Just ordered one of these
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Jan 27, 2013.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Auto Meter 2343 Autogage Mechanical Tire Pressure Gauge : Amazon.com : Automotive
    It is a little pricey for a mechanical gauge, consider you can get a similar looking one from WalMart branded SLIME for 4.99. I am tired of having gauges that read 3 PSI off from each other, and ones with poor repeatability from run to run, and in the end I don't know which gauge or run to believe.
    Hopefully this is the "professional grade", and I will use it as my master gauge that I keep in the garage.
    I am an engineer and a little OCD when it comes to measurements. :)
  2. gliderman
    gliderman Active Member
    751
    225
    Yeah, you probably dont want to know that Subway Foot Long sandwiches arent all a foot long.
    PriusCamper likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    i find that the digital ones from sears are more accurat and costs the same
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I have that exact same one (also bought from Amazon) and have been using it for a couple of years now, I would buy the same one again. Works good and seems accurate but it is hard to find a place to get it tested.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I've used an Accu-Gage for years and years--great product:
    Tire gauges
  6. Mendel Leisk
    42,355
    I like the stick gauge: very compact, never goes out of adjustment, AFAIK.
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
    You have to watch those things. I had one go bad on me and the pressures were all over the place and it was not a cheap one.
  8. Mendel Leisk
    42,355
    ^ Yeah, maybe safety in numbers. I do have a couple of the stick kind, and a digital gauge. Use them all, every once in a while, to see if anyone of them is drifting.
  9. priusincc
    priusincc Member
    332
    16
    NV
    I bought a simular guage and it seems to work well. Mine may not be super accurate, but at least you can keep the tires at the same pressure. The stick guages don't seem to work, the valve stems are too short.
