Just so I understand 12v charging
Discussion in 'Prime Main Forum (2017-2022)' started by schja01, Dec 4, 2018.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No but people who don't know how to interpret the readings DO.
    Maybe not intentionally.
  2. sam spade 2
    7,035
    2,804
    2017 Prius c
    Perfect.
    Thank you.
    padroo likes this.
  3. sam spade 2
    7,035
    2,804
    2017 Prius c
    Thank you for the additional explanation.
    That's what I was getting at.
  4. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    I would answer no for Prime and yes for Plugin (2012-2015). When I put a voltmeter on my Prime’s 12 volt battery, the reading when everything was off was the same as when it was charging the traction battery, leading me to believe the Prime did not charge the 12 volt while charging the traction battery. When I put the Prime in READY, the voltage on the 12 volt went up so I believe it was charging.
    My Plugin was different, as the voltage on the 12 volt went up during charging of the traction battery.
    I suppose it is possible the Prime charges the 12 volt during traction charging IF the 12 volt is at a low state of charge, but I have not seen this.
    Downrange and jerrymildred like this.
  5. bisco
    52,755
    see post #9
  6. kaptmorgan
    kaptmorgan Junior Member
    33
    marietta Pa
    I think on the prime it does because the main battery is heated or cooled by the 12V battery during the Charge cycle.
  7. bisco
    52,755
    there wouldn't be enough power for that. it is heated or cooled by the hybrid battery itself, delaying charging.
  8. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    You could turn the headlights on for a few minutes prior to doing the charging test.
  9. Trollbait
    12,800
    There is a DC to DC transformer that steps down the voltage from the traction battery for powering 12V accessories. So something being 12V doesn't mean powered by the starter battery.
  10. Mendel Leisk
    42,242
    Just editorial: which battery do you mean by "starter battery"?
  11. TPP2k18
    TPP2k18 Junior Member
    23
    Vancouver, B.C.
    2018 Prius Prime
    Technology
    In my Prius Prime 2018 sold in Canada, the manual says, and while I can't find the spot here, I am pretty sure it says the heating is done by the 12v, and that is why if it is plugged in for more than 3 days, the heater auto stops. But I am probably wrong lol.
    ■ Hybrid battery (traction battery) warming control (Alaska and Canada only) This control operates after the charging cable remains connected to the vehicle for 3 days and “Traction Battery Heater” automatically stops. It automatically insulates the hybrid battery (traction battery) in extremely low temperatures. ● This control stops 31 days after the charging cable is connected, even if it is still connected to the vehicle. ● When this control operates, timer charging settings are ignored and charging starts immediately.
    “Traction Battery Cooler” uses the power of the hybrid battery (traction battery) and external power source. • While “Traction Battery Cooler” is operating, the amount of the remaining charge of the hybrid battery (traction battery) increases and decreases in a certain range, and does not increase as in normal charging.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    There is no such thing as a DC to DC transformer.
    And there is no "starter battery" in a Prius.
    It is the accessory battery........and the accessories and computers are sometimes powered by the battery and sometimes by the inverter.
  13. bisco
    52,755
    agreed, i'm not exactly sure what they are saying there about the 'heating' and 'insulating'. would love to know the details.
  14. Trollbait
    12,800
    Your post was oh so helpful:rolleyes:
    I used the wrong specific term for a specific type of power converter. Electric power conversion - Wikipedia
    Is providing a correction too heavy a lift for you? (It is a converter, not transformer, for those interested.)
    People commonly use starter when referring to a car's 12 volt regardless of whether it actually turns a starter motor, or just boot up the computers. How many posts have you corrected for using charger when the person meant EVSE today?
    bisco and Mendel Leisk like this.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Good.
    Yours certainly was not.
    Either of them.
  16. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    There is no need to charge the 12v battery while charging the traction battery just because the fans are running. If the 12v battery is up to voltage the charging system and traction battery will deliver power to the fans while the battery just floats on the line.
    Trollbait likes this.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    That's true but the REST of the story is:
    The 12 V battery is almost NEVER completely "up to voltage" so any time the charging system is active some charging of the battery is likely to be taking place.
  18. bisco
    52,755
    agreed, it's keeping the battery from discharging, just not enough to register on your typical volt meter.
  19. BChoAss
    BChoAss Junior Member
    34
    22
    CA
    2019 Prius Prime
    Interesting find WeberAuto on Youtube:
    Apparently the charger assembly on the Prius Prime tops off the 12v battery when plugged in.
    (timestamp 20:18)
  20. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Yes, but not very effectively. It only maintains at ~12.7v most of the time, and occasionally tops off at ~13.5v. And this only happens while the traction battery is actively being charged. Once the traction battery charging is completed, keeping the charging cord plugged in will not maintain the 12v battery but rather drain it faster.
    See this thread for more information:
    Hopefully, ultimate 12v battery charging system discussion on PP | PriusChat
    #40 Salamander_King, Apr 18, 2022
    schja01 and jerrymildred like this.
