Just Installed BM-2 Battery Monitor and NOCO On Board Charger
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Dec 9, 2025 at 9:06 AM.
  1. Gokhan
    Gokhan Senior Member
    6,204
    2,455
    Paramount CA
    Same with Gen 4, which has an identical BMS. It goes up to 14.4 V, but it is usually 14.1–14.3 V. The battery SOC will affect the actual voltage.
  2. VelvetFoot
    VelvetFoot Active Member
    667
    239
    New York State
    2026 Prius
    First dip, 5 hours after stop. Probably EVAP pump. Hopefully, one or two shots and over, 'cause it does cause a step down in voltage.
    Gokhan likes this.
  3. Gokhan
    6,204
    2,455
    Paramount CA
    Yep, that’s just EVAP, nothing to worry about.
    Gen 4/Gen 5 parasitic drain is mostly an urban legend or myth. The main reason for Gen 4/Gen 5 battery failures is the fact that the BMS doesn’t charge much during warmer months, and if you don’t drive the car frequently for long distances, that could result in battery failures.
  4. VelvetFoot
    667
    239
    New York State
    2026 Prius
    There were 3 tiny dips in half-hour intervals overnight, starting an hour after the probable EVAP pump. Perhaps related?. Makes you wonder what they are. :)
    I might see if my security camera in the garage can pick up the sound of the EVAP pump, lol.
  5. Gokhan
    6,204
    2,455
    Paramount CA
    They could be EVAP or other things. It is nothing to worry about.
    Incidentally, the dips for my AGM battery are shallower than for your flooded-cell battery because of the lower internal resistance of an AGM battery.
