Just paid $116 for synthetic oil change,filter, and cabin air filter.Said it was to prius specs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mike doughty, Jun 19, 2013.
  1. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Not such a bad deal really.. but they did put in the wrong viscosity.
  2. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I believe the manual states the filters should be changed every 30k miles, so technically the won't be covered during the 2 yr/25k free maintenance period. But dealers will try to get you to replace them more often when they bring out the filters and show you how dirty they are. Mine tried that on me - didn't work. Perhaps I should've asked if it was included in the free maintenance plan?
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you take the filter elements out and write you initials on them, then you will at least know if the dealer is actually showing you your own filter.
  4. jhinsc
    1,167
    259
    South Carolina
    Great tip! I know if I replace my air filters just before going in for service, they won't approach me about it.
  5. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I know there are threads on this but be careful when you replace the cabin air filter. The Denso filter used by Toyota has an arrow on it indicating "this end up" when the actual air flow is down. Most replacement cabin filters have an arrow pointing in the direction of airflow so it's very easy to put it in upside down. My Toyota dealer told me I installed the filter upside down so I had to explain this to him.
    As for oil changing, I have a Mobil One garage down the street that wants 90 bucks for synthetic oil and filter change. My local Toyota dealer does it for 50 bucks, no appointment required, and give a great free lunch to all service customers which works for me.
  6. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I did an oil change and transaxle oil change at 5000 miles. The dealership charged me $87 for the transaxle and $51 for the synthetic oil and filter. They tried to talk me out of the transaxle oil change, but I insisted. I'll be back for the freebie at 10,000.
  7. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    I went to a large car service parts supplier in the UK yesterday "Halfords". The asking price for Mobil 1 0w20 oil was a little over £21 per litre (about the same volume as a US quart) making the cost for 4 litres £85 or $136 just to buy the oil. Now thats what I call a rip off.
    There oil selection charts also stated the Toyota recommended oil for the gen3 Prius as being 0w30 which we all no is not correct. All this from probably the largest motorist supply chain in the country.
    John (Britprius)
  8. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    My Toyota dealer charges $50 for oil change amd $10 rotation -------------filters I do myself
  9. michinnom
    michinnom Member
    162
    29
    good deal for all you got! where is this place? i'd like to go there
  10. Bingee
    Bingee Member
    210
    62
    Michigan
    One of the perks my dealer offers is toyota synthetic oil and filter charge
    Of 10.00 that is if you bought from them
  11. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    You should absolutely complain ... the oil cap says 0-20W the manual says the same allows 5k for 5-20W if the next is the right one .. THEY did not follow prius specs...
    But otherwise the price is comparable what toyota would have charge ...one thing to repalce cabin filter or even the ICE filter is absolutely easy. Even if you buy the OEM parts you can easily do it (well maybe not) . But both is very easy. But changing the light bulb (lower beam) boy that is hard on the passanger side ... not impossible but hard for the first time.
    kenoarto likes this.
  12. Mendel Leisk
    41,397
    Wow!
    The last 0W20 I purchased was Toyota brand, at the part's counter, for $5.65 (Canadian) per liter.
  13. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I just checked my cabin air filter the other day and it was in upside down, ooops. It still kept the pollen, dust, acorns, and mouse droppings out of the blower motor just as effectively as if it was right side up.
    Me thinks direction isn't as important as making sure you don't flip the filter if it's removed and reinserted. My filter is still upside down, because I want the mouse dander to stay on the side away from the blower motor.
