Just purchased car and A/C air not cold :(
Discussion in 'Gen 2 Prius Technical Discussion' started by 2007Touring160K, Oct 17, 2023.
  1. 2007Touring160K
    2007Touring160K Junior Member
    Los Angeles
    Four Touring
    Read up on this in previous related posts but still a bit perplexed as to what the best course of action is.
    Just purchased ‘07 Prius w/ 159K miles. I thought I felt cold air when I test drove it but then today when I was driving on a hot day it became very obvious that the air was not cold at all; even with the A/C on max and at the lowest temperature setting.
    Looked through maintenance records and found that an A/C recharge was done in Nov/2022 w/ “Freon R134-a, a/c service valve, and a/c dye/oil” but thats all I know. Worried that this is gonna be expensive to fix but hoping another recharge will do the trick.
  2. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Finding a note that dye was applied means that somebody suspected a leak in the system.
    Not finding a later note that a leaky part was replaced suggests that if it was ever found, it might not have been fixed.
    You may have just discovered why the car was for sale.
    I would start by looking for dye stains, in the hopes of locating the leak.
    The thing to know here is that a Prius is very sensitive to refrigerant quantity. If you are off by much in either direction, there will be expensive consequences, unfortunately. Many have learned this the hard way.
    If you don't know how much refrigerant is in the system, the only way to gain certainty is to recover and vacuum out all that remains and start over from zero.
    Don't get suckered in by the quick-shot storebought cans. Those are for cars you're going to get rid of this week.
    #2 Leadfoot J. McCoalroller, Oct 17, 2023
  3. 2007Touring160K
    Los Angeles
    Four Touring
    Looking for a leak something I can do myself? I have no idea where to look.
    Thinking I’ll call the shop that did the work and ask if I could bring it by to see what’s leaking or going on.
  4. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,519
    Durham NC
    If you connect a low side gauge to the system use of that goes from zero to a hundred pounds with a blue hose on it what does it say right now not on sitting . Nothing at all on You see like 90 lb on the gauge? I'm also not certain that our specialized oil for the electric compressor comes premixed with dye I haven't gone shopping for this yet so I don't know if they use the proper oil and then injected the die separately or whether they make our oil with dye aalready in it I personally haven't looked. And looking for long streaks of this die on every fitting you can see condenser compressor hoses so on and so forth connections at the fire wall.
  5. Tombukt2
    13,867
    2,519
    Durham NC
    If you have one of those silly cans of 134a with the gauge on it that you used to charge the wife's car or your other car or what have you connect that to the fitting that's in between the inverter and the engine with the gray cap on it might be a black cat that fitting will only fit on that tube It won't fit on the one on the other side of the engine when you do that with the system not running nothing's happening no buttons have been pushed what is the gauge say? That's a quick test you should be able to do in the advance Auto parking lot You're looking for right around 88 to 94 some odd pounds at rest seriously. If you see 40 you are extremely low on gas 40s what it needs to be at or close to it when the system is running compressor pumping everything on that line is cold so on and so forth.
    2007Touring160K likes this.
  6. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    If it's a bad leak you can usually spot it as a big oily wet spot, even without dye. You still sort of need to know where to look.
    For slower leaks and harder-to-reach areas, you need the dye and then an ultraviolet lamp to make the dye light up- but you still need to know more or less where to check.
    A leaky condenser is common on cars that old, and not that bad for repair costs. A leaky evaporator is a bit less likely but they require an obnoxious amount of labor to swap... so hope it isn't that.
  7. 2007Touring160K
    Los Angeles
    Four Touring
    Ordered silly can of R134a and UV light.
    #6 2007Touring160K, Nov 1, 2023
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,120
    6,977
    Texas Hill Country
    To see refrigerant dye you need a uv light and glasses. As stated above the most common leaks are in the condenser (in front of radiator) and the evaporator (buried behind dash which has to come out to change). The evaporator is close to $2000 installed due to labor and parts. In either case use only oem parts or you will lose cooling capacity. Never use sealer or refrigerant with sealer or oil. High voltage 3 phase power is in the compressor which can burn out with the wrong oil.
  9. 2007Touring160K
    Los Angeles
    Four Touring
    I just got the light w/ out the glasses. Hopefully that’s okay
  10. rjparker
    11,120
    6,977
    Texas Hill Country
    The glasses help.
  11. Tombukt2
    13,867
    2,519
    Durham NC
    My UV black light that is just a handheld fluorescent piece of nonsense and I also have one that's made by Coast like a flashlight I haven't never had to use the glasses I just use the little flashlight put it in the right mode and I'm usually doing this at dusk or I'm pushed in the garage which is like dusk in the shade and then that's droplets of that yellow dye light up like fluorescent man It's like a light show from the '60s if it's coming out like that and if it's in the evaporator I just test the water as it's dripping out if the system's running at all If not you can just pour water into the evaporator case and what runs back out shine the light on that see traces of the dye and you know you haven't evap leak or expansion valve or something like that in that case.
  12. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    The glasses are to protect your retinas, not to make the image clearer. Always wear eye protection when working with UV!
    Personally, I would take this car to an A/C shop and not turn on the A/C until then. For all you know the amount of refrigerant is way off and running it like that can destroy the compressor.
  13. 2007Touring160K
    Los Angeles
    Four Touring
    With the car turned off this is what I got. Heard a sound when I popped it off the valve so there’s definitely refrigerant in there. Im thinking this means that the problem is perhaps not the level of refrigerant so I didn’t add any‍♂️ Should I add some? Will put the UV light on it tonight.
    Tombukt2 likes this.
  14. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    the only way to get one of those systems working right is to put exactly the right amount of refrigerant in.
    That means recovering whatever's in there, vacuuming the system totally empty, and then adding back exactly the right amount as measured by a scale.
    if you're off by much, it'll wear out the compressor pretty quickly.
  15. Tombukt2
    13,867
    2,519
    Durham NC
    So this picture of the gauge this is with the car on and the air conditioning on a full tilt correct?
    If that's your standing pressure with the car off then sitting there 20 minutes whatever You should see almost 100 lb on your gauge 94 something not 37
    #14 Tombukt2, Nov 7, 2023
  16. 2007Touring160K
    Los Angeles
    Four Touring
    No it’s with the car completely off bc I thought that’s what you said. And I left the gauge on for a minute or so. Ok I’m gonna add some refrigerant until I get it in the 90s. Here goes nothing
    #15 2007Touring160K, Nov 8, 2023
  17. Tombukt2
    13,867
    2,519
    Durham NC
    Yeah generally on all of my cars here including my '01 sienna van when the system is completely stopped there's no high and low side both the high and low side with the appropriate gauge and the proper fitting to connect it to the hose will read right at 100 lb 94 96 93 Right in there somewhere The minute you turn on the air conditioning switch you will see the low side which is the side you're dealing with get pulled down to that 37 or so that you see right now which I guess you have because you're pretty low on gas that should be enough to start the system and the compressors running but it's Wailing out RPM tryna pump al.ost nothing. Don't do that get a can of gas turn the mess on can upside down and start letting some in slowly and feel your fat hose coming off the compressor. When it starts getting cold you need to keep an eye on your sight glass and almost all the bubbles start to clear turn off the gas feed and let it sit there and run and watch the bubbles or lack thereof in the sight glass and feel your big line should be nice and refrigerator cold air conditioner should be on LO and high fan The car should be cooling off smartly inside by now You should be seeing a constant 37 on the low side gauge or somewhere right around there up to 42. And that should be about it pretty uneventful.
  18. dolj
    dolj Senior Member
    8,652
    4,402
    Wellington, New Zealand
    I wouldn't do that.
    Well, it's nothing if you don't count the $2000+ you'll spend replacing the destroyed compressor.
  19. 2007Touring160K
    Los Angeles
    Four Touring
    Well I refilled refrigerant and got cold air! I just don’t know if it’s cold enough but it definitely is cold! Was blowing for like 15min non stop the other day. If it’s just a leak and have to recharge with refrigerant once a year I’m totally fine with that. Hopefully just a leak. I put the UV light and tried to follow the hi and low pressure line best I could. Anyways I’ll take what I can get.
  20. Tombukt2
    13,867
    2,519
    Durham NC
    The metal lines unless they're rubbing against something what you see on those is should be just residual where somebody touched some blow-by got loose and stuck to the pipe where it turns to rubber and where connections are like penetrating the firewall and the o-rings If you get one of these cars and it's already out of gas before you go shooting gas in it you might want to put a few o-rings in they're easy to put in it doesn't take much to do it and many times they are old deteriorating and will let gas by them so you buy an o-ring kit they're like green color or purple the o-rings they're better than Buna N which was the old type. Then you can shoot some gas in get enough pressure to kick the compressor on look at your sight glass run it up until the bubbles almost disappear stop charging see the 37 or so on the low side pretty consistent have a fat cold metal line and car cooling and call it a day and see what happens next year or at the end of cooling season Is everything still working? You're probably good $2,000 compressor not in my world I'm at five of them sitting here in the shed ready to go they're very reliable It's only when you run them low on gas and have them winding out at 7,000 RPMs are they going to think about imploding and shredding themselves generally speaking of course.
  21. 2007Touring160K
    Los Angeles
    Four Touring
    So if there’s is residual from when someone touched it maybe they touched it to replace the O-rings and the O-rings dried out ??
    Next time I have to recharge it I’ll look into the O-Rings although it was low on refrigerant (or gas) it wasn’t empty... the gas has to be totally empty to replace the O-rings ?
    So if I don’t put the A/C on the highest level I will make my compressor last longer by avoiding 7000rpm?? Compressor better than evaporator
