toyota hq
  8. bisco
    52,785
    all the best!(y)
  9. Jeri Nelz
    From what I could find by searching up the internet that florida I believe is a CARB state, as it accepted california's emission laws in 2007 or 2009 which means when the guy originally quoted me 10years that it should be correct. Anyone have any word or advice on if I am correct?
  10. JC91006
    16,933
    8,643
    If it started in 2007,then your 2006 doesn't qualify. But call toyota anyways and see what they say
  11. Jeri Nelz
    What would be the process or chance of success if I decided to trade the car or sell it to toyota? Is that even an option?
    #31 Jeri Nelz, Dec 7, 2014
  12. JC91006
    16,933
    8,643
    You can trade it in but you'll get pennies on the dollar. They'll offer you $1500 for your $6000 car
  13. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    If you are interested in losing money big time, go ahead and trade. Fix it first, then consider trading or selling out right. Just don't give it away.
    Any machine can be fixed with the right part and the right tools. Sorry to be blunt, but it is what it is.
    Ron
  14. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Yes indeed. Yours would not be the first that a clogged vent fan is a cause of such issues. Get rid of that dog, ;) or not in your car rule. :)
  15. Cindy19851
    Cindy19851 New Member
    Rancho Cordova
    2002 Prius
    I know they just opened a Greentec Auto in Tampa Florida, I have heard good things about them. The number is 800-773-6614
  16. dorunron
    3,318
    1,105
    Houston, TX
    Seen more than one Prius effected by hair in the vent. Not only is the fan clogged up, but the hair gets down to the battery itself which causes more heat problems. When something like this takes place, it is really best to uncover the big battery and clean it up with a low powered vacuum at the same time the fan is cleaned out. Also blow out all of the duct work. That will remove any hair from the system. Some of the folks here on this board have actually added a little filter media where the opening is on the rear seat. That eliminates any chance of foreign particles entering the system and creating the problem in the first place.
    IIRC, Toyota is now making a filter for the system. It does not come with a new car, but can be added. Check with the parts dept. at Toyota for more info. I am not sure if the filter is only available for the Gen III or if it is also made for Gen II Prius.
    Fur and dirt causing major battery problems | PriusChat
    Ron (dorunron)
    uart likes this.
  17. Jeri Nelz
    Is there by chance a guide so I can try and clean everything out myself during the weekend?
  18. bisco
    52,785
    there is a complete pictorial guide, if you search, hopefully will find it.
  19. dorunron
    3,318
    1,105
    Houston, TX
    Sheesh, two minutes of searching and this is what I came up with.
    Battery Fan Cleaning | PriusChat
    Read the above string and DOWNLOAD the PDF FILE DUDE!
  20. dorunron
    3,318
    1,105
    Houston, TX
    Every Question that is asked about the Prius has been asked before. OKAY, not 100% of them, but just about. Google is your friend! Try searching instead of posting frivolous questions that have been asked before...
    Senior's like myself get tired of answering the same questions every day when Google will reveal the answer to 99% of the questions asked each day here on Prius Chat!
    Again, sorry to be blunt. It is what it is.
    Ron (dorunron)
    usnavystgc likes this.
