Just got a Prius Prime...need advice re the power cord.
Discussion in 'Prime Plug-in Charging' started by RoxD, Dec 21, 2019.
  1. bisco
    51,994
    thank you!
  2. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    Shoot me a PM with your Address and I will mail it from the post office in an envelope.
    I have scrap pvc and it only takes me 5 minutes or less to make one.
    jerrymildred, RoxD and bisco like this.
  3. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    That's the Christmas Spirit !!! (y)
    Merry Christmas,
    Rob43
    RoxD and jerrymildred like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    A band saw would be the hot ticket for ripping that pvc in the middle if you can find one that you can use.
  5. Blue-Adept
    293
    179
    2018 Prius Prime
    My band saw is dead. It was about 75 years old. Was my grand fathers. Splitting the pipe is not to difficult with a reciprocating saw but a table saw with a fine blade may also work...
    jerrymildred likes this.
  6. RoxD
    RoxD New Member
    2020 Prius Prime
    not sure how to private message.
  7. bisco
    51,994
    click on an avatar, then click 'start a conversation'
    RoxD likes this.
  8. jerrymildred
    11,517
    14,152
    Tampa, FL
    Or just click on "Start conversation" under the avatar's name.
  9. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    I would recommend this if you have a good relationship with your landlord and don't mind spend some money. I also rent and was able to get my landlord to agree to installing an external outlet (since I was willing to pay for it).
    The best part was that I got to specify the installation (i.e. new dedicated circuit, thicker gauged wire than needed, proper gfci outlet, etc) so I knew that my setup was safe.
  10. veganeric
    veganeric New Member
    MPLS
    2020 Prius Prime
    Many electric garage door openers have limit screws to adjust how far the door closes/opens. You may be able to simply adjust the close screw so there is a gap left.
    Rob43 likes this.
