Just hit 5000 miles. Anyone rotate their own tires?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Green Hokie, Jun 13, 2007.
  1. jamesl
    jamesl New Member
    <div class='quotetop'>QUOTE(Green Hokie @ Jun 16 2007, 09:28 PM) [snapback]463228[/snapback]</div>
    On all front wheel drive cars excluding directional rims...
    The tires should be rotated front straight back (drive wheels) and the back wheels criss cross to the front. This would be the recommended rotation pattern.
    This way a tire will have been at each wheel postion in four rotations.
    http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=43
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Yes, but Toyota says otherwise. What to do?
  3. jamesl
    jamesl New Member
    <div class='quotetop'>QUOTE(lenjack @ Jun 24 2007, 11:28 PM) [snapback]467481[/snapback]</div>
    I would go with what the tire manufacture says, because toyota won't be backing up a tire mileage warranty issue. And everyone i know is front straight back and rear criss cross to front.
  4. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Some tires cannot be rotated side to side as the belts lay a certain way once they are used. Make sure your tires are not this type which must continue rolling in only one direction thoughout their lifespan.
