Just purchased Bridgestone EP422 tires
Discussion in 'Gen 3 Prius Fuel Economy' started by alfon, Aug 12, 2012.
  1. Dmatt
    Dmatt New Member
    75
    Too funny, why didn't I think of that......you are right!!
    F8L likes this.
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    So far about 3,000 miles on the Ecopia's and about about a 2-3 mpg hit over
    the Michelin Energy Saver AS. I just may, during this 30 day money back
    guarantee with Bridgestone, exhange them for the Michelin Energy Saver AS
    tires. I believe Michelin will have another $70.00 rebate begining Sept. 8 with
    Costco where I buy my tires.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    alfon, how does the handling of the EP422 compare to the Energy Saver A/S. I have about 15k on my Energy Saver A/S and am now becoming extremely disappointed with the handling and traction, now that the tires have worn down a bit. The car floats a lot and taking corners fast results in a horrendously loud scream. Thanks.
  4. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    I'm wondering about the direct comparison for, as The Critic asks, reasons other than MPGs. Safety and noise are big issues for me, and I'm wondering how the Ecopias (the 422s) compare to the Michelin Energy Savers on those counts. Did you also have issues with handling and traction, as noted in The Critic's post?
  5. The Critic
    3,193
    2,319
    CA
    They're probably still OK. Usually tires take 10k or more to really show any deficiencies.
    iPhone ?
  6. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Mine have about 10k on them and so far no noise when cornering.
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    The Energy Saver tires seem to corner well and so does the Ecopia's.
    I just noticed at high speed driving 65-70 the tires appear to somewhat make
    the car float a little. Somewhat like the wind is blowing, even though there
    is no wind. The Energy Saver tires were much more stable.
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    that sounds about right. In my experience they give ~1/2 of Energy Saver MPG improvement when compared to stock Avids.
  9. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Just got back from Costco. They will install the Michelin Energy Saver AS
    tires for about $74.00 more than the Ecopia's cost me. They would have
    installed them today but they had to be ordered.
    To me the $74.00 is well worth it.....
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Not bad. :) I am going to see if the 215/50/17 is available yet. It would be interesting to try it on a GenIII.
  11. a priori
    3,083
    407
    23
    Chicagoland (West)
    How do the RPMs on the 215/50 compare with the stock 215/45s and the stock 15s?
  12. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    They are taller than the OE 15s by approx. 1/2" so the car will be sit higher but also fill the wheel well more. The 215/45/17s vary but are approx. 1/2 to 1/4" shorter than the OE 15s. Ideally one should use a 205/50/17 but tire choices are different than in a 215/45/17. My idea for the 215/50/17 is based on using a slightly larger tire to compensate for lowering the vehicle. I would only want to lower the car to reduce wheel well gap. I don't want to lose ground clearance because I take my car off road for work. The 205/50/17 and 215/50/17 would fill the wheel well better than the 215/45/17 and may not require lowering (doubtful). I wouldn't even consider the 215/50/17 but Michelin lists the Energy Saver A/S is this size. It's sorta like a GenII owner switching from 185/65/15s to 195/65/15s. I'm not certain it would work but it never hurts to speculate. :)
  13. cyclopathic
    3,292
    547
    2014 Prius c
    Just make sure you get road hazard protection. Energy Saver sidewalls are toilet paper thin and can be easily damaged
  14. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    He already had a set. :)
  15. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    On our last set of energy saver tires we put on over 68,000 miles and never had
    as much as a low tire. I believe that Costco has a great service policy.
  16. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Just got back from Costco. Installed Michelin Energy Saver AS tires, 195x65x15.
    Cost only $48.00 more than the EP-422's.
    Soon as I drove off I noticed the smoothness and quiet. After over 7 miles
    from reseting trip A it read 70.5 mpgs( indicated) when I arrived in Astoria.
    With the Ecopia it would have read 63-65 mpg indicated. The Ecopia's also were well
    broken in with about 3,000 + miles, the Michelin's, of course, brand spanking new.....
    solrunner likes this.
  17. jlulu
    jlulu Junior Member
  18. jlulu
    jlulu Junior Member
    I purchased the EP422's from costco last month. While I like the tires better than the stock tires, after reading this post I decided today to leverage this "knowledge" and follow the same path by returning them to costco and "upgrading" to the Michelin Energy Saver AS.
    However, per costco (and other posts in this forum) there is a nation wide backorder on these tires. The only Michelin option they offered at the "Michelin Energy Saver" tires (touring summer version, not AS) and these tires will cost a total of apx $200 more. I'm not sure the $200 is worth it as the EP422's were only about $380 to begin with.
    I definately want the better MPG. Any suggestions?
  19. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    If you are Cali local I am selling my slightly used Energy Saver A/Ss. :)
  20. jlulu
    jlulu Junior Member
    I am a CAli local (sac area) and I'd normally be interested in picking up the AS, but given that I've already purchsed my existing set from Cosco I'm kinda stuck going with them.
    any suggestions on my options at this poing staying with the E{422's, moving to the summer Energy Savers, or other optoins?
