Just installed my new Rotiforms
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Stoweza, Dec 30, 2017.
  1. Stoweza
    Stoweza Junior Member
    16
    16
    North carolina
    Rotiform 18 model BLQ
    Just got them installed today and I'm ecstatic with the way they turned out. Einbach 1.5' lowering kit is coking in next week as well as my Thule cargo rack set up to finish the look. If the forum has any questions feel free to ask.
    JamesBurke likes this.
  2. Stoweza
    16
    16
    North carolina
    <PHOTO 1>
  3. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    Pictures of the roof box setup would be good. Looking at getting a Thule Touring 200 (400 lites) box myself.
    iPhone ?
  4. Stoweza
    16
    16
    North carolina
    Sure thing. I'll post pictures when I get it installed :)
  5. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    28 pounds for the single piece wheels. 35mm offset so 10mm push to the outside from OEM. What tire you put on? Section width, Revs per mile ect. for comparison to OEM.
    Nice color match.
  6. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    I like the look of your wheels
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    @X HCH2 is that an old Featherbed frame Norton in your profile?
  8. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    You've got a good eye. It is a Norton, but it is an 850 Commando. It has the "isolastic" frame, the successor to the Featherbed.
    I bought it in 1975 when they went out of business. Still have it and ride it regularly in good weather.
    X
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Well done you! I'm just a little bit jealous, even now. :D
  10. jamiec123
    jamiec123 Member
    89
    75
    Ohio
    Love the wheels! I was looking at getting them in 18s but I’m stuck on getting a set of Niche wheels.
    One question though. When I got my quote from discount tire direct it says the lug pattern is 5x114.3. I thought the Prius was 5x100. Do you happen to know what you have so I don’t order the wron pattern?
  11. Stoweza
    16
    16
    North carolina
    The prius is 5x100 with a 54.10 center bore. So if you are running an aftermarket wheel, use hub centric rings. I had to get ones custom made for like 8 bucks for 57.10 ---> 54.10.
    jamiec123 likes this.
  12. jamiec123
    jamiec123 Member
    89
    75
    Ohio
    Thanks for the info. I knew they were wrong about the lug pattern. Where did you get the hub centric rings at?
  13. Stoweza
    16
    16
    North carolina
    Hub Rings / Spigot Rings for Wheels from USA $6.25 / pcs - HubCentric-Rings.com
    They do not keep 5710 to 5410 in stock in the US, so it took about 24 days to get mine. 57.10 is just what the rotiform blqs use, so depending on the hub size for your wheels you could get them faster. Don't bother with the aluminum upgrade, you don't need it
  14. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Looks nice! (y) Any idea yet on how the larger wheels affect MPG?
