Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. bisco
    52,855
    there's a 400' cedar post and rail on our property line owned by our neighbor. when I was young and healthy, I would replace the posts as they rotted at the soil line, and rarely a rotting rail.
    now that I'm old and confused, I ignore it, and our neighbor hires handymen to do it.
    each time one falls over, he tells them to replace it, and check all the others. invariably, within a few weeks, another falls over.
    52,855
    I still round up my gas purchases, but the higher the price goes, the more difficult it is to get it to stop where you want. ocd? :cool:
    futurist and Mendel Leisk like this.
  3. Mendel Leisk
    42,347
    We're post Post Office?
    I'm the opposite: clicks-off, done.
    bisco and futurist like this.
  4. futurist
    futurist Member
    57
    185
    United States
    2024 Prius
    Yep -- far better for your vehicle, and unfortunately how most modern fuel tank emissions components are designed.
    After about 2005 or so... multi-clicking after the first, you risk the chance of liquid fuel getting into the intake port for the purge charcoal canister. This is designed to take only vapours from the tank and absorb them into the charcoal, for use later when they can be burned for power, thus injector pulse trimmed to ideal for ICE efficiency.
    If you fill the tank up into the neck past that port, and fuel gets in there... soaks the charcoal making the canister unsuitable for emissions control; poor fuel metering can result as the PCU expects a different richness at the O2 sensor than it gets. This of course lowers efficiency and kills power and idle quality, as the PCU tries desperately to push / trim back enough pulse to satisfy the O2 sensors. If done a year of fillups... can require replacement of the canister and purge valve mechanism. Mind you -- this can still happen if you don't fill past the port but close, and the car sloshes it around, same difference to the charcoal.
    First click usually is safely away from splash-contamination of this vapour port (I mean, if you're fond of taking your car anywhere it'll tilt on the road surface >35 deg on the filler side... u be u, but all bets are off :confused: ). My childhood driveway was 58 ft and 30º dug into a hill, but was built during lap belts and ignition points still adjusted by the owner, let alone fuel tanks being little more than vented canteens, purging vapours right to atmo... ah, the '60s :rolleyes:
    Used to multi-click-fill all my cars with little downside since my first in the '80s (in fact, used to fill until I could see the fuel bubble up around the filler opening, challenging myself to get it juuuuust full enough it wouldn't spill out onto the paint)... but with the junky 7th-gen Honda, one of the forum keys to restoring mpg on those things, was to swap out the purge mechanism, as was known to be poorly-engineered from the factory (very sensitive to even slight overfilling). Taking it out, found it was full of fuel. >$200 in 2015, and mpg went from 31 to 36, plus far smoother at idle and torquier than I got it. So when the previous turbo Honda's mpg took a nosedive about 30K (41 down to 36), inspected the canister... and the thing was also filled with fuel. >$300 -- in 2019. Stopped multi-clicking after that :confused:
    Try not to give a third of a studio rent payment ($500) to your OEM, if you drive a modern ICE car... just because you're spazzing about two cups extra fuel not being in the neck every fillup :sneaky::D
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,349
    979
    Monument, Colorado USA
    While my brother doesn't have nearly 400, he got tired of constantly having to replace the wooden posts so dug them all up and installed aluminum poles with concrete foundations....should last him a couple of years!!
  6. ColoradoBoo
    1,349
    979
    I'm an engineer but, still, want to seriously SLAP the engineer who put the AWD motor in my back of my 2021 Prius AWD.
    The drain bolt is right there....easy peasy. The FILL bolt is up on the right hand side and there's just no way get in there....too much crap in the way. If I had a very short 10mm hex socket MAYBE but I don't have one...my regular socket doesn't even come close.
    After spending way too long trying to figure out how to get that bolt lose, i remember, a few years ago, I bought a set of extra long hex sockets to remove the exhaust manifold in some of our Toyota's....prayed we had a big 10mm size...YEP! Was able to wriggle it in there and used an extension to get the ratchet on there and broke it free....PHEW!
    Getting the bolt back on was, also, a pain...you can only get one hand barely up there and not at a good angle....ended up using the other hand's to put a finger up there to get the threads started.....to quote Charlie Brown, "ARGH! and Good Grief!"
    Little motor only takes about a qt and a half of Toyota WS and it wasn't even all that dirty....plan to wait 4-5 years instead of 3 for the next service.
    Mendel Leisk and futurist like this.
  7. Trollbait
    12,829
    The private delivery companies do.
    That's what the Subaru manual says to do.
    Stevewoods likes this.
  8. Stevewoods
    Stevewoods Senior Member
    666
    1,267
    where I am
    hill likes this.
  9. bisco
    52,855
    rounding up hasn't affected any of our 6 hybrids negatively over the last 22 years
  10. Mendel Leisk
    42,347
    Yeah a dollar doesn’t amount to much gas of late.
  11. ChapmanF
    19,025
    Plus, it'll never be more than half a dollar, unless you round like IRS.
  12. hill
    9,038
    Good read!
    Gasoline has a very high rate of evaporation.
    On the other hand, go ahead and click away on your diesel vehicle - as its low rate means no evaporative emissions systems. Throw a lit match in a bowl of diesel fuel & it's likely to just get snuffed out. But spill it on the ground? You've got a greasy stain for a good long time.
    ColoradoBoo likes this.
  13. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    The pumps don’t click off all the same. Except Costco seems to spend the money to maintain their equipment.
    #3473 Mr.Vanvandenburg, May 10, 2026
    futurist likes this.
  14. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    Too much Ram, not enough Dodge.
    futurist, RRxing, hill and 1 other person like this.
  15. ColoradoBoo
    1,349
    979
    That's true! I've had gas shoot out of the car because the auto-stop didn't work.....really made me fret about that charcoal cannister getting ruined but didn't seem to effect anything.
  16. ETC(SS)
    7,555
    Cigarettes didn't affect my dad negatively for the first 22 years either....but hey.
    Your car, your call.
    Evap solenoids are easy-peasy to replace but....why bother with all that since it's easier to:
    Click-pay,
    Click-done.
    I don't really pay attention to the dollar amounts, as long as the DTE goes back up up to about 500-510. :cool:
  17. bisco
    52,855
    it's probably a sign of old or something, but I doubt there's any relationship to smoking.
  18. futurist
    futurist Member
    57
    185
    United States
    2024 Prius
    Overfilling in this way once or twice, isn't going to soak a pint charcoal canister, methinks. But do it regularly, that's when you shell.
    Auto-stop mechanism not working properly and spraying fuel, is one of the reasons why we can't have nice things -- too dependent on an analogue mechanism that wears, isn't properly set, or simply lacks maintenance because those responsible want to chisel away anything that spends money. The mechanism is pretty ingenious... when properly maintained and serviceable :unsure:
  19. Isaac Zachary
    2,779
    1,501
    Not only are they taking away OTA TV in my area (shutting down the repeater network for our rural community), but they also announced that they're shutting down yet another radio station. That's the second one in the past few years. Now we're down to 5 others that I listen to regularly.
    Of course, the radio station will continue to work online and online only. But personally, when I listen to radio it's to digitally detox, not to be hooked up online. And with the possibility of losing my job looming over me and internet prices going up another $20 yet again, I'm seriously thinking of cutting my internet bill. Without TV and radio, that will kind of leave me in the dark, other than the local newspaper and going to the library to get online. But it's not my fault that they're taking down the TV stations and yet still charging us those specific taxes and that my internet bill has quadrupled.
  20. Winston Smith
    Winston Smith Active Member
    476
    339
    OH
    2024 Prius
    LE AWD-e
    The library doesn't seem like a bad option at all. I used to take the kids there to look at books and skim some periodicals.
    If people had originally been offered a radio phone, internet and cable for hundred of dollars per month, I don't know how it would have become ubiquitous.
    Last week I talked through a matter with an older fellow, a well compensated professional with a huge hospital network. He volunteered that he and his wife would be getting rid of their land line because they don't use it. Cell phones are a terrible way to converse, and some people make it worse by putting theirs on speaker.
    Who'd have thought that the high point of media and communication would turn out to be three crumby network news programs, an analogue telephone landline, and magazines in the mail?
    Isaac Zachary and bisco like this.
