Just had 10K done
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Jan 14, 2013.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Got my 10K done by the dealer today at the dealer. I also had them turn off the reverse beeps.
    The paperwork showed they used:
    QTY 1 of 04152-YZZA6 filter element
    QTY 5 of 00279-0WQTE-01
    They billed ToyotaCare $53.18 of labor (Tire rotation and inspections too), and $30.70 for the materials mentioned above. The reprogramming for the reverse beep was free, but I did have to wait an extra 30 mins for the shop foreman to show up to work to do that, apparently not everyone in the shop was TechStream-savy.
    I went straight from the dealer to work and have not double checked their work yet. I will look when I get home tonight to see:
    1) If they overfilled, since they claim full 5 qts were used;
    2) If they reset the tire pressures after the tires were rotated.
  2. El Dobro
    El Dobro A Member
    7,101
    3,280
    Check the cover on the bottom to make sure nothing is hanging.
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Just double checked:
    1) Oil change door is not hanging off the bottom;
    2) Oil not over filled, just a hair above the full mark, just like how it came from the factory;
    3) Tire rotation done, as I was checking the pressures, found a nail in the driver side front tire. Soap tested it and it is bubbling very slowly. :mad: I can't say if the nail was there when they rotated it or not, but looks like I have a date with Discount Tires in the morning.
    The Critic likes this.
