Just Installed a new 12v Aux Battery in my 2006
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cubbyg, Dec 10, 2012.
  1. cubbyg
    cubbyg Junior Member
    57
    I was having difficulty opening my rear hatch.??? I performed "DO-IT-YOURSELF TEST PROCEDURE(thanks to jdenenberg)":
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the headlights on and off three times to enter Maintenance mode; release Info button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    Read more: http://priuschat.com/threads/question-re-12-volt-battery-please.113664/#ixzz2EgVw01SQ
    Found the aux voltage was 11.7v. Time to get the old one out.
    It was a really easy job. I installed an Optima DS46B24R (~$155) replacement and everything fit perfect. If anyone has 30-45 minutes and a little wrench time (10mm and 12mm )....go for it. I found the Youtube post very detailed and helpful:
    Hatch pops right open and I am glad I have a new aux battery, robust and ready for action!
    jdenenberg likes this.
  2. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Where did you find it for $155, please?
  3. cubbyg
    57
    Found it @ Advanced Auto Parts. They had a coupon 20% off last week and I snagged it! :)
  4. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Last time I shopped for 12V battery, I went to Interstate Battery
    Batteries - Interstate Batteries has every battery for every need
    They sell refurbished battery for Prius, at $30 :)
    They only use the housing, and replaced everything inside battery.
    You will need adapters for the poles, but that's about $15 or something...
    That's a super deal for me.
    So far, it has been on my Gen II Prius for 1.5 years, and 30K miles. No sign of degradation. I expect it to last same as regular batteries.
  5. fuzzy1
    10,705
    I now disagree with this voltage range, which seems tuned more to traditional non-hybrids. The Prius seems to run lower. I often saw 12.2-3V on my apparently healthy 2010, and saw numerous reports of others finding no symptoms yet even at 11.8-9V. Then someone posted a handy Charge-vs-V chart here: only 36-37 average mpg?
    Cubbyg reported 11.7V before this swap. That wasn't dead yet, but according to this chart, it was near end of life. And far lower than the point where my non-hybrid failed to crank last month.
  6. cubbyg
    57
    The beauty of the new Optima is that everything including the vent opening, dimensions, and the smaller post design is an exact duplicate of the factory battery with the benefit of the deep cycle design and performance.
  7. cubbyg
    57
    The whole idea of the replacement was not to take the battery to failure. Best to replace it near the end, on your own time, not the battery's!! That way when you need the car to start and go it is ready when you are.
  8. fuzzy1
    10,705
    I had to add this note because some drivers in other threads may have been prodded to replace aux batteries that were perfectly fine. The 12.4V threshold in the post you copied is too high.
    But I agree that yours, at 11.7V, was due for replacement.
  9. redhawk
    redhawk New Member
    My SmartKey system stopped working—had to insert fob in slot to start the car—so I used the procedure mentioned above to test. Voltage is around 10.3.
    What's disappointing is I just installed a new Optima DS46B24R in February.
    I'm going to charge it up and hope to get more life out of it. I'm not sure why it would go bad so quickly.
  10. cubbyg
    57
    They price matched from Streetside Auto.com ($150.82).
  11. cubbyg
    57
    They have a 3 year replacement warrantee, if it fails.
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi cubbyg. Could you post the new voltages that you measure after a few days driving. Make sure to include both the Acc mode and Ig mode measurements. :)
  13. cubbyg
    57
    12.4v and 14.0. All looks very good
  14. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    14.0 is not the "Ig mode" measurement. That's READY mode. The states are OFF, ACC, IG-ON, READY.
  15. cubbyg
    57
    Just did it again, 12.1, 11.9, 14.0
  16. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I am no expert, but 12.1 is not that great IMO. Your battery is not fully charged. 11.9 should be higher also. 14.0 is normal and that is expected.
    A fully charged battery should read 12.4 to 12.7 on the MFD or higher in the first part of the test. Your reading is 12.1 Note: The MFD does not always read the full voltage at a rest depending on loads being applied during the test. Try to minimize loads such as doors being open, fan blowing on A/C-heat, radio, etc.
    Refer to this voltage chart to get an idea of State of Charge (SOC) on your 12 volt battery.
    I understand you just replaced the battery with a new Optima, however there have been a lot of reports recently about the Optima's not being fully charged when being bought new. I would suggest you use a smart charger, and fully charge the battery then run the test again after letting the 12 volt rest for at least 8 hours. If you test right after the charge, the values will not be indicative of the true values after the battery has set for a resting period.
    If you charge the battery, set your charger to AGM and choose 4 Amps for the best charge. Optima does suggest the battery can be charged at 10 Amps. If you choose to charge higher than 4 Amps, I would suggest you connect your charger directly to the battery rather than using the jump post underneath the hood in the fuse box. The Prius normally charges at 4 Amps, so my reasoning is that if you are using the jump post, you would want to simulate actual Prius normal operating conditions. I have no doubt other's will have their own opinion concerning charging methods, so I suggest you do some research before you follow the steps I mentioned.
    FWIW, I maintain my Prius 12 volt battery (original OEM) with a smart charger and do keep it topped off at least once a month. I always use the jump post and set my charger on 4 Amps and AGM. By doing that I keep my battery fully charged at all times. I don't drive the car every day, and most Prius owners can attest that the 12 volts does run down quickly if the car sets due to the parasitic draw from the SKS and other electronics onboard.
    My numbers are normally 12.3, 12.0 and 14.0 - borderline, but still doing the job. Have seen 12.4, 12.1 and 13.9 before. I will be changing my battery soon and will replace with a OEM battery rather than the Optima.
    Ron
  17. cubbyg
    57
    Ron, Thank you for you comments. I am troubled by these numbers. I charged the battery over night before installation. It had a manufactured sticker from Johnson Controls of 12/12 from the great nation of Mexico . I wonder if the internal test in the prius really tests the battery volatge correctly? Is there is an unusual load on the powerd down car, or if the charging system is not working properly. I would appreciate any other thoughts and comments from the community at large. I am sure this information would benefit the community as a whole regarding this issue.
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    The internal tester in the Prius is not all that accurate. The real test is how does your car work?
  19. cubbyg
    57
    I am not sure how to evaluate the battery on the subjective question of "how does your car work?"
  20. dorunron
    3,318
    1,105
    Houston, TX
    Cubby,
    If you are troubled by those numbers, I further suggest you do the following.
    1. Check the resting voltage of the Prius with a digital meter that will measure DC voltage.
    2. Check the voltage of the 12 volt battery while the car is completely off after the car has set overnight.
    3. Check the voltage of the 12 volt battery while the car is in "Ready Mode".
    Compare the value of the battery while the car is "off" to the volt chart in post #16 If the battery is not fully charged, charge the battery again and retest with the digital meter. Remember to allow the battery to rest before you take your readings. That will help to eliminate what is known as a surface charge.
    If you find that you can not succesfully charge the battery to at least 90%, I would consider returning the battery under warranty and getting another one. As I stated earlier, there have been reports recently about the Optima batteries not being fully charged when being sold. I have also read that it seems the quality has gone down since the plant moved to Mexico. Note your date code.
    In reference to the voltage in "Ready Mode". As long as the value is between 13.6 and 14.4 you should be Ok concerning the charging system of the car. Just make sure that the cables are clean and that all the connections in the back end are tight.
    Ron
