Just read about the inverter recall!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nudriver, Feb 20, 2018.
  1. nudriver
    nudriver Member
    283
    32
    los angeles
    Found the answer boys. I called up a different dealership and the guy looked up my car. Turns out back in 2014 I took it in under the warranty for free oil changes. At that time the part was changed. I just never knew.
    The same guy I spoke to said that the Takata recall doesn't apply to my car. Yet it's showing that it does on the website, though not listing it as a safety problem, so that still doesn't quite make sense.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    That sums it up.
  3. nudriver
    nudriver Member
    283
    32
    los angeles
    What does that mean? I have to change my inverter even though there was no recall? That doesn't make any sense.
    52,775
    you can plug your vin into the toyota owners site for some helpful info.
  5. 4md
    4md Member
    97
    55
    Sofia, BG
    Is there any other way to tell if the update was applied? Maybe using Techstream and see the software version?
    I tried to put my vin in Toyotaowners.com, but it says it's not valid Toyota VIN. Maybe because mine is EU version...
    I'm the second owner, but as far as I can remember, the local Toyota dealer said that the whole inverter has been changed under warranty at around 60k miles.
  6. renatomn74
    renatomn74 Junior Member
    Italia
    In the link below, there is a Dutch-language document that I found on the Toyota-Tech.eu website by inserting my VIN: when the inverter is updated they make a red mark above it. My car (2014) mounts the G9200 - 47190 inverter (with red mark).
    https://drive.google.com/file/...UqLAv40y4O0J/view?usp=drivesdk
    Inviato dal mio ASUS_Z017D utilizzando Tapatalk
  7. renatomn74
    Italia
    I write from Italy but I did not find the previous document in my language.
    The second picture is my inverter.
  8. renatomn74
    Italia
    Correct link/file
    #28 renatomn74, Jul 3, 2018
  9. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    Hi I don't know if it's related at all but my 2010 model recently had a P0A80 diagnostic on the battery from the local Toyota dealer and checking on the Toyota recall site it does apply for the Safety Recall E0E, NHTSA ID recall 14V053. What I want to know is: could my diagnostic of the dead battery code be influenced in any way by this recall situation or could it be causing a false positive P0A80 code? The recall problem in describing pretty much everything that is happening to my car. Thanks.
    #29 Andres V, Oct 26, 2018
  10. renatomn74
    Italia
    I don't think the battery problem is connected to the inverter issue. The P0A80 code may be due to a faulty cell (or several cells) inside the battery. Through an obd adapter and a program / app you can check the status of the individual cells. The hardware that controls the status of the cells (signal electronics) is different from the hardware that manages the current in the IGBT (power electronics). The problem of inverters should concern an inadequate dissipation of IGBTs in case of current peaks.
    Can a faulty inverter damage even one or more cells? A still working inverter, but with too stressed IGBTs, can it ruin the battery? I think not: in cases where the inverter broke and then it was replaced, the batteries did not have any problems.
    P0A80 Replace Hybrid Battery Pack
  11. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    I got news, today I got my car back. No actions were taken because my dealer told me I have the latest software on my ECU. I asked if they could give me the version numbers of my software and they replied there isn't any to identify the releases. Seems quite unlikely but I'll let this one pass. I just don't trust my dealer, hope I don't regret it.
  12. Will J
    Will J Junior Member
    CA
    I just had the IPM fail on my 2015.
  13. Jon Watkins
    Jon Watkins Active Member
    131
    115
    Bluffton SC
    2024 Prius
    How many miles?
    What did it do when it failed?
    Cost to repair?
    I’m going to buy an IPM from a recycler to have on hand in the event mine fails. Can still get them with low miles.
  14. Justify1
    Justify1 Junior Member
    Fresno
    Yesterday I was driving warning lights came on hybrid system,lost power in my 2012 prius c.How do I get on lawsuit for my car.Pretty sure it is ipm ,I have serviced my car regularly,put best gas in.
  15. ArtAtlanta
    ArtAtlanta New Member
    Atlanta GA
    Recently had the software recall done on my 2012 Prius V. Never had any problems with this car before. Driving 5 weeks after the software install, the Inverter Fails.
    Getting quoted very high prices on repairs.
    Anyone else had failure after the software install?
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Seen post of inverters fail after update, check to see if your inverter is still under warranty first before looking into repair prices.
    Raytheeagle and RMB like this.
  17. Prieth
    Prieth Junior Member
    17
    NM, USA
    I might be wrong, but I thought they extended the warranty for these inverters to 15 years.
    I've only had my car a couple weeks and haven't gone for the recall, does anyone know if you are required to have the recall performed to receive the warranty extension?
    SFO likes this.
