Just replaced the Air/Fuel and O2 Sensor, Plugs in my 2007 Prius. Getting P0420. Whats Next?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simple2code, Aug 4, 2017.
Tags:
  1. simple2code
    simple2code New Member
    Rancho Cucamonga, CA
    I just replaces Air/Fuel Sensor and O2 sensor + plugs and air filter. Still getting P0420. Whats next to check replace?
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Probably catalytic converter. Normally you should be able just to look at live data from computer to determine if it’s sensors or catalytic converter. But since you already replaced the sensors then it’s very likely catalytic converter. How much oil does it consume?
    m.wynn likes this.
