Just Replaced 2 Bad Battery Cells In My 2007.. Now All Dash Lights Are On And Engine Wont Start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GenoJ, Feb 12, 2015.
  1. Kevin Cecchini
    Kevin Cecchini Junior Member
    44
    Clinton, Michigan, 49236
    wait, I have a 2004 prius and I have to press mine up. it only goes up, the lever that is. Is there something I am doing wrong?
    I charged the traction battery pack with the $400 charger and let it sit for half hour to an hour and then the first thing I did was enter inspection mode with holding the auxillary button while the power is on and turning the lights on and off three times. After I did that, I shut off the power and then nothing occured. that is, the transimission will go into neutral and back into park, but not in revers or drive and the engine will not start. any ideas?
  2. JC91006
    16,764
    8,562
    Flip the orange lever up and then slide the entire thing down. Just push it down towards the floor. You'll see it slide and lock into place
    51,851
    after you press the switch in (up), you have to slide it down.
    whoops, missed jc's post.
  4. Kevin Cecchini
    44
    OK I just did that, sweetness. thank you so much.
