Just how the hell
Discussion in 'Gen 3 Prius Technical Discussion' started by Stu9, Apr 10, 2025.
  1. ChapmanF
    18,993
    For what it's worth, I don't think hub bearings are any more fun in a gen 2.
  2. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    It isn't just that it is a simpler car overall.
  3. Tombukt2
    Tombukt2 Senior Member
    13,836
    2,514
    Durham NC
    Yeah that's a smart move The hub bearings in the rear are actually the same basically You just don't have disc brakes so you have to keep your backing plate and it's also heavier than the thin thing that's sitting there behind your brake rotor that's just a dust shield on a drum brake system that backing plate is pretty stout as it's not just a backing plate and hold your wheel cylinder and all that nonsense The brake shoes and all of it but it generally comes off without any ado and then that's out of your way and then if the car is jacked up properly where I live a 5 lb maul . Will generally beat the assembly through I kroil the crap out of it day before . Or if it's really ugly someplace like New England I start spraying it about 4 days before I work on
  4. Mendel Leisk
    42,304
    @Stu9 I think the simple answer would be: have a professional shop deal with it. I know.
